Question about Maytag MSD2754G Side by Side Refrigerator
I have a MZD2766GES. I believe I need to replace the ADC unit. How do I remove the light shield so I can get to it? Thanks.
  • 121 Answers
The cover is heid up with clips on the rear corners release them and slide it forward
Posted on Nov 29, 2008
Mzd 2766ges adc board
I have no idea what the tech was thinking! What would a water filter have to do with the unit shutting down?! From what you have described, I would say the ADC is getting stuck in the defrost model. Replace the ADC and you should be good to go. Here is the part to order.
Keep me posted and throw that techs number in the garbage!
Nov 30, 2012 | Maytag MZD2766GES Side by Side...
The refrigerator will not cool. It comes on and shuts off but does not kick in to cool. HELP
The two most common problems on this model were either the relay to the compressor or the ADC (adaptive defrost control) both parts can prevent the cooling for the unit. Relay kit or ADC. I would visually inspect the relay to the compressor with the unit unplugged, smell it to see if it smells burnt, if so replace it. If it is ok, then I would suspect the ADC board and it will need to be replaced.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Oct 09, 2011 | Maytag MZD2766GES Side by Side...
Maytag refrigerator moldel msd2756dew coils are freezing over
There are three magor parts that control the defrost on your model MSD2756DEW Refrigerator. The=> MSD2756DEW Controls are inside the fresh food compartment and behind the controls on the top shelf. In that photo is position 13 That is your ADC or adaptive defrost control part number=> 61005988
This is most likely the reason for not defrosting and causing the evaporator to ice over. The next part is the=> 61006199 Defrost Heater with Defrost Thermostat
sea_breeze_142.jpg Here is a PDF of a Maytag MZD2766GES and it has the same parts as yours so click here=> Maytag MZD2766GES Just use it for illistration or parts. Click here=> Defrost Heater Assembly to see that part and at bottom of page there is a short movie of how to test the defrost heater with an OHM meter. This is not hard to do if you want and I will be here if you need to ask other questions. If you have questions please let me know, Thank You, Sea Breeze
Apr 18, 2011 | Maytag MZD2766GES Side by Side...
MZD2766GES No cooling.Stat(slide) set to call.120v to unit.Lights on.No compressor operations.Manually defrost last few months.
Lets check start relay, run capacitor and thermostat. Also need you to pull away from the wall and unplug, remove cover over compressor and then feel the top of the compressor to see if warm or too hot to keep hand there. Should you need a start relay you will need=> 12002784 Relay and Overload Kit
12002784 Relay and Overload Point and Click Parts If the compressor is cool I want you to check the Adaptive Defrost control=> 12002104 Adaptive Defrost Control Sometimes these parts act like the compressor start relay and stop compressor and fans and even sometimes one or the other. The thermostat should also be checked while unplugged with an OHM meter=> 61005327 Temperature Control Here is a pdf with the locations and should you have any questions I will be here again later, Thanks Sea Breeze
Here=> MZD2766GES
Apr 16, 2011 | Maytag MZD2766GES Side by Side...
How do i put this model into defrost? mzd2766gew
The older Adaptive Defrost Control (ADC) boards - short L1 and TEST pins together (you can use the tip of an insulated screwdriver or short length of wire - stripped only at the ends). Newer ADC boards don't have a TEST pin. You can also force defrost by cycling the Cold Control 3 times within 6 seconds and leave it on COLD (this may work only for the newer ADC without the TEST pins).
Mar 09, 2011 | Maytag MZD2766GES Side by Side...
Maytag MZD2766GEB refrigerator does not automatically defrost leaving coils to freeze over. I have the "little white box timer" (is this what they call an "ADC" automatic defrost control, that sits in the...
to get to the adc board and it is common for these to go out , you have to grab the plastic cover from the very back of the cover and pull towards the front of the unit , you should see the slots your sliding it off , somtimes it is a bear to slide off..
then after that there are phillips screws going into the roof of the unit , you just have to loosen these and slide the entire control section to the right to unlock from cabinet.
you should see the adc now and its a tight squeez to remove and replace , make sure there is no power to the unit.
Let me know if you have any questions.
Phil
Jun 10, 2009 | Maytag MZD2766GES Side by Side...
Maytag side by side defrost problem. I am a tech with a maytag side by side that recently had the recall work done on the compresor relay and now the customer says ref. side is not cooling. Are these...
The ADC has failed and or the defrost thermostat has failed. It has a cal rod heater. They usually do not fail, but check continuity on it anyway. The ADC is in the control panel on the back right corner.
Jun 07, 2009 | Maytag MZD2766GES Side by Side...
Freezer coils keep freezing up.
