Question about Logitech QuickCam Orbit Personal Web Camera
Logitech drivers causes system error using XP. LVckap.sys
Stop 0X000008E ( 0XC000008F ) ( 0XAA373FF5 ) ( 0XA90AB4AC ) ( 0X00000000 ) LVckap.sys AA373FF5 base at AA34F000 Occurs when using camera with Yahoo messenger, especially with more than two paticipants in the conversation. Originally went into auto re-boot before BIOS changed to cause error halt.
  • Bren Brown Jan 23, 2007
    thank you for your help
  • 3 Answers
I have a Logitech Quick Cam and it is running version 10.5.0.1096. Still has the same BSOD problem.
Posted on Feb 23, 2007
Disable EAC sound in audio settings of camera settings
Posted on Feb 21, 2007
Wait until end of this month, Locgitech will release a new software. Somer
Posted on Feb 19, 2007
    President:
  • 2,961 Answers
View this site for possible solutions http://forums.logitech.com/logitech/board/message?board.id=quickcam_software&message.id=518
Posted on Jan 20, 2007
Fix error 651 on windows 7
In windows 7, when you try to connect using your PPPoE connections, you may be faced with the following error: Error 651: The Modem (or other connecting device) has reported an error.
These connections would work just fine with Windows XP or Windows Vista PCs.
Again, you are not alone, this seems to be a known bug in Windows 7 that is being worked at. However, you can workaround this problem.
The RAS PPPoE driver file "raspppoe.sys" found under c:windowssystem32drivers folder seems to be the root cause of the problem. Fortunately, we can workaround the problem simply by renaming the original raspppoe.sys file to something like "raspppoe_orig.sys" copying a working file from a Windows Vista system. If you do not have access to a Windows Vista system. click here to download raspppoe.sys file (unzip). This should help!
Jan 01, 2011 | Computers & Internet
Wireless not working pc told me error 651
The RAS PPPoE driver file "raspppoe.sys" found under c:windowssystem32drivers folder seems to be the root cause of the problem. Fortunately, we can workaround the problem simply by renaming the original raspppoe.sys file to something like "raspppoe_orig.sys" copying a working file from a Windows Vista system . If you do not have access to a Windows Vista system. click here to download raspppoe.sys file (unzip)
DO VOTE ME
Dec 07, 2010 | Computers & Internet
My computer wont start? error occurs "system32/drivers/isapnp.sys", when i try to reformat my pc, in windows set up, kernell debugging part it will stop and says PCI.sys is corrupt. i cannnot finish...
Try this, when you start your next reinstall dont format right away. first delete the partition and recreate it, after that do your format. You could have a bad sector and formating it is causing an issue.
Aug 11, 2010 | Microsoft Windows XP Professional
I need a driver for the logitech M-RM67A cordless optical mouse
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Ideally you need Mouseware v9.79.3. that’s what came on the CD for my RM67A. I have a M-RM67A transmitter. The date on the actual driver for Logitech is 7/11/2003, v9.79.0.0 (as seen in Device Manager)
If you search for mouse M-RM63 on the Logitech web site, you can download v9.79.1. That may be good enough. Another mouse may have v9.79.3.
For years my RM67A did not seem to work. So I followed these instructions, and it works now.
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=878
If you are still stuck, reply here and I’ll find some way to get you my driver.
Mar 14, 2010 | Logitech Cordless Optical Mouse for...
Initially a gateway pentium 4 with XP got a boot sequence failure with BSOD 0x000024a. left it plugged in for a couple of hours, now the boot sequence fails with a BSOD 0x000021. What next?
STOP error 0x24 means a problem occurred in ntfs.sys, the driver file that allows the system to read and write to NTFS drives. STOP code 0x00000024 may also display "NTFS_FILE_SYSTEM" on the same STOP message.
Seems your hard drive is experiencing problems causing this error to occur.
Feb 16, 2010 | Gateway 400VTX-3501335 Notebook
I get a stop error message when I try to install windows like this stop: 0x0000007e pci.sys
the error that you are getting is caused when you use an old Windows XP CD without service pack 2 integrated. If you want to install XP on to the new system you must use an XP CD that has service pack 2 integrated.
