Question about Eureka Smartvac 4870 Bagged Upright Vacuum
Replace the handle release pedal on an Eureka Boss Smartvac,
I have an older Eureka SmartVac and the handle release pedal broke. I ordered a new one, part number 70042. I can figure out most things, but either I'm missing something here, or I'm having a brain fart...
I can't find the manual but i don't think the manual would help me much with this problem anyway. I've been holding the handle upright with a bungee cord, but that doesn't work well enough when I go to clean the throw rugs.
Help, please,
Barb Stout
  • Barbara Stout
    Barbara Stout Dec 01, 2008
    I'm sorry, but the first solution didn't address replacing the handle release pedal at all. Basically, all it did was give me the reasons I had bought it a few years ago.I have an older Eureka SmartVac and the handle release pedal broke. I ordered a new one, part number 70042. I can figure out most things, but either I'm missing something here, or I'm having a brain fart...
    Help, please,
    Barb Stout
  • Barbara Stout
    Barbara Stout Dec 04, 2008
    Thanks for posting the manual, but as I suspected, it gave no info on replacing the handle release pedal....so i still need help!!!
    Master:
  • 474 Answers
Bassially, uyou have to take it apart and replace the broken with the new. Im asuming you have taken it apart already and tried putting it in. Now, in order for it to lock in place to keep it standing upright, there is a spring or a metal clip ( 17 in diagram from above user refered to as the handle release spring) that locks in place when you push it up and pressing the petal depresses it and allows you to tilt it down.
Now is it stuck up and locked or is it falling down and not locking upright?
If its not lcoking upright, there may be damage or broken plastic wher the metal clip or spring go in and allthough you replaced the parts, the casing itself is damaged and isnt holding the handle lock spring is proper position and falls out of place after you put it together, in which case your out of luck, unless you can fix it with ingenuity and some strong apoxy. You could try using some automotive appoxy to glue the metal spring in place, wait a few hours to dry and then re-asemble and hope that it holds.
Im guessing it probably broke when someone tryed to pull it down without pressing the release petal and snapped the plastic that holds the metal spring in place. just a guess.
well good luck.
Posted on Dec 04, 2008
    Scholar:
  • 82 Answers
Hello. Are there any deep screw holes underneath it? This is the way I took apart my Oreck.
Let me know if you can't find anything and we can try something else.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, other areas that maybe explored are:
  • flat metal tab that serve as spring P/N 70043;
  • the the grooves and latch indentation that the handle release locks on, they may be worn out.
Additionally, an exploded parts diagram might be of more assistance to you.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Dec 01, 2008
  • Louie  Role
    Louie Role Dec 04, 2008
    Hi again,
    Any updates or developments so far?
    Novelist:
  • 157 Answers
Obscure question for the win. Sorry to hear about your troubles but bravo for taking the incentive to fix it yourself rather than sending it to a repair shop. It took a bit of searching, but I found the repair schematics for your model vacuum.
Schematics in a PDF
Note: The handle release is labeled in the schematics as part number 16 on the first page.
Hope this helps!
TJ
  • 734 Answers
There is a service manual on net for 5.79 USD ------
http://www.google.com/products?hl=en&client=opera&rls=en&hs=YJf&pwst=1&resnum=0&q=service+manual+Eureka+Smart+Vac+4870+Bagged+Upright+Vacuum&um=1&ie=UTF-8&sa=X&oi=product_result_group&resnum=11&ct=title
    Genius:
  • 1,847 Answers
Here is a link to the owner's manual in case you need any diagrams
http://www.eureka.com/service/manuals/70750.pdf
    Master:
  • 505 Answers
Go through this :
The Eureka Boss SmartVac 4870GZ upright vacuum is a powerful performer with an attractive price tag. It has several extra features and it tackles pet hair with ease -- all for about half the price of its competitors.
This hard-working vacuum easily cleaned carpets of various heights in our tests. Thanks to a brush on/off option, it also can be used on hard surfaces, like wood or tile floors. The option to turn off the rotating brushes on the vacuum head works well with delicate area rugs. It's also a good idea to turn off the rotating brushes when using attachments so they don't excessively clean one area of the carpet.