I had a similar problem with a Maytage Side-by-SIde Model MDZ2768GEW, (purchased in 2001). Defrost not working...poor cooling in both the freezer and fridge. We opened up the back of the Freezing side and the coils were iced. This Model is auto defrost so obviously something was not working. We called a Sears repair office and they sent a guy that told us we needed to defrost the unit. Well...I wasn't home and my father-in-law didn't question it - he defrosted it! I was busy at the time and didn't pursue it until the problem naturally resurfaced a month or so later. Not wanting to haggle with Sears over their Tech's lazy incompetence (or the $100 I was out), I decided to commence troubleshooting. I'm an ex Navy nuke electrician and electrical engineer so this didn't seem to be beyond my ability. Not having the Owners Manual, I internet searched until I found this site: www.servicematters.com/maytag_library/html/index.html. You can download your model's Service Manual and root around for other tech info their. I found the manual for mine and performed the troubleshooting for the Adaptive Defrost Control. Its fairly easy to do and you don't have to empty the entire fridge. You do have to empty the upper shelf in the fresh food (cooler) side to gain access to the controls. --This may not be in the exact order needed but you remove the light shield by pulling down on the back corners of the cover and sliding it forward (slotted attachment - no screws). Next Remove several screws holding the fascia / radiant shield on. Then remove screws that mount the control housing to top of fridge, etc. I also removed two screws that mount the ADC to the plastic housing to get access to the ADC. Basically, remove enough screws to lower the top assembly down to get to the ADC... --You may need to turn off the fridge now (or do it before you started the previous steps but the light helped me). If you are not using a Wattmeter, I don't think you need to pull the power cord. --The Service Manual next says to attach a Wattmeter to the fridge (and assumedly plug it back in). Most people don't have a Wattmeter...but what I had is a clamp-on ammeter...which you can get as part of "better" multi-meters for well under $100. An ammeter is good enough if you know how to multiply voltage and current to get VA (or approximately) Watts. Any idiot can do this...I think. P(Power) = V x I x pf. What you calculate with VxI is Apparent Power (VA). You convert to "real" power (Watts) by multiplying VA x pf. You generally have to guess at pf, but 0.8 for a motor/compressor is a good approximation and 1.0 for a heater or indandescent light bulb is roughly good. Enough electrical basics... --With Fridge plugged in, and being careful not to touch exposed connections, move the ADC control board so you can gain access to it (2 screws were removed previously to loosen it from the housing at top/back right of fresh food side). The ADC is a small printed ckt board about 3" x 3". --Use a small insulated jumper (or insulated alligator clip) and jumper Pins labeled "L1" and "Test". These are labeled on the PC board and were the two left-most pins, side by side, on my ADC. The Manual doesn't say whether to leave the jumper on or not. I tried both ways and I believe all you need to do is momentarily jumper the two pins (but my ADC wasn't working right, which I will get to later)...so I'm a bit unclear on this part. Also - DO NOT jumper between any other pins, or you may damage the ADC, if it's not toast already. The pins are close together so you need to take some care in doing this. --According to the Service Manual, you should read about 500-600 Watts of total power consumption if the unit is in Defrost mode. I found (referring to the electrical schematic), the main red power wire (ty-wrapped to a green/yellow wire that goes to the main lights). Power is red so it's process of elimination to find the "right" red wire. It's not that hard to figure out. I also confirmed this by playing with the door switch light and watching amps go up and down as I pressed & released the door switch. Ultimately, I measured about 2.2 Amps with the unit working normally (cooling) and 6 Amps in Defrost mode...and about 120 Vac supply. So...VoltsxAmps=VA, which equates to 720VA. I don't know what the power factor of the unit is...but with the compressor and freezer fan off, and only the defrost heater and lights on...the power factor would be close to 1.0. So my reading might have been a touch high but...what it did prove is that a) the heater works (I could feel heat off of it and I had the freezer panel removed and saw it melting ice), and b) the thermostat was working. --I also confirmed proper thermostat operation by measuring it "open" with an ohmmeter after the defrost cycle and measuring it "closed" once it cooled down enough (book says ~ 45F thermostat opens and ~15F it closes (to allow defrost when commanded by ADC). --What I found was that when I jumpered L1 and TEST, the Defrost didn't come on...until I manually turned the Freezer control off - and then back on again. Once I did this it started Defrosting (amps rose from about 2 to 6, compressor and freezer fan shut off and heater started heating. I repeated this twice after waiting for the unit to cool down after the defrost cycle. You can also just unplug the fridge to terminate the Defrost cycle and if the temp hasn't risen above the thermostat setpoint, you can immediately repeat jumper testing as necessary. --The defrost heater stayed on for about 5-8 minutes and after a total of 23 minutes the compressor/fan restarted - which matched what I read somewhere - though doesn't match the ADC Instruction Manual - which I show a website for further down. --So it appears the ADC is just not entering the Defrost cycle but does exit it properly. I believe that my problem is the ADC as I proved the heater works and the thermostat (as I mentioned earlier). Other than bad/intermittent open wiring, there's nothing else in the circuit and I believe I ruled out a bad connection by taking the thermostat connector apart several times and jostling wires up at the ADC to gain access. According to what I can find, the replacement ADC for my unit is Part No. 12002495. One should verify the P/N for their particular model. You can look at the Instruction Sheet here: www.servicematters.com/maytag_library/docs/16023486.pdf. It also has some info on how the ADC is supposed to work...NOTE: You should verify this P/N with someone, as I will before I order it. FYI...at Partselect.com, they show a replacement PN (their #) as PS2061226, for about $61. I've seen various prices on different sites and this was pretty reasonable. Lord knows what Maytag/Sears would charge. Maybe add a "1" to the front? ;) PartSelect also indicates different "Series" numbers for the same PS number for the ADC...not sure about which one I have so Buyer beware, make sure you resolve this before ordering -- I still have to. Anyway, hope this is helpful to someone out there in cyberspace. I will have to confirm my P/N and then buy the ADC. If anyone out there, esp pros, have any suggestions feel free to chime in. Except if you are the guy that told us to defrost our auto defrost fridge to "fix" the problem, for 100 smackers no less. You Sir, should be caned 100 times for being a slug. No economic stimulus for You!
May 16, 2009 | Maytag MZD2766GES Side by Side...
Mzd2766ges
its located in the upper right corner of freshfood side. sometimes its hard to get to. remove light shield, then heat shield, then the auto damper housing assy. and then 2 scews holding the defrost board,remove the 4/6 wire plug to board carefully. also unplug refridgerator first. good luck.
Aug 27, 2008 | Maytag MZD2766GES Side by Side...
Maytag MSD2754G Side by Side Refrigerator Logo
115 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
