Question about Kitchen Ranges
I have a ge profile dual range stove. The stove sounds off a noise periodically and the letters "FO" show up on the led and renders the stove not usable
  • 121 Answers
The erc -clock faild
Posted on Nov 29, 2008
I'm getting a periodic beeping signal and an "FO" error message from my lower oven. What is it telling me? The oven is a dual electric. Model number 326B1230P001. Thanks. Stanley Hochman
Hi!! Failure Code Fault Code Description Solution F0 Stuck touch pad Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both.
Although the manual recommends to replace the touch pad, try unplugging the unit form the wall for a couple of minutes to reset it. It works most of the time.
Good Luck!! Don't forget to rate this post!!
Sep 20, 2010 | GE Profile JGSP44 Dual Fuel (Electric and...
Buzzing Noise coming from GE Stovetop.
It could be a loose transformer that needs to be remounted. Pull the stove out, remove all of the screws at the top and visually inspect the transformers and wiring. This should be an easy fix, but if you leave it too long then your stove will malfunction. I hope this helps at least get you to the next step.
Jun 21, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Gas stove ignator makes
sounds like you got the electronic ignitor valves wet try blowing them out with air or don't use for a few hours
May 27, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Stove Ignitor makes tik tik sound and the sparks continuously
may be a loose wire on the spark ignitor ceramic or if you run via main electic it may be your spark generator
May 14, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile stove not working
If neither bake or broil ignitors work you must first verify voltage to the parts.
Most likely a defective electronic control.
Feb 05, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE 44xl gas stove (no electrical plug)
I have a gas range GE 44XL it has an electronic ignition on the burners and a glow plug module fo the oven
Dec 02, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE profile gas stove over does not work....F7 D8 on screen
spectra stove and it is beeping and reading f7 we have unplug it and replug please help me
Nov 20, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Our GE Profile Oven is not heating up (stove works)
Please check here for possible troubleshooting steps:
http://www.repairclinic.com/0088_13_1.asp#Level1_2
Hope that helps! Should you have any further questions,please feel free to post them here.
P.S. - If you find that the solution/answerI provided led you to, or resulted in a fix, please close the ticket with a FixYa!rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Oct 04, 2008 | GE Spectra JGBP35 Gas Kitchen Range
GE range stove #317B6641P001
Hi thanks for the question. the problem you are having is with the igniter. it does not get hot enough to work at 100 % . replace the igniter. thanks te appliance doc
Sep 10, 2008 | GE Profile JGSP44 Dual Fuel (Electric and...
Kitchen Ranges Logo
78 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
