Question about Scanport N9 19" LCD Monitor
H21 LCD Monitor -No display
The problem I'm having is the monitor is not displaying anymore, its just a blank screen. When I turn the monitor on the green light comes on briefly for like a second and then goes off . I have hooked up a different monitor and that works fine, so I know my pc is not the culprit. I do have the monitor apart and there are like 5 circuit boards inside.I don't know what needs to be replaced. Any help would be greatly appreciated. Thanks
I am having a similar problem. the backlights are coming on but with Windows loaded I just get a mostly bright screen with some faint colored streaks . But no image. I have looked at all the components and there are no bad Caps. The data interface looks the same as the one on my laptop. So I hooked the it up to my laptops data cable with the inverter being powered my it's own circuitry. But the back lights come on and there are not colored streaks.
I'm wandering if the lcd is bad or the electronics that run it.
Any suggestions.
Posted on Dec 31, 2007
  • 9,098 Answers
With that many boards, it probably has a separate ballast (inverter) to run the lamps. In the power supply section, I would look for bulging electrolytics and bad connections. In the ballast I would suspect a shorted output transistor, a bad output transformer, a bulging capacitor or bad connections.
Posted on Jan 21, 2007
I've got a Scanport H21 monitor that the green light comes on but has a black screen. Can not dring up a menu or "VGA IN" message.
I am in computers. This is either a #1. display that is going out. #2. the video card fails some times, #3. or the monitor is not plugged in all the way. #4. The VGA cable is not firmly attached to the Momputer/monitor. Your VGA IN message that the computer does not have its signal to the monitor that the connection to the computer is good. God Bless
John
Apr 16, 2017 | Scanport H21 21" LCD Display Monitor
You can try a different cable for VGA. Check if the port is lose. The green light is only indicating a proper power supply to the monitor. The display is very much dependent on the VGA cable. If your monitor also has HDMI port, you can try to connect using that cable (provided the display adaptor also has HDMI port). If nothing works for you, take it to a hardware engineer or local repair shop.
Jan 20, 2014 | Scanport H21 21" LCD Display Monitor
My hp dv4-1435dx screen is blank.It was on then it froze and then went blank. I have tried to fix it by removing the battery and replacing it a number of times. It comes on when started and plays the...
This could be due to presence of static charges on the notebook or hardware malfunction of the video card or defective LCD display screen of the notebook. To resolve the issue, perform the following steps.
Step 1: Hard Reset
To perform a hard reset, please follow the steps listed below:
1. Unplug the AC adapter from the notebook PC and remove from any port replicator or docking station.
2. Remove the battery from the notebook battery compartment.
3. Press and hold down the power button for about 20 seconds.
4. Insert the battery and plug the AC adapter back into the notebook PC.
5. Press the power button to turn the notebook PC back on.
This will discharge the static charges from the notebook. Now check if the display works fine or not. Incase, if the issue persists, then the video card or LCD screen must have gone bad, and to isolate the same, please connect an external monitor to the notebook and check for the display on it. You can follow the steps below to connect an external monitor to the notebook.
1. Turn off the notebook.
2. Connect the monitor cable from the external monitor to the monitor port on the rear/side of the computer.
3. Connect the monitor to a power source and turn it on.
4. Press the Power button to turn on the computer.
At this time, please follow the instructions mentioned below for switching the display to the external monitor:
The notebook's video card supports three modes. Built-in screen only; external video only; and both on simultaneously (mirrored). If you're not seeing the image on the desired device(s), the notebook's video card is probably in another mode. Press FN + F4 to cycle through the display options: Notebook display, External monitor, both.
If you press FN + F4 once, the external monitor will display & there will be no Notebook LCD display.
If you press FN + F4 twice, the external monitor will display & there will be some shading on the Notebook LCD.
If you press FN + F4 thrice, both Notebook LCD & external monitor will display.
If the issue persists on the external monitor, then this could be due to defective video card on the notebook. However, if the display on the external monitor is fine, then the issue is with the LCD display panel of the notebook. In either cases, the notebook requires a detailed onsite diagnosis by a service technician.
If your notebook is under HP warranty, then contact HP to get the notebook repaired for free of cost.
Jun 01, 2010 | HP Pavilion dv4000 Notebook
Screen goes blank after a few seconds
Hi ,
The monitor flicker problem. The monitor when turn on will display image for couple of second then turn black. The monitor status led is still green. This will happen each time it is turn on. The symptom at appear to come from the inverter board.
May 08, 2009 | NEC-Mitsubishi NEC Display Solutions...
Need power supply board for H21 LCD monitor
H-21 scan port Dark Screen, If you unplug the green light flashes 2 or 3 times ending any activity until completely unpluged and plugged in again. My other scan port works fine using 1st monitor cables. I've used both ports on the graphics card. It's definately the monitor power supply or other componant.
Any ideas?
Bill
Nov 12, 2008 | Scanport H21 21" LCD Display Monitor
Monitor displays breifly then goes to blank screen
The power -inverter board probably needs an overhaul.
I redo many of these.
If the screen was pinkish or flickering before it finally got to this point, it is possible that a bulb has gone bad.
Fran
Sep 07, 2008 | Proview PL926WBi 19" LCD Monitor
LCD monitor goes blank
It appears that the display resolution set in your display properties is out of the range that the LCD can display.
Try this.
Boot to the ENABLE VGA MODE by pressing F8 to get the Windows Boot Menu. If you can get to the desktop, then go to display properties, and see if you can change the resolution to higher settings and maintain video. (If the video blanks out, then it should revert to the previous setting in 15 seconds)
Aug 03, 2008 | Gateway FPD2275W LCD Monitor
There is just no way you will be happy to hear it needs service or replacement under warranty.
Worldvet
Jul 03, 2008 | Relisys RLT1720 17" LCD Monitor
Scanport H21 problem.
Fried chips? Tech with electronic repair requested.
Sep 08, 2017 | Scanport H21 21" LCD Display Monitor
Scanport N9 19" LCD Monitor Logo
202 people viewed this question
Top Scanport Computers & Internet Experts
William Miller
William Miller
ray gallant
Paul Chapman
Paul Chapman
Are you a Scanport Computer and Internet Expert? Answer questions, earn points and help others
