Question about Microwave Ovens
Picking replacement over-the-range microwave for easiest install
We need to replace a 30'' GE Spacemaker microwave. It was suspended from side brackets, with top retaining screws. There are at least 4 models showing the same dimensions, though none appear to publish their installation process. We purchased one (HVM1540), and find that it uses a bracket mounted across the bottom on the rear wall, which would involve cutting into our tiling, quite apart from a completely new set of holes in wall and top cabinet. Does anyone know how to find a model compatible with the top suspension?
  • 1 more comment
  • andrewrb Nov 30, 2008
    Please note that we're not looking for parts or repair, but information on which models have what type of bracket mounting (and confidence that bracket does not extend beyond stated microwave dimensions). I have not been able to find this published online.
    I probably should have noted the height of the GE models, and space available, as approx. 16". The shallowest current Whirlpool I could find is 17.5", likely to be a problem.
  • andrewrb Dec 01, 2008
    As commented, the Whirlpool doesn't appear ideal because of greater height, so that it overlaps tiling. However, if I stick ply of same thickness as tile, and can mount bracket on that so that everything is flat, it may work.
    Thx
    Sergeant:
    Champion:
  • 291 Answers
The whirlpool has support mounting on top but it still comes with a mounting plate you screw to back wall and hang the microwave on it then run the mounting/support bolts down into it / the back plate can be mounted by drilling 4 holes in back wall to mount it and non of the mounting shows / that would be your best bet / larry
please do not forget to leave a rating
Posted on Nov 30, 2008
    Sergeant:
  • 217 Answers
Www.repairclinic.com check out this link for replacement parts.
  • Microwave Ovens Master
  • 19,396 Answers
You need to use you complete model number, the one on the service plate to order the part.
Possibly call the dealer at the phone.
Try calling this one.
I have a GE OTR microwave JVM1460 spacesaver xl1400. I am trying to take it down. I unscrewed the two top bolts from inside the cabinet. I thought it should just swing down on the mounting strip, b
remove-ge-spacemaker-800x800.jpgRemove a GE Spacemaker
The GE Spacemaker series of microwave ovens are designed to be installed above an oven range, freeing up counter space in your kitchen. Some of these Spacemaker models are connected to an outside venting system to carry kitchen vapor and odors outside. Other Spacemaker models utilize a ductless system to do this. Removing a GE Spacemaker microwave oven isn't a difficult task, but, because of the size of some of the oven models, it is a two-man operation. Have a question? Get an answer from an appliance repair specialist now!
Other People Are Reading
Things You'll Need
  • Assistant
  • Sharp knife
  • Phillips screwdriver
Instructions
    • 1 Open the cabinet above where the Spacemaker microwave oven is installed. If you see a vent in the cabinet leading to the Spacemaker oven below, your Spacemaker is vented. This vent needs to be disconnected before continuing with removal. Disconnect the vent either by loosening the duct clamps or by cutting the duct tape away with a sharp knife. Pull the vent out of the top of the oven.
    • 2 Have an assistant support the oven from below. Loosen the mounting screws connected to the Spacemaker through the cabinet bottom. Loosen the screws by turning counterclockwise with the Phillips screwdriver.
    • 3 Unplug the Spacemaker from the socket in the cabinet.
    • 4 Continue loosening the screws while your assistant holds the oven in place. Once the screws are removed, have your assistant slowly lower the Spacemaker down by lowering the front face at a 45-degree angle.
    • 5 Feed the power cable for the Spacemaker through the hole in the bottom in the supporting cabinet.
    • 6 Help your assistant slowly pull the Spacemaker forward and out of the mounting brackets on the rear wall. Once the Spacemaker is cleared of the mounting cabinet and rear wall, set it down.
    • 7 Remove the mounting bracket from the rear wall by loosening the screws.
Read more : http://www.ehow.com/how_7344250_remove-ge-spacemaker.html
Nov 26, 2014 | GE Microwave Ovens
What model replaced the 36" profile spacemaker?
I am under the understanding that GE and other manufactures have discontinued the 36" microwaves you may have to purchase a trim kit to fill the space from a 30" unit.
Sep 22, 2014 | GE Profile Spacemaker Over-the-Range...
How many cubic feet is a GE spacemaker model l# JVM240WL001
you must ask some vendor Online via chat with GE, they offer many Sales, and good opportunity. Get in tourch with them.
God bless you
Aug 03, 2012 | GE Profile Spacemaker 1.8 Cu. Ft....
GE PROFILE SPACEMAKER 2 JVM2070SH001 MANUAL HOW DO i REPLACE CHARCOAL FILTER?
That's covered in the owner's manual. If for some reason you don't have yours, you can download GE owner's manuals and installation instructions here.
You can find handy exploded views and order parts (including filters) here.
Jan 10, 2011 | GE Profile Spacemaker Over-the-Range...
Ge profile spacemaker 2.0 model#JVM2070SH001 - HOW TO REPLACE CHARCOAL FILTER.
What is the recommended clearance between spacemaker microwave oven and range top
30 inch minum from the cooking surface to the cabinet above. See this link for installation instructions and more specifications.
http://genet.geappliances.com/DocSearch/Dispatcher?REQUEST=SEARCHWITHURLCONNECTION
Apr 23, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Model of 1989 GE Spacemaker
The model number should be on a tag as shown in the drawing below.
Feb 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I'm trying to uninstall my over the range ge spacemaker and can't
You can download GE installation instructions here.
If you're replacing it due to a defect, we may be able to guide you to a less expensive repair.
Otherwise...
Dec 12, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
127 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
