Question about Uniden TRU8885-2 Cordless Phone
Uniden cordless phones
My phone has two handsets. Both handsets have suddenly stopped working. The speakerphone on the base works. Both handset screens show readouts and if I dial a number the screen shows the seconds being ticked off--but no dialtone or any sound on either handsets. The mute is off. Privacy is off. Everything is plugged in and the charge light is lit when the handsets are on their bases. Any ideas would be greatly appreciated.
  • 6 more comments
  • Anonymous Mar 13, 2014
    The base to my Uniden DCX131 (+2) stopped working and my friend gave me her old base (+2) of the Uniden D1660. Can I pair the DCX131 handsets to the D1660?
  • Anonymous Mar 17, 2014
    uniden cordless handset phone #2 shows handset out of range and searching
  • Anonymous Mar 20, 2014
    i used the handset 2 days ago and then yesterday I looked at the charging base the charge light was not on so I picked up the phone and it is dead any suggestions, this is the only charging base I have
  • Anonymous Mar 24, 2014
    my uniden dect4086 cordless phone clock repeatedly loses time despite resetting and replacing handset battery and base being plugged in constantly
  • Anonymous Mar 26, 2014
    My cordless Panasonic model # is KX-TG6531 and want to switch the base handset *1kitchen to*2 bedroom. Can the *numbers be changed or switched around?
  • Anonymous Mar 27, 2014
    Have pressed find/hs button on base; display shows "paging" and "in-use" button on base lights up. Can't find the bloomin handset; do you have any other suggestions?
  • Anonymous Mar 29, 2014
    how do i delete a handset on the intercom list of my uniden cordless phone
  • Anonymous Mar 30, 2014
    It's been working great up until now. Does it need major surgery?
This sounds like the register-deregister problem elsewhere on this page. Try holding down the "end" and "#" buttons for about 6 seconds to deregister the phones and then reregister them. I had this problem too and it worked for me.
Posted on Jan 21, 2007
Phone says searching
Bring the handset that says searching into the same room as the base and see if the handset stops searching. Next unplug the handset batteries (yes from all handsets) and the base power cord (from both the base and the wall outlet). Wait a few minutes and then reconnect the batteries and base power cord. Next try to de-register and then re-register the handsets. (If you add a comment with the phone model, I'll help you with this step. Uniden has the manuals for their phones on their site: http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=dectphones_mnl .)
If this doesn't help, next try a new battery (and make sure that the battery is fully charged) for the phone. (If the phone is under warranty, contact Uniden. Note: batteries lose their ability to hold a charge over time. This includes the time on the shelf in the package.)
If a new battery doesn't help, then there is something wrong with the handset. Decide if it is worth having the unit fixed if the phone is out of warranty.
I hope this helps.
(I'm assuming that both handsets are cordless. If you have a corded/cordless model, then check that the base has power before you go farther with the above diagnostics. The power brick should be warm. We had a cordless phone on a power strip (UPS) that got turned off. The handset was searching for a signal that wasn't being sent. If you have power to the base, try sending the Find Handset message. The problem could be either the base or the handset not sending and receiving the signals between them.)
Dec 11, 2011 | Uniden DECT 6.0 Cordless Phone
Base handset not working
try taking batterie out reset it 2 min then back in and unplug base might wann buy new battery also for that one
Jan 30, 2008 | Uniden Cordless Phone
How do I turn on my speakerphone for my Uniden EXP4540?
Sorry, Uniden EXP4540 2.4 GHz does not have a speaker phone feature. The cordless phone features AutoTalk™ and AutoStandby™. AutoTalk™ allows you to answer a call by just removing the handset from the base so you don't have to waste time pushing buttons. AutoStandby™ allows you to hang up by simply returning the handset to the base. You can check it's manual with this link http://www.uniden.com/pdf/EXP4540om.pdf.
Thanks for using fixya!
Mar 30, 2011 | Uniden EXP4540 2.4 GHz Cordless Phone
Uniden XS 1210 cordless phone won't connect to base unit
try connecting both phones via the base that is working and see if they recognize each other. Let me know if that works.
Jul 21, 2009 | Uniden Cordless Phone
My phone is dead
Reset Procedure for Cordless Phones
Question:
What is the general reset procedure for cordless phones?
Answer:
1. Disconnect Battery from handset(s)
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect Battery to hanset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base in most instances.
<KEYWORDS="RESET, call,? can?t tone, dial no flashing, unavailable, range, of out working, not up, messed>
May 05, 2009 | Uniden Cordless Phone
I am having problem with my cordless phone.
Another tip is to remove the battery from the handset for at least 5 seconds. You might want to get a voltage meter and check the voltage on that new battery - maybe it isn't charging properly.
Mar 13, 2009 | Uniden Cordless Phone
How to set up uniden phone to base
If the handset has previously worked with the base - press the hangup button and the # key at the same time on the handset for five seconds and follow the prompts to deregister the handset. (System reset - deregister HS - which handset) It will tell you that the handset is deregistered. Then put the handset onto the base and it will register the handset.
Dec 14, 2008 | Uniden 5.8GHz Expandable Cordless Phone...
Dead Uniden DCT5280 Handset
if battery just replace battery but the head sets are compatible with other handsets of same ghz say 2.4 you just gotta set in base and let base recognize new hand set these phones are practically built the same way but only with new technology
May 03, 2008 | Uniden Cordless Phone
ELBT595 Handset Not Turning On
Check the handset battery -- if there is a slight "bulge" on one side (ie: not COMPLETELY flat) then the problem is with the battery. I had that problem and had to order a new one. That said, I just installed the new battery, and while it now charges, the handset won't connect to the base unit. The base unit works (tried the speakerphone), but there is not connection between base and handset.
Feb 18, 2008 | Uniden ELBT595 Cordless Phone
Handset Buttons Stopped Working - Full Battery
Here is a link to Uniden's site, and on the right side of the page, there is a link for a download manual pdf and helpline
http://www.uniden.com/products/productdetail.cfm?product=TRU8885-2
also worth checking if any buttons are stuck, or if the handset is set to pulse rather than tone mode, or if it has had a tumble or knock, possibly the keypad connector has come loose .
Hope this helps.
Sep 17, 2006 | Uniden TRU8885-2 Cordless Phone
Uniden TRU8885-2 Cordless Phone Logo
411 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
