Question about Westinghouse WST3501 Microwave Oven
Locked with the word CHIL on the display
I unplug the microwave dor 5 minuto to clean the counter and now is locked, doent start and the word chil is on the display I tried everythig.....what can I do...? thank you I have a West 3501, model 033497
  • 3 Answers
Press the Stop/Clear button several times in a row. This should clear the error.
Posted on Dec 28, 2008
Cannot unlock the display panel
Elise,
So I'm understanding that the lock icon stays on no matter what you have tried. I would try pressing and holding the START/STOP button for 5-10 seconds to see if it changes. I don't know how long you've been leaving it unplugged for when you do unplug it, but i would suggest at least 3-5 minutes. If these don't work what I would do is either contact the manufacturer or maybe even a local authorized technician. This way they would be able to assist and possibly have some more suggestions or be able to find and solve the issue for you.
-Best regards-
Jan 16, 2014 | Frigidaire FFMV164LS 1.6 Cu Ft 1,000 Watt...
I have taken the cover off my Samsung re1200 microwave for cleaning and now the digital display is locked after I have put it back on and switched it on..! Any ideas? Richie
Some fluid must have dripped down on the keypad control board while you were cleaning, or there was a static discharge that locked the display. Unplug the microwave oven overnight in a attempt to get the microprocessor ic to reset, hopefully this will cure the problem.
Apr 09, 2012 | Samsung Microwave Ovens
My smh8165 microwave stopped working and the display says "SE" and is less then a year old
Unplug microwave. Remove (2) flat head machine screws on the top of the microwave holding in the top front trim. My trim slid left and gently pulling was removed. The control panel has (1) screw holding it in. Remove screw, slide up and gently pulling detach from microwave. There are (5) electrical disconnects which need to be disconnected. Do not force they should come easily. Lay control panel on and old towel. Squirt both the male and female connections(in microwave control panel opening) with electrical cleaner. Carefully clean up excess. Connect the (5) quick disconnects and carfully fit back in the control panel opening. Attach screw. Place top trim in and slide right to lock. Once it is in secure the top two screws. Clean area and plug back in. Hopefully your up and running. These pieces break real easy so don't force anything.
May 26, 2011 | Samsung Microwave Ovens
I self cleaned oven and at end f cycle the dor is still locked and the touch pad for the oven is not working. The microwave touch pad is working fine. I tried to rest breaker but the problem did not go...
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Apr 30, 2011 | Microwave Ovens
I have accidentally locked my microwave oven (profile performance convection oven). I was cleaning the front. Can you tell me what to do?
Got you covered. Here you go:
Microwave - Explanation of the Child Lock Out Feature
Many microwave control panels can be locked to prevent accidental use or access by children.
There are two different ways to lock the control panel:
1. Press and hold the CLEAR/OFF pad for 3 seconds. The display will show "LOCK" and then revert to the time of day.
A small "L" will appear in the corner of the display as a reminder that the control panel is locked. If anyone tries to use the microwave, the display will show "LOCK".
2. On some models, press and hold the 5 and 7 pads simultaneously for 3 seconds.
To unlock the control: Repeat the procedure which was used to lock the control. (Press and hold the CLEAR/OFF pad for about 3 seconds or hold the 5 and 7 pad simultaneously for 3 seconds.)
That info is from GE
Hope that does the trick.
Regards, Farmerbear at FixYa.com
Sep 13, 2010 | General Electric Microwave Oven
Lock function reset for model JMV8208BAS
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes. Then let us know if the hard reset does not fix it.
The owner's manual is online here and it covers the child lock:
To set the child lock.
Touch and hold
ENTER/START
pad more than 3
seconds. CHILD
LOCK ON will
appear in the display
window with two
beeps.
To cancel the child
lock.
Touch and hold
ENTER/START
pad more than 3
seconds. LOCKED
will disappear and
you hear two beeps.
Aug 18, 2010 | Jenn-Air JMV8208BAS Microwave Oven
Display on my westinghouse microwave says CHIL it wont work now
hello,
what you are to do to fix up the problem is that,put iff the the oven for some time and allow it to relax it self with out an operation, then put it on again then if it has time programming or reset button then click on an of this button for it to restart it self ,
but if this problem remain then you will have to open the the oven then trace the wire down to the panel to clean up any from of dirt or liquid around the panel then couple it back at it was with this the problem will be solve.
thank you and thanks for using fixya.
Jun 14, 2010 | Westinghouse WST3504 Microwave Oven
How do I unlock the key pad? The display shows locked and I don't know how it locked.
Here you go.
The Child Lock shuts down the control panel pads to prevent
unintended use of the microwave oven.
When the control is locked, only the Vent Fan and Light pads will
function.
To Lock/Unlock Control: The microwave oven and Timer must
be off. Touch and hold START for 5 seconds until 2 tones sound
and a lock icon appears on the display. Repeat to unlock and
remove the lock icon from display.
May 10, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Hello, I have west3501, I unplug it for 5 minute and now is locked with the word CHIL on the dispay, the model is 033497, I tried everithing....thank you
The owner's manual will cover how to turn the Child Lock on and off.
If for some reason you do not have your manual, I would contact Westinghouse Small Kitchen Appliances at 800-245-0600 or 800-947-3745 or visit here.
Nov 29, 2008 | Westinghouse WST3501 Microwave Oven
Bosch HES435U - Stove Keypad is Locked
Locking or Unlocking the oven control panel
1. Access Select Function Menu
2. Turn knob clockwise until Lock Keys is flashing
3.Touch Start. Key Pad locked is displayed.
4. To unlock keypads, touch cooking mode and hold for 5 seconds. Display will read unlocking key pad
5. When unlocked the clock will again appear in the display.
Apr 29, 2008 | Bosch HLK4525GB Convection/Microwave Oven
Microwave Ovens Logo
231 people viewed this question
Top Westinghouse Microwave Ovens Experts
William Miller
William Miller
SHARCNET-USA
SHARCNET-USA
Jaime Hernandez
Are you a Westinghouse Microwave Oven Expert? Answer questions, earn points and help others
