Home | Dell | W1700 17 in. HDTV-Ready LCD Television | Dell W1700 picture wen...
Dell W1700 17 in. HDTV-Ready LCD Television
Problem for Dell W1700 17 in. HDTV-Ready LCD Television
Dell W1700 picture went out. Still have audio.
By n_bastian on Nov 29, 2008
I'm attempting to take the back off of the set but am stuck. I can't seem to find screws that hold on the back panel. I tried finding the schematics of this tv online but to no avail.
Do you know how to remove the back of this tv so I can attempt to swap out the inverter?
Also, is the inverter the same as the backlight? How do I differentiate which is at fault?
Thanks,
Neil
Clarification Request
Posted by Usabigrhammr on Feb 03, 2009
Ok, is there a link so we can see the pictures mention?
Thanks
How can we see the photos?
thanks
Same Problem
Feb 19, 2009
-   how do you get to the part on slowly tilting the chassis because I can't find the screws. Whenever I try to lift it it, I lift the screen also. -   ahchang
Dec 12, 2008
-   I have the same problem....from where do I order and how much is the invertor....-   Guest
Nov 30, 2008
-   DELL W1700 screen is black. I have sound. -   godell1
Best Solution
posted on Dec 23, 2008
Helpful)
thomasjbush
Rank: Apprentice
Rating: 88%, 4 votes
I have just did this here is the solution for you:
MoniServ, Inc.
http://www.moniserv.com
Tools:
Philips screw driver
Small Flat screwdriver
that’s all!
Preparation:
Make sure your desk is clean and you also need a piece of soft clothes because you need
to place your LCD Monitor face down.
How to open the back cover:
First, remove all screws on the back cover, then, use a small flat head screw driver to
push down
the plastic Clip inside the LCD Monitor star at the bottom of monitor. Then you can easily
separate the front bezel and back cover like the photos shown below.
Backlight Inverter Installation Procedures for Dell W1700
Place the Monitor
Face Down
Push This Plastic Button
Down and Remove
Swivel Base as shown
on Next Photo
Remove these
screws
Star at the bottom of monitor as
shown on photo.
Use a small flat head screw drive
to push down the plastic clip.
Do it one side at the time as
shown on next 2 photos
When you have unlocked all 4 sides of plastic clips, Place the monitor face down again
as shown on photo
Slowly tilt
upward from
left side of
back cover
Disconnect this cable and
remove back cover
Remove two
screws and Pull
out this small
circuit board
Disconnect Speaker
cable and remove
the tapes
Disconnect
Backlight cables.
Remove these screws
on the both side of
Panel
Caution!!!
Slowly tilt upward the chassis and disconnect the flat cable
between Chassis and Panel As shown on next 2 photos.
Holding the chassis upward and
Use small flat head screw drive
to unlock this plastic clip
Slowly pull it out
Remove defective inverter board and replace with our New Substitute Board
(T501045.00MSS) and re-install all disassembly components back. Now your LCD
Monitor working again.
MoniServ Substitute Board is available at
http://www.lcdpart.com/Products/t50104500mss.html
Backlight Inverter board.
Photo Shown with our Substitute Board
Remove 4
screws and
disconnect
this cable
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Dell W1700 17 in. HDTV-Ready
Questions and Unsolved Problems for Dell W1700 17 in. HDTV-Ready
Do you recommend Dell W1700 17 in. HDTV-Ready LCD Television?
Answer
Answer
My monitor is all black, no picture. I checked all the cables and power inputs. I tried it on... (More)
Answer
hi evey time i turn my dell w1700 off it keep coming back on .i check the adapter the volt is only... (More)
Answer
self-test feature check staying on after installing new backlight inveter
Answer
power button is on, but it does not show anything on the screen, We plugged it into the cable line... (More)
Answer
Dell W1700 no screen no audio but power light is on from green to amber.
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dell W1700 17 in. HDTV-Ready...:
Top Flat Panel Television Experts
Rank: Guru Guru
Solutions: 1493
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Flat Panel Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
