Question about Kenmore Washing Machines
Machine fills with water, then stops
Machine fills with water,then stops
  • 121 Answers
There is a switch on thr lid that will stop it from going on
Posted on Nov 29, 2008
New Samsung Top Loader13kg WA13J571 Wobble Techn,used for the 1st time-water level 1(LOW)still filled the WHOLE machine with water.Bigger load on level5(FULL)never stopped filling with water.
use the features fuzzy logic, u only need to power on and start on the machine when u hve fill in the tub with cloths and soap. water will fill in according to the load filled.
Sep 08, 2017 | Samsung Washing Machines
My samsung top loader washing machine sw65v9w won't stop filling with water
If the water stops when you stop the cycle, then the pressure sensor is at fault. If you need to turn the water supply off to stop it, then the water inlet valve is at fault.
Nov 04, 2012 | Washing Machines
Water does not stop filling with water
The possibility is faulty water inlet valve.The valve lets the water to enter the machine.But if this valve is got weak/faulty then it will not stop the water from entering.If the water fill vale is checked ok then other possibility is faulty water fill valve switch.The switch detects the required water in the washing machine and shuts the fill valve off,but if the switch is faulty then it will not shut the water fill valve off and this will not stop the water from filling and this overfills the water.So most cases the water fill valve is faulty and it has to be replaced.But if the fill valve is checked ok then other possibility is faulty water fill valve switch. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. To get required parts ,you can get it from www.repairclinic.com . Keep updated if any more queries.Thanks.
Oct 14, 2010 | Kenmore 24032\24036 Top Load Washer
Machine does not stop filling with water. Will
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
Sep 30, 2009 | Washing Machines
GE wcxr1070a washing machine. fills with water
Check the water level switch and the plastic tubing to the switch.
Sometimes soap scum stops up the plastic hose and the water level switch does not close to send power to the timer.
If the plastic hose is good and the water level fills and stops replace the water level switch.
Mar 21, 2009 | GE WCXR1070A
Doesnot stop filling water
To javed_iqb904, does the drum actually fill or does it seem like that water is draining out as it's filling?
To neonllama19, if it fills with the tap on and the machine off, it sounds like a defective water valve. If it never stopped filling it sounds like a defective pressure switch or hose to the pressure switch is loose or diconnected.
Jan 08, 2009 | Frigidaire GLTF1670A Front Load Washer
Water doesn't stop filling
If you turn power off to machine (or unplug) and washer continues to fill, you need to replace the water inlet valve. (the part the hoses connect to) If cutting power stops the water fill, you have a problem with the water level switch or the tubing leading to it.
Oct 28, 2008 | Whirlpool Washing Machines
Washing machine trouble
You need to replace the water level selector switch. You can check the part at repairclinic.com
Jun 27, 2008 | Washing Machines
Washing Machines Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