Nov 16, 2009 | Dell Inspiron B130 Notebook
Continuous BLUE SCREEN after sp2 install.
After you upgrade your computer to Windows XP, you might receive the following Stop error message when the computer starts: STOP: 0x0000007E (0xC0000005, 0x804E518E, 0xFC938104, 0xFC937E04)
SYSTEM_THREAD_EXCEPTION_NOT_HANDLED
WUSB54GCx86.sys- Address 92D89498 base at 92D7c000, Datestamp 45c04cc9 Note The parameters and file names in this error message might vary, depending on the cause of the Stop error. The file name in the second line of the error message, WUSB54GCx86.sys, is an example of a driver file that might be causing the error.
This article discusses seven methods for resolving the problem. The first method is designed for beginning to intermediate computer users. The other six methods are designed for advanced computer users.
Because this article contains steps that involve restarting your computer, you might find it easier to follow the steps if you print this article first.
CAUSE
This issue might occur if a system thread generates an exception that the error handler does not catch. This exception can be caused by any of the following: • If this issue occurs after the first restart during Windows Setup or after Setup is complete, the computer might not have sufficient hard disk space to run Windows XP. • The computer BIOS might be incompatible with Windows XP, or it might have to be updated. • The video adapter drivers might be incompatible with Windows XP. • A device driver or a system service might be damaged. • If the issue is associated with the Win32k.sys file, it might be caused by a third-party remote control program.
Use the Windows Error Reporting tool loadTOCNode(2, 'resolution'); You can use the Windows Error Reporting tool to send information about the error to us and to obtain information about any available fix or workaround. Follow these steps to use the Windows Error Reporting Tool: 1. When the Windows Error Reporting window pops up on your computer, click Send Error Report to send the error report to us. 2. In the confirmation window that appears after you send the error report to us, click More Information. This helps you find any available fixes for the problem or information about how to work around the issue. 3. If a fix or a workaround is not available, you can use the "Advanced Troubleshooting" section to try to resolve this issue. If you are not comfortable with advanced troubleshooting, you might want to contact Support. For information about how to contact Support, visit the following Microsoft Web site:
Method 1: Make sure that you have sufficient hard disk space loadTOCNode(3, 'resolution');First, make sure that you have sufficient hard disk space. The Stop error can be caused by insufficient hard disk space.
If you can use safe mode or the Recovery Console to start the computer, delete any unnecessary temporary files, Internet cache files, program backup files, and files that contain saved file fragments from disk scans (.chk files). You can also install Windows XP on another hard disk that has more free space.
If you cannot start the computer, go to the next method to update the computer BIOS.
Method 2: Update the computer BIOS loadTOCNode(3, 'resolution');If freeing space on your hard disk did not resolve the problem, the BIOS might have to be updated. Use the hardware and software vendor contact information articles that are listed in the "References" section to contact the computer manufacturer to obtain the most recent BIOS update.
Note When you update the BIOS, you might have to disable BIOS memory options, such as caching or shadowing, temporarily.
Method 3: Disable or update device drivers loadTOCNode(3, 'resolution');If you have updated the BIOS successfully and the problem persists, the video adapter drivers on the computer might have to be updated or disabled. Follow these steps to troubleshoot the video adapter drivers: 1. If a driver is listed by name in the Stop error message, disable or remove that driver. • If the error occurs during the startup sequence and the system partition uses the NTFS file system, you might be able to use safe mode to rename or to delete the faulty driver. • If the driver is used as part of the system startup process in safe mode, you must use the Recovery Console to start the computer. 2. If the Stop error message does not indicate a specific driver, update the video adapter drivers to the latest versions. 3. Disable or remove any drivers or services that you recently added. 4. Check the Microsoft Hardware Compatibility List (HCL) to determine whether the PCI devices in the computer are compatible with Windows XP. For information about the HCL, visit the following Microsoft Web site:http://www.microsoft.com/whdc/hcl/default.mspx
Method 4: Remove unsigned driversIf you have updated the video adapter drivers and the problem persists, or if you cannot start Windows in safe mode, the problem might be caused by a different, unsigned driver. Remove all drivers that are not digitally signed by Microsoft. For more information about how to do this, click the following article number to view the article in the Microsoft Knowledge Base:
316434 (http://support.microsoft.com/kb/316434/) How to perform advanced clean-boot troubleshooting in Windows XP
Method 5: Remove all third-party drivers loadTOCNode(3, 'resolution');You might be unable to determine which third-party driver causes the error. If removing unsigned drivers does not resolve the issue, try moving all third-party driver files from the %Windir%\System32\Drivers folder to a different location. Follow these steps to move the third-party driver files: 1. Use the Recovery Console to start the computer, or start the computer from a different installation of Windows if you have performed a parallel Windows installation. 2. Create a temporary folder to hold the driver files. For example, you could create c:\DriverTemp. 3. Move all files that do not have a creation date for Windows XP of 8/13/2001 from the %Windir%\System32\Drivers folder into the temporary folder that you created in step 2.
