Question about Proview PL926WBi 19" LCD Monitor
Streaks make letters fatter every 2 inches apart across screen
Looking at sentence's all across the screen, the letters every 2 inches apart from top to bottom of the screen are darker and fatter across the screen from left to right. The fatter and darker letters are approx 3/4 inch wide.
Only had the monitor for 18 months
FV926w
  • 558 Answers
This is called phase it can be set auto by the button or you can disconnect the power and next day reconnect and leave it in default which can be better than letting the monitor try to set the phase.
Posted on Mar 21, 2009
2 Suggested Answers
skotkolr
  • 558 Answers
SOURCE: darker fatter letters every 2 inches apart from top to bottom
it is called phase you can attempt to let the lcd monitor auto set or you can disconnect the power over night then plug in and then do not auto set this default usually seems best some times
Why my seiki 32 in has 2 inch line going across top
on the remote look for a button called apex and push it 3 times while looking at the black part od the set.
Terry
Jan 16, 2015 | Seiki ki SE32HY10 31.5-Inch 720p 60Hz LED...
Shadows on monitior
This sometimes occurs when the machine gets too hot. If your graphics card is too hot, its performance will suffer. Check the fan speeds/ temperatures and see if that helps.
Dec 12, 2012 | Samsung 22" TFT SYNCMASTER P2250 LCD...
I'M HAVING BRIGHT RED BOWED STREAKS ACROSS THE SCREEN AND DOUBLE VISION LETTERING
Sounds like a convergence problem. This means 2 Chips need to be replaced by a qualified tech.
N Sabre
Nov 08, 2009 | Akai PTH5498 54" Rear Projection...
Red and blue streaks across the screen top and bottom
The Convergence Amp IC's are bad. You should call a good TV Tech for this repair.
Jul 11, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Darker fatter letters every 2 inches apart from top to bottom
Nov 29, 2008 | Proview PL926WBi 19" LCD Monitor
Red line convergence problem on KP-57WS510
Yes replacing the ic's should solve it. It worth a try if you want to spend the money
Jun 02, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
Red line across top half of screen
Uh-Oh.. Sounds like the BGA RAM in the video circuit. (These units are Intel based and Core 2 duo if posted correct).. We can repair if you need help and its under warranty and sorry its not a home remedy situation..
ikenfixit.com
Jan 17, 2008 | Apple MacBook Pro Laptop Computer with...
JP J5780 Streaks in the rollers and ink
THE FIRST PROBLEM IS DUE TO DUST PARTICLES IN THE TOP SCANNER ASSY,SO TRY TO OPEN IT N CLEAN,SECOND PROBLEM IS RELATED TO CATRIDGE
THNX N
Jan 11, 2008 | HP Officejet J5780 All-In-One InkJet...
Blue haze around image, yellow streak
the tv color circuit is off frequency change the color ic take a look on the crystal that gives the 4.8.mhz burst could be that it needs to be replace dont rule out the video IF change the two ICs you mention.good luck.from the look of your tv screen that is my conclusion.good luck.email me at nicodhem@yahoo.com
Apr 04, 2007 | Samsung HC-P4241W 42" Rear Projection...
Proview PL926WBi 19" LCD Monitor Logo
81 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Pawan Ambastha
Level 1 Expert
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
