Question about Hoover F7220900 SteamVac V2 Upright Vacuum
Steamvac Hoover Were you able to remove the turbine? I just can't find the way to do it. Can you help? Eddie eddie@dotgoneassets.com
    Brigadier General:
  • 6,966 Answers
I am not sure if you will be able to view my solution in your Premium Problem re: Hoover SteamVac F7222-900. With your indulgence, I took the liberty of posting here a copy of the solution I posted.
A common problem on most versions of Hoover with turbine system especially those that are not often used. Pls reference:
Justa start, do postback how things turned up or should you need additionalinformation. Good luck and Thank you for using FixYa.
Posted on Dec 01, 2008
How to repair the bearing in the brush motor in s Hoover Steamatic
I believe you are asking about the turbine assembly. It runs off suction and powers the brushes. These commonly seize up due to moisture. They seldom can be fixed although tearing it apart and lubing the bearings can be tried. When we get them in for service they almost always get replaced. They come as an assembly.
1. Remove hood.2. Remove turbine.3. Replace or Repair turbine.4. Reinstall hood.
I'll include a link to a picture of the most common turbine.
Good Luck! The Vac Dr.
http://vacuummedic.com/product.php?id=229
Dec 24, 2012 | Hoover SteamVac Carpet/Upholstery Deep...
Were can i find the belt on a hoover steamvac spinscrub the wheels quit spinning on it
There is no belt on the Hoover SpinScrub. The brushes are turned by an air driven turbine. To test the turbine, insert a flat screwdriver into the square hole that the pin on the brush assembly normally fits into, and see if the fitting turns. If it doesn't turn, the turbine has seized up and will need to be replaced.
Jun 20, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Hoover SteamVac brushes aren't turning ...
Sometimes this speed knob can be really stuck on there. Even if you were to break off the part that the knob sits onto, this part is actually part of the turbine assembly, and the new turbine assembly would have that prong that the button sits on.
As long as you have the screwdriver underneath of the knob, I wouldn't worry to much about putting too much pressure on it.
Let me know if you still have any questions, I'll be happy to help you figure it out.
If you found this helpful, please be so kind to rate the repair that I wrote, or leave feedback.
Thank you,
Chris Jones
GoVacuum.com
May 27, 2010 | Hoover V1 SteamVac SpinScrub Vacuum
Brushes do not move any more how can I access the belt area to replace or inspect
The brushes are turning by an air driven turbine. The turbine has a pivot bushing made of steel inside of it that gets rusty because of the water that is running through it. The turbine gear will have to be replaced. You can access the turbine gear by removing the hood. You can find a genuine hoover replacement part by following the link below. Just find the model number of your Steamvac.
http://www.usavacuum.com/Hoover-SteamVac-Parts-s/105.htm
Please give positive feedback.
Mar 04, 2010 | Hoover STEAMVAC VACUUM Vacuum
Brushes donot turn when asked to shampoo
The brushes are turning by an air driven turbine. The turbine has a pivot bushing made of steel inside of it that gets rusty because of the water that is running through it. The turbine will have to be replaced. You can find a genuine hoover replacement part by following the link below.
Hoover SteamVac Replacement Turbine Brush Gear Part # 91001097
F7425 Parts Link
http://www.usavacuum.com/Hoover-Steamvac-s/109.htm
Feb 09, 2010 | Hoover F7425-900 SteamVac V2 Widepath...
Brushes do not turn
F7425 Parts Link
Dec 24, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover steam vac model f7425-900 filter is
The brush system on this model has a poor engineering design in that the brushes are running off an air turbine, which uses a steel bushing to spin the turbine which gets rusty from the moisture when the machine is being used. No long term solver. I would replace the machine with a Dirt Devil Platinum Force model
Nov 27, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
The scrub brushes dont spin anymore
Oct 23, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover turbine replacement
first you must remove the dirty water tank then the nozzle window on top of the machine. (this is the clear piece that the dirty water is sucked through.) then remove all 8 screws from the bottom along with the 1 screw on the main housing. after all this the top housing will be snapped into the base at two spots in the rear of the upper housing. when these are loose the housing should be out. you will find the turbine in the front along with 2 more screws and 2 hoses that also must come off. attach new part and reassemble.
good luck!!!
Sep 23, 2008 | Hoover F7431-900 SteamVac Vacuum
Hoover F7220900 SteamVac V2 Upright Vacuum Logo
163 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
