Question about NetGear WGR614 Router
Cant connect to internet with laptop
My router box will no longer ci\onnect my laptops
  • 1 more comment
  • Anonymous Nov 30, 2008
    laptop cannot connect to internet
    same problem
  • Anonymous Feb 21, 2009
    I have been constantly losing my connection and now the router is not recognized any longer
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 62 Answers
Well sir in this case just make sure you are trying to connect to your own network , and even after that it's not working then try configuring the wireless setting's on the device.
Following steps will help you out:-
a)Use an ethernet cable to connect a computer to any one of the four LAN ports of the NETGEAR router.
b)In a web browser, enter the router's IP address - either http://192.168.0.1 or http://192.168.1.1 by default.
c)When prompted for a Username and Password, enter the default username and password (admin; password) unless you have already changed it.
d)Select Wireless Settings from the Setup menu in the left-hand navigation bar.
e)ssid:-any name , channel:-11 , mode:-g and b
f)Under Security Options, select WEP (Wired Equivalent Privacy) or WPA-PSK (Wi-Fi Protected Access Pre-Shared Key).
For WEP:-
authentication type should be automatic and encryption strength should be 64-bit.
passphrase:-leave that blank and only select key1 from the list of four keys and in the key1 box type your telephone no. without the numeral 0 in the beginning or enter 10 hexadecimal digits of your choice and apply the setting's.
The number in the key1 box will act as the password to connect to the wireless.
For wpa-psk:-
In the passphrase box enter any password of your own choice between 8 to 63 characters which will be
password to connect to the wireless and apply the setting's.
g)You can also follow this link for the help:- http://kb.netgear.com/app/answers/detail/a_id/112/related/1
Posted on Nov 24, 2009
Laptop cant connect to internet
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Apr 06, 2010 | Linksys Wireless-G Broadband Router
Problem with Acer Emachine and internet onnections!
Sometimes, the order in which u do things makes all the diffference.
1. shut down all machines
2. unplug modem and router
3. plug in just modem and wait for lights
4. plug in router and wait for all lights
5. restart computers
* if your still having an issue and your connection says local connection only then you need to reset the modem and router and then follow the above steps again.
Mar 06, 2010 | Acer Aspire 5100 Notebook
I have a same problem..
check the router interface and make sure that is the ip and subnet you have set for it 10.0.0.2 but you are right if the routers ip is set for 192.168.1.1 the laptop should be also 192.168.1.X
Jul 17, 2009 | Linksys WRH54G Wireless Router
Laptop driver needed
You dont need a driver for the wireless router. If your laptop can recieve wireless signal(from a wireless router) all you need is an active internet connection, configure the laptop and router to distribute the internet, you're good to go.
If your laptop cant recieve a wireless signal from a wireless router then you might need a USB Wifi Dongle.
Apr 06, 2009 | Linksys Wireless-G VPN router with...
Wireless Router No Longer Connecting
Check the LAN cable between the router and the internet modem and try another cable. Obviously rebooting both is orth a try.
The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can set-up form scratch.
Feb 19, 2009 | D-Link AirPlus DI-524 Wireless Router
D-link dir-625 still cant acces wirelessly
If your laptop has a wireless capability you should be able to connect to the wireless network of your router, just view the available wireless network select the wireless name of your router and connected to it if it already say connected try to disconnect the ethernet cable from your laptop and access the internet wirelessly..........
Nov 01, 2008 | D-Link DIR-625 (790069292637) Wireless...
New HP laptop will not connect to wireless secure network
Problem solved. I disabled the security on my network. I connected the new laptop to the unsecure network. I saved the settings on the laptop for the unsecure network. I rebooted the laptop. I re-enabled security on the router. I tried to connect to the network. I got an error on the laptop saying the network saved settings did not match. I modified the settings to a secure network on the laptop and saved the 128 bit key. Rebooted everything. All works fine now.
Sep 06, 2008 | D-Link AirPlus DI-524 Wireless Router
Cant connect to wireless router
Make sure the wireless adapter is enabled on the elonex laptop and its properly installed.
Connect wirelessly on the elonex one laptop using the same SSID and security key that you used on your main laptop.
Aug 07, 2008 | Belkin (F5D7230-4) Router (587009)
Laptop
the internet cable should be connected to the "Internet" or "WAN" port on the router. Your PC should be connected to one of the regular ports on the back of the router and your laptop can be connected just like the pc, or it can connect wirelessly.
Then you should be able to see the internet from your laptop.
Jan 20, 2008 | Belkin (F5D7231-4) Wireless Router
Open Questions:
The Best Unlimited Online Backup and Cloud Storage Services Cloud backup, in simpler language also known as online backup, is a way to backup data by storing a copy of the data over Internet to secured cloud servers. Unlike the traditional ways to store data on local hard drive media the data is stored on cloud servers that are accessible through Internet. Cloud backup technology also help us retrieval of stored data on the go using a variety of devices all connected to the cloud servers. With Cloud backup, end users can upload documents, photos and videos to the cloud and then fetch them at their ease. This helps them save storage space on Server Cloud Backup Solution their computers and mobile devices. Furthermore, the cloud based structure allows end users to upgrade software more quickly - because software publishing companies choose to offer their products via the web rather using traditional, tangible methods that involve discs or flash drives. Top software publishing companies have chosen to turn their business models to subscription based and they deliver their product offerings through cloud solutions. All data is critical for businesses. It's a treasure trove of information. Problem is, they are drowning in it. Datalign provides a lifeline. We provide Cloud Backup For Small Business companies with a unique approach to backup, analyze and organize their data with the use of artificial intelligence Capabilities. Not all data file types should be treated in similar manner. Data may be accessed or stored depending on the requirement of the users; some users may want the data at their fingertips whereas others may want to store it for archival and compliance purpose. To rectify this problem with one solution, we have introduced the world's first Tribrid Backup. Without sacrificing any data, it enables businesses to protect all produced data and save storage costs. Our innovative platform has been designed while keeping you in mind. To provide Online Backup Pricing optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly. Our Cloud services are available on demand and always up and running. We ensure 99.9% uptime for our cloud services. This ensures un-interrupted data transfers and practically no downtime.
Apr 21, 2018 | VIA Computers & Internet
See all NetGear WGR614 Router Questions
NetGear WGR614 Router Logo
186 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
