Question about Acclaim Bust A Move 2 for Nintendo 64
How to clean an Game Shark 3.2 pak and also an 3.3 pak?
I have an N64 Game called Perfect Dark and would like to know which game shark pak to use for all the cheats, and how to clean them too?.
  • 1 more comment
  • Anonymous Dec 26, 2008
    hiiiiiiiiiiiiiiiiiiiiiiiiiii
  • Anonymous Jan 22, 2009
    im having a problem with having it turn on, the title screen wont show up and the little red number isnt there either, can anyone help?
  • Justin Goldberg May 11, 2010
    As Nobarai stated above, never blow into the cartridges! Also alcohol can corrode. Nintendo recommends in the game manuals to clean the contacts using a more gentle household cleaner like Formula 409 or similar.
  • 57 Answers
A newer pack will be able to use cheats on it.
You can clean ALL your packs AND your game deck by diluting:
A cup of water
and a capful of Rubbing Alcohol
Mix them together, then rub the solution over the contacts of the carts and the game deck with a Q-Tip.
I did this, and I have not needed to blow into the cartridges yet, even though it's been a good 9 months since I've cleaned them.
Posted on Nov 30, 2008
Nothing happens except the number 8 shows up but nothing else happens with the gameshark 2.0
http://www.atariage.com/forums/topic/132541-some-help-with-my-new-gameshark-pro-3-3-for-n64/ Check this site... Check the pins in the cartridge and the game shark... Try with different games... Make sure its clean and making all connections. :) hope it helps.
Feb 09, 2013 | Video Game Consoles & Games
What does an expansion pack for the n64 do? what is its purpose? and are they interchangeable?
I will refer you to a page on Wikipedia that explains it -- but the simple explanation is that the Nintendo 64 Expansion Pack increases the RAM on the N64 from 4MB to 8MB. There were a few games with improved graphics and game play that REQUIRED the expansion pack.
Yes you can remove the Expansion Pak from one N64 and put it into another. However, your N64 will NOT work without either the Expansion Pak or the Jumper Pak in that slot. The original memory card that came in there was called the Jumper Pak which was 4MB. The Expansion Pak was 8MB.
http://en.wikipedia.org/wiki/Nintendo_64_accessories#Expansion_Pak
Jun 16, 2011 | Nintendo 64 Console
Nothing happens
is it on the right input channel? either there will be input 1,2 and some times input 3 try cycling through the inputs with the n64 on by pressing the input button on your TV remote
Aug 18, 2009 | Atlus GBA Game Shark for Nintendo 64
Can't play StarCraft - what kind of pack do we need and where do it go in the system
The rumble pak is optional, all it does is shake the controller during gameplay. The expansion pak is required to play the game. It increases the Ram inside the console to 8MB. Some games its is optional, While others it is required.
Donkey Kong 64, Perfect Dark, Starcraft 64, The Legend of Zelda: Majora's Mask all require it for all the feature to be accessable. There may be other games that use it but they do not require it for the most part
May 19, 2009 | Nintendo N64 Expansion Pack for 64
Nintendo 64 Transfer Pak...
Try cleaing the contacts on the games and the transfer pak itself, look up how to clean games on youtube.
Jan 27, 2009 | Nintendo 64 Console
Nintendo 64 Pokemon Stadium Transfer Pak Error
Its most likely the controller. When you put in the pack is it loose? You could try cleaning the GB game and trying again.
Jan 26, 2009 | Nintendo 64 Console
Kirby 64 won't hold a save file
The battery inside the game pak has died, thus, it can no longer hold a save.
Buy a special screwdriver for n64 Game Paks. Unscrew the casing, then find the battery inside the Pak. Take it (the battery) to any store that sells watches, then ask for a replacement for that battery. Plug the batery (+ side facing you) in the Pak, then screw it back together.
Your game should now save. :)
Nov 22, 2008 | Nintendo 64 Console
N64 game Pak
It's not too hard, remove the "Do not remove" sticker first. Then take a flat head screwdriver and put it in the notch where the cover clicked in on the top and just pop it out. Here is a guide with pictures (although they have the official tool, a screw driver works just fine.) http://www.nintendo.com/consumer/systems/nintendo64/hook_expansionpak.jsp
Aug 30, 2007 | Nintendo 64 Console
Nintendo 64 expansion pak
Barb3: The Jumper Pack (JP) is a bypass for the expansion cartridge. You were supposed to turn off the equipment remove the JP and then use the expansion cartridge. Your N64 Ram it's probably gone for good. Is either replace the RAM, which is hard to find or replace the N64. Sorry for that.... SithPitt
Jul 03, 2007 | Nintendo 64 Console
Acclaim Bust A Move 2 for Nintendo 64 Logo
840 people viewed this question
Top Acclaim Video Game Consoles & Games Experts
Tony
Josh Whitehead
Josh Whitehead
Colin Stickland
Colin Stickland
Are you an Acclaim Video Game Console and Game Expert? Answer questions, earn points and help others
