Reset windows password, I recommend use Windows Password Reset, you can download it then follow the instructions to reset your password, so easy and safe.
Step1:Download Windows Password Reset and install it.
Step2:Burn Windows Password Reset ISO file to CD/DVD,or USB.
Step3:Put in your newly created CD and remove your Windows Password.
It help me reset windows password easily.
Hope this method can help you too.
SOURCE: forgotten password to open tally45
This is a problem the only way to deal with this is to try to input until you can access your computer. Also if it is a Win 7 loaded computer you can look at the password hint section. Also for everyone it is advisable to make a password reset disk in case this does happen. Also you can completely re load your software if you cannot access the computer. This will give you back your operating system.
There is special software programs out there that will crack your password because there is so many of them I would not even attempt to share a link. I also highly recommend typing out the password in small readable print it out and cut it neatly and tape it with scotch tap under the DVD-R or CD tray when you open it right along the edge of the front lip.
Also use a password you will never forget use small caps only. John
SOURCE: i have forgotten password to open tally45 from lenovo think pad
You can reset forgotten Windows password with 3 methods below:
1. Another valid administrator account which can normally log on.
2. A password reset disk or a repair disc, which is created in advance ( before you lost password ).
3. Third-party software to create a bootable password reset CD/DVD or USB, like Windows Password Reset