Caution If the computer relies on third-party IDE or SCSI controller drivers for correct operation, you must identify those driver files and then leave them in the %Windir%\System32\Drivers folder. 4. Restart the computer. 5. Continue the Windows Setup program. You can add the driver files back to the computer one at a time to identify the faulty driver.
Method 6: Remove third-party remote control servicesIf you still have the problem after you use the previous methods and the Stop error message contains the Win32k.sys file name instead of a driver file name, the problem might be caused by a third-party remote control program. To remove the service, use the Recovery Console to start the computer and then delete the third-party remote control service file.
Oct 24, 2008 | Intel Motherboard
Cant install without service pack 2
Do you have antispam or antimalware software running? mostlikely they removed or didnot let you install the file LVCM.sys which is part of the logitech drivers.
Description: File LVCM.sys is located in the folder C:\Windows\System32\drivers. Known file sizes on Windows XP are 1317152 bytes (50% of all occurrence), 472396 bytes.
The driver can be started or stopped from Services in the Control Panel or by other programs. The program is not visible. File LVCM.sys is a Microsoft signed file. The service has no detailed description. It is not a Windows core file. Therefore the technical security rating is 14% dangerous. Important: Some malware camouflage themselves as LVCM.sys, particularly if they are located in c:\windows or c:\windows\system32 folder. Thus check the LVCM.sys process on your pc whether it is pest.
Jul 12, 2008 | Logitech QuickCam Express Web Camera
Oribcam causing system crash on acer 5630 model with the following blue screen of death error message lv321av.sys as the cause of the issue.
Hello the problem came from the hires of the webcam into the laptop .with the times the hires become old and fragile and if you move in the bad positionthe webcam or the base of the laptop you will crash with the so beautiful (BSD bleu screen of death)
Sorry for my english i am french
yeah sarko land !!!!
Apr 23, 2008 | Computers & Internet
BSOD in windows XP Professional
A stop error occurs when Windows XP Professional stops responding. Stop error messages can be caused by hardware or software malfunctions. The error messages appear on a blue or black background. The following steps, which also appear on the stop error screen, help you find out the cause of a stop error and how to fix the problem. To troubleshoot General Stop Errors: 1. Restart your PC. Unplug each new hardware device, one at a time, to see if this resolves the error. Try to run any hardware diagnostic software supplied by your computer manufacturer. 2. If this is a new installation of hardware or software, contact the manufacturer for any Windows XP Professional updates or drivers you might need. Click Get support, or find information in Windows XP newsgroups (under "Ask for assistance") and then click Get help from Microsoft in the left-hand column. 3. Check the Microsoft Hardware Compatibility List (HCL) to verify that all your hardware and drivers are compatible with Windows XP Professional. 4. If you can start Windows XP Professional, check the System Log in Event Viewer for additional error messages that might help identify the device or driver causing the problem. 5. If you cant start Windows XP Professional, try to start your computer in safe mode, and then remove or disable any newly added programs or drivers. 6. Search the Microsoft Knowledge Base for "Windows XP Professional" and the number associated with the stop error you received. Specific Stop Errors Some stop errors display descriptive messages such as "DATA_BUS_ERROR" that can help you determine the exact solution for the error. This section discusses how to troubleshoot specific stop errors, based on the type of error you receive.
Jun 26, 2007 | Microsoft Windows XP Professional for PC
Logitech QuickCam Orbit Personal Web Camera Logo
1,136 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Damen Wong
Damen Wong
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