One distinct advantage of the Eureka Boss SmartVac is the PowerPaw attachment. This mini-turbo is a 5.5-inch brush roll that increases the amount of dirt and dust that is picked up; it is ideal for cleaning stairs. The SmartVac 4870GZ uses a collection bag and comes equipped with a sealed HEPA filter. The filter is relatively easy to change, and will need to be replaced about twice a year (more often if you are battling heavily soiled carpets). The costs of HEPA filters are about $20 each, so plan on figuring this expense into your operating costs.
We especially like the SmartVac's brushview window. By looking through this clear window covering, you can actually see the dirt being removed from your carpet. This Eureka model is meant for serious cleaning, and it makes us feel better when we can see all the pet hair it picks up zipping through the hose. Plus, if the hose ever clogs, we'll be able to see that, too. As with most vacuums we test, we wish the hose had a longer reach. Its accordion design is particularly unwieldy at first, but does offer a bit more flexibility with extended use.
This model has a few details that really make a difference. Its 30-foot power cord gives plenty of room to vacuum from room to room without moving the cord to various outlets. It has helpful onboard accessories, including two nesting wands, a crevice tool, dusting brush and upholstery tool, as well as the PowerPaw tool.
Thanks
Eureka 4870 upright vacuum cleaner needs powercord replacement
If it's not too badly damage you can wrap it with black electrical tape
Oct 20, 2014 | Eureka Boss SmartVac Pet Lover Bagged...
How to install handle release button on eureka vacum cleaner model# 4870
Eureka 70042-355N Handle Release Pedal for model 4870
costs online anywhere from >99cents to $9.00.
here is a great discription found after much looking.
http://www.fixya.com/support/t4508530-eureka_model_4870dt_r_nplastic_foot
Aug 30, 2011 | Eureka Smartvac 4870 Bagged Upright Vacuum
Have a Eureka "the boss" smartvac, won't pick up anything when I try to vacuum carpet. Any suggestions on how to fic this problem?
1st) make sure your yellow dial at the top by handle is in floor position
2nd) make sure your brush roll spins when handle is reclined in operating position. (disengage brushroll control by flipping the "switch" towards you)
3rd) check belt to make sure it is not broken
4th) check the brush roll for debris caught in it
5th) check lower hose
Aug 12, 2010 | Eureka Smartvac 4870 Bagged Upright Vacuum
4870 roller part number
I know the belt number
Eureka Part Number: 61110B (Replaces 61110, 61110A)
And the roller i think: Genuine Eureka Brush roller part number 61250-3 for Eureka The Boss/Smart vac/smartvac ultra 4800 series vacuums including models 4870 and 4880
Hope this helps you.
Jan 03, 2010 | Eureka Smartvac 4870 Bagged Upright Vacuum
How do you replace the handle release pedal
The handle release is just snapped into the bottom base. To take it out you will need to take a flat screw driver and pry the old one out. Then take the new one and pop it into place.
Dec 02, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Eureka the Boss SmartVac just turned off and won't turn on
Make sure it is not the electrical outlet that has tripped. If not then you basically have 3 choices. Cord, switch, motor. A service tech. should be able to diagnose.
Jul 25, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Something is stuck in my hose on the eureka boss smartvac, can i dtach plastic hose on side
yes, there are a few screws that need to come out to do so, u can also use a coat hanger to loosen it up and turn it on, the vac will **** the loose dirt into the bag/canister
Jul 14, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
New brushroll for eureka smartvac 4870; bristles too long to turn
HI Don't forget that you have a height adjustment control so its better to put it in the highest position - if this is not allowing the roller brush to move properly on the carpet then switch the vacuum off, and lightly trim with scissors on the brush lines. Avoid cutting everything down though - a slight trim should improve things. Generally though when brushes appear too long its usually because the height adjustment dial hasn't been set upwards.
Mar 27, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Eureka Smartvac 4870 Bagged Upright Vacuum Logo
333 people viewed this question
Top Eureka Vacuums Experts
charlesjo336
Level 1 Expert
JoeVacs
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
