Hi. My problem is that I can not use the internet with my laptop. We have a router/broadband and all of my flatmates can use the internet, even those who have Vista. I first thought it was because of Vista because I have it as well. My laptop is brand medion. It is said that it is error 815. My laptop is german, the broadband irish. maybe that is the problem. Don't know.I'm desperate. Help me please!
    Champion:
    Scholar:
  • 209 Answers
I've found on a forum that the error 815 means that your Internet Service Provider server is not responding. You have to check your connection's settings (username and password for your ISP, DHCP config). And, see if the connection by default is the right one (not the dial-up), in Tools, Internet Options, Connection Tab and select Never dial.
Posted on Nov 29, 2008
  • Elise Lacoursiere
    Elise Lacoursiere Nov 30, 2008
    I guess you had already done that! Please, let me know.
My laptop and my iphone indicate that my wireless-g broadband router is putting out a wireless signal; but neither accessory works on the network, even though the bars are entirely full on the devices.
The bars on your laptop or iPhone means that you are connected to the router! Not necessarily to internet. Your internet depends on ISP Internet service provider and modem which connected to your router. To check if you have active internet connection connect your laptop directly to modem provided by your ISP with ethernet cable and try to open a internet browser IE or Safari or Chrome or Firefox and open a webpage! If you are able to connect internet by this mean you have internet connection active. Now disconnect your lap top from modem and connect modem to your Linksys router using WAN port of LINKSYS! Its good to power off and power on (power cycle) once on modem and router to make it work!
good luck!
Sep 14, 2011 | Linksys Wireless-G Broadband Router
No internet with wireless laptop
may i know whats your router model and also your laptop, the OS that has been installed also there.. and add more info regards to your problem.
thanks
Oct 29, 2008 | Linksys Wireless-G Broadband Router
How do u hook up ps3 online usin broadband card and laptop
Hi, The PS3 has a built in wireless card. You need a broadband internet connection& a wireless router for it to work this way.
What hardware do you have? You wont be able to connect the PS3 to the internet if you only have a laptop with a wireless broadband card. this is to be used for one PC/laptop at a time. Sorry
you could query this with Verizon though i am sure they would agree, that it is to be used for one PC/laptop to access the internet.
Thanks
Dec 21, 2009 | Sony Playstation 3 (PS3) Console
Just set up my g broadband router. Unable to connect to internet
Your laptop may not support g wireless. Change the wireless to broadcast B and G
Nov 15, 2009 | Linksys Wireless-G WRT54G Router
Will not detect a connection to internet
hi
instead of connecting the cable from the modem to the Internet port on the router connect it to one of the ports numbered 1,2,3,4 and hopefully it should connect
also check the channel at which the laptop and the router are communicating
also check the ip range that the router is adjusting itself to
hope this helped
cheers
PS: if this was anybit useful pls rate the solution, thanks
Jun 26, 2009 | Linksys Wireless-G Broadband Router
Laptop finding router but no internet connection
If you can connect directly to your virgin Media Broadband and get internet then your laptop and broadband router is fine.
The wireless router appears not to have a DNS entry and you will need to add that manually.
I suggest that you connect directly to the Broadband modem, be sure you can get onto the internet. Once you have confirmed you can get onto the internet you need to get the dns information from your Broadband modem for later.
once connected directly to the broadband modem, click start>run> then type "CMD" then click open. you will get a prompt type the following and record the DNS Server ip addresses.
"ipconfig /all" then hit enter
this will display your ipaddress information but mostly you need the DNS server ip addresses.
once you have recorded them rerun the install, but this time instead of at the end of the install where it shows the Wireless router information you can modify or change it and add the DNS server entries.
Also by default most wireless routers ip address is 192.168.1.1 and you can type that from a internet explorer and change it from there as well. I believe it's no ID or user name and the password is admin.
Good luck
Jan 28, 2009 | NetGear WGR614 Wireless Router
Hi, I have an old acer laptop and my wife communicates with me on it using broadband and a router with a usb pick up. I have returned home and have a new acer laptop with wireless LAN already installed. It...
Youe broadband router is working ok with the broadband cable.So it is configured with the broadband cable.Now,to work with the wireless internet,you have to configured the wi-fi router to work internet.You can see the wi-fi connection but unless & untill you will configure wi-fi router it must not work or if before it was working with the wi-fi then you can check the wi-fi router setting because it might change by mistake.Surely it will work after configurating wi-fi router.
Jan 03, 2009 | Computers & Internet
Check to be sure that your network connections are set to automatic(control panel->network connections then right click on your wireless connection go to properties- tcp/ip click on that and check there.
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
