Question about PfaFF Creative 7570
Timing adjustment on pfaff 2056 (not 7570)
I emailed you a couple days ago and described a timing problem I was having on my Pfaff performance 2056.  I tried the link you provided via FixYa and was unable to connect thru it.  Coincidentally my timing issue rectified itself.  I have no idea how it did this and this isn't the first time it has done this.  I would still love to get instructions on how to adjust the timing.  My email is elsje@columbiawireless.ca
Thank you sincerely for your time, Elsje
  • cout May 05, 2009
    I have the same problem- the timing is off. The needle hits the bobbin casing and gets stuck. I can twist my bobbin casing around but can't seem to get the timing right. Thanks for any help! Oh and my machine is a Pfaff Expression 2036
SOURCE: I need service manual for pfaff 7570
also need this manual
TIA
sarah
Posted on May 01, 2008
SOURCE: 7570 connection
I have Windows Vista; I also had a similar problem; found out that I could only use the usb port on my computer exclusively for sewing as the driver software seems to conflict;
Also, having said that, go to Pfaff.com & download the free driver upgrade and see if that will get you started good luck deb
Posted on Jul 01, 2009
SOURCE: Pfaff 7570 connection to new XP laptop
I bought a 25 pin female RS-232 to USB cable from a computer repair store. It works great. You will have to install the software that comes with it so the computer will know that it is a serial port.
Posted on Jul 03, 2009
  • 632 Answers
SOURCE: PfaFF 1222e timming is off
Setting time isn't as simple as it sounds. You'd have to follow a checklist first before you can do the setting. I could tell you but it is just too long to upload and don't know how I can post the img's. So my best advice is to buy the factory or generic repair manual.
Posted on Aug 28, 2009
  • 5 Answers
SOURCE: connect PfaFF Creative 7570 to a PC
The software you need to connect the Pfaff 7570 to the PC and to create your designs is called PC-Designer version 2.2 from Pfaff. You may be able to find a used copy. The software should come with a dongle (special cable) for connecting the machine to the PC. Make sure you have this piece because it will not work with an ordinary cable. Depending on what type of port you have on the PC to connect to, you may also need an adapter since the dongle has an old style connector on the end going to the PC. If you are going to create your own designs, you will also need a storage card which inserts into the machine that you send the designs to. Pfaff makes one, called the creative card. I have also used a generic card meant for the pfaff; the generic card is less expensive and has a greater capacity. You can find many designs online either free or for sale to send from PC to Pfaff as well.
Posted on Dec 15, 2009
Pfaff quilt expressions 4.2- thread jam error but there is no jam
THe Pfaff QE4.2 is a nice machine. You must be sure you are using it correctly. Damage to the machine can result if you are not following the operation manual correctly.
If the bobbin is dropped in spinning in the wrong direction, birds nesting will result. If you have poorly wound bobbins the machine will perform very poorly. If you try to use the incorrect bobbins you have trouble. This machine may need to be cleaned serviced, and adjusted to factory specs to perform to expectation.
I use a Pfaff Performance 5.0 I used to have a QE 4.0. SUper nice machines!
Cheers,
Embroidery Services
San Diego, CA
Sep 14, 2017 | PfaFF Sewing Machines
What size bobbin for a pfaff creative sensation
Bobbins (10pk), Pfaff #820921096: Sewing Parts Online
www.sewingpartsonline.com > Pfaff Parts > Creative 2.0
  1. Cached
  2. Similar
Product Details. Guaranteed to fit Pfaff Sewing Machine Models: Group J: creative sensation, creative sensation pro, creative performance, creative vision, ...
Pfaff - creative sensation™ pro
www.pfaff.com/en-US/Machines/creative-sensation-pro
  1. Cached
Now your PFAFF® creative sensation™ pro can embroider faster than ever ... needed to achieve perfect balance between the needle and bobbin threads.
Pfaff - Accessories
www.pfaff.com/en-US/Accessories?page=5
  1. Cached
Results 161 - 200 - Revel in a wide range of PFAFF® accessories .... blue bobbins for sewing, embroidering or experimenting with the creativeBobbin Case. bobbin for pfaff creative sensation Google Search
Dec 31, 2016 | PfaFF Sewing Machines
Pfaff problems
Hi... Here is a link to the Instruction Manual: http://www.manualowl.com/m/Pfaff/performance-5.0/Manual/352216
I assume your using the correct stitch program, needle and 'foot'. Does the machine work correctly using the above with less thick material? In other words is the problem purely to do with material thickness?
Regards
Joe
Jun 12, 2014 | Sewing Machines
My 7510 says "adjusting pattern" 248 when I turn
I had this problem a few weeks ago. A new baseplate fixed it. You will need to take it to a Pfaff repair shop
Mar 27, 2011 | PfaFF Creative 7570
The memory board went out on my 2000 tiptronic 6270 a couple years ago. now the machine won't sew at all. the sewing light comes on, but not the lighted digital readout area. so , no sew. how do i...
There is a fuse in the the base plate
that has probably blown. It is soldered in and needs to be fixed by a Pfaff dealer on someone with access to the fuse. If you have the work done, make sure they replace a certain reisitor on the base plate at the same time to prevent this from happening again (per Paff). Sorry for the inconvenience, hope you are back to enjoying your Pfaff machine real soon.
Aug 01, 2010 | PfaFF Tiptronic 2030
Sewing Machines Logo
418 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
