Question about Samsung DLP HL-P5663W 56" TV
Television sound my tv works fine..... but there is this annoying buzzing sound that i would like to get rid of but dont know how...... some help would be nice HLP6063W Samsung. Loud buzzing sound, sounds like a fan. Repair man comes out and says it is the color wheel. $350.00 and he has to take the TV for a week. We don't believe him because what we have read on Jangro.com When the color wheel bearings go out they make a screaming sound and the picture is distorted. Our picture is fine. It definately sounds the same as a cooling fan in a computer, like something is hitting the fins. Anyone replaced the cooling fan?
    Genius:
  • 1,239 Answers
Hi
the sound is because of only 2 problems1.fan                                                     2.famous color wheel in it so if very well could be a fan, question is there are three. All differant sizes and have differant part numbers so you will have to find out which one and get back to us on its location.
you can get its parts here 1-787-373-11 about $10.00 at www.vancebaldwin.com
Posted on Dec 07, 2008
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
On Nov 29 you posted that "I recently replaced the color wheel". Other than the color wheel, there would be other motor for fans inside your Samsung for ventilation, might then this be at fault now? Additionally, it could be a cable or wire slightly touching a fan blade hence the sound as you described. Of course best recommended action would be to open again the unit and observed, move some wires/cables away from potentially touching any of the fans.
Incidentally, a loose speaker frame/mounting could also produce annoying buzzing sound.
Good luck and Thank you for using FixYa. Happy Holidays.
  • Louie  Role
    Louie Role Dec 12, 2008
    Hi again,
    Any updates or developments so far?
  • 10,594 Answers
If you have little experience in TV repair, unplug TV from AC outlet, open its back cover and replug TV and power up it. Try to guess where is noisy fan located. Once you pointed out what fan is cause of noise, again unplug tv from AC and take out noisy fan ( if possible and easy for you) then put few drops of WD40 lubricant on its axis and put back fan.
Replug TV and power up and check noise is there or not. If noise is still there, replace that fan.
Don't forget to handle TV with care as TV has high voltages inside.
Posted on Nov 29, 2008
TV making loud buzzing sound
More sets than you might imagine have this kind of problem---I a regular TV it is usually a transformer that is vibrating hard enough to make the sound---the higher pitched sound is just that--a sound.
If this is a direct view(means not a flatscreen and has a Glass Picture tube it will be either the high voltage transformer or one of several smaller transformers.
This can usually be fixed---seen a few so loud the cats in the house run away.
Let me know model number of set for more information.
On chance it has the high voltage transformer I attach a photo of what that looks like.
May 23, 2012 | Zenith Televison & Video
My 32" Philips LCD TV makes a annoying buzzing
The main cause off buzzing from these sets is the transformers on the psu. This can be solved by sealing the transformers with a sealant spray.
Jan 21, 2011 | Philips 32PF5531D 32 in. LCD Television
Today I bought SONY KDL37EX402 LCD TV. Immediately when I turned it for the first time I noticed an unpleasant sound like a ?buzzzzzz? from the back of the TV. As I worked it for more then 5 hours I...
I'm pretty sure that the buzzing sound is a not normal thing for an LCD TV. I sell Flat Panels during my spare time and it should be as quiet as a CRT types. It is more likely a defect and you should return it ASAP.
Hope this helps.
Oct 23, 2010 | Televison & Video
Hi have a techwood tv 32722hd no sound or a buzzing sound.can you help thanks
Same problem here, only white noise... have contacted TV repair people and will let you know what the outcome is!
Mar 30, 2010 | Televison & Video
Humming/buzzing sound
That could be either the ballast, or colorwheel. Does the sound get louder at the rear of the tv or louder in front. let me know I may be able to help you.
Apr 08, 2008 | Toshiba 46HM95 46" HDTV
Audio static
could be some old electrolytic capacitor or some bad speaker
Mar 14, 2008 | Symphonic ST420FF 20" TV
Buzzing sound from my tv
tv makes a buzzing sound when i turn on the set, than stops.
Dec 10, 2007 | Harsper HP-4200VPM Television
LG LC55 humming/buzzing
Have you tried adjusting the contrast? , have a similar problem with a 42'' lcd and it appears to be related to the contrast setting .If is set my contrast below 90% the buzzing sound stops.
This buzzing sound seems to be a common problem with LG TV's
Nov 24, 2007 | LG 42PC5D Television
Buzzing Noise and TV picture is yellow
Andy, I'm thinking the buzz is from the deflection coil (yoke) on the neck of the tube or the power supply. Probably not the high voltage as you can hear the "buzz". If it's really that annoying, you can take a length of rubber tubing (no metal) and listen to the buzz coming from the chassis kind of like a stethoscope. STAY AWAY FROM THE HIGH VOLTAGE, please. The yellow picture sounds like a blue chroma failure. A tube can be rejuvinated if need be but that's a job for a pro. Hope this helps.
Oct 30, 2006 | JVC AV-27220 TV
Television sound
if you have a converter box hooked up to the tv as well turn the volume down on both devices and bring the volume on the tv up to mid range, then increase the volume on the converter.....one is overriding the other
Mar 27, 2006 | RCA F27628 27" TV
Samsung DLP HL-P5663W 56" TV Logo
Henry  Thomas
Henry Thomas
