Question about Dyson DC28 Animal Bagless Upright Vacuum
Brush Bar Randomly Stops Turning
I will be vacuuming and the brush bar stops turning, the power button flashes, then it may start turning again. A few times I stopped the machine and cleaned the bar and even unscrewed it to see if something was trapped farther up. After putting it back together it worked for a few minutes and then stopped turning again.
  • Dyson Master
  • 1,558 Answers
There are numerous things that could cause this. It would be best to find a qualified Dyson repair person to determine the cause of your DC28.
Posted on Nov 30, 2017
3 Suggested Answers
ukvacfan
  • 328 Answers
SOURCE: The brush bar on my Dyson DC17 stopped turning.
If this model has a brush control - i.e a roller at the side of the model which controls brush to spin or not, then its a protected brush model - therefore even if the drive belt is intact the Dyson would have to be repaired by a service personnel or professional. The brush protection isn't able to be taken apart and sounds like it may well have slipped off due to tension.
Posted on Apr 02, 2009
how do I get to the top belt spindle on a DC O7 animal (purple one) to be able to change the brush bar
Posted on Oct 04, 2009
Brush bar not working have taken it out and cleaned it
hi John.
you have not said on what model its not working.
but if you go to this link and look for your model it might help you out.
Brush bar not working Google Search
Nov 23, 2017 | Vacuums
Tip
Cordless Shark Vacuum Brush Bar Stops Working
My cordless Shark Vacuum brush bar would stop working each time after a few minutes of use. I was getting ready to throw the vacuum cleaner away, but decided to pull the bottom cover and check it first. I did the following modification and now it works great!
Just a few notes before attempting this tip: You need to be carefulafter this modification if you see the brush bar stop as this couldmean the bar is really jammed and there is a risk of the brush barmotor burning out. Most of the time disabling any fuse or circuit breaker is a very bad idea and could ruin equipment and even cause a fire. In the case of this tip, only consider the modification if you areready to get rid of the Shark because of the brush bar problem. Another option is to replace the circuit breaker, however consideringthe time and money involved vs. the cost of the vacuum cleaner it mayor may not be worth it to you. I did this modification to my cordlessShark about 4 months ago, and have had no further problems with it. I takes about 15 minutes to do this modification using a screw driver and wire cutters.
1. With the vacuum cleaner off, check the brush bar by manually rotating is with you hand. It should not be jammed or very difficult to turn. If so, remove the brush bar and clean it. Try the vacuum again. If you still have a problem with the brush bar stopping, proceed to next step.
2. Remove bottom cover around brush bar / motor.
3. There are two wires going to the brush bar motor, one wire includes a small circuit breaker.
4. Clip the circuit breaker out of the wire and reconnect the wire straight to the motor.
5. Re-install bottom cover.
on Apr 25, 2010 | Vacuums
Brush bar stops spinning
If cleaning debris from brush roll and nozzle housing doesn't solve the problem you may need a new PCB, if that doesn't solve it you may need a new power nozzle assembly. This is a difficult repair that should be performed by a qualified technician.
Apr 05, 2016 | Dyson Animal Airmuscle Vacuum dc28
Dyson dc28 animal red light flashing and no suction
Clean any debris from around the brush bar. If this doesn't solve the problem you may need to take it to a qualified repair person
May 18, 2014 | Rainbow E series Canister Wet/Dry Vacuum
Brush bar won't turn
Please advise which model of Dyson
Jan 04, 2014 | Dyson Vacuums
Dyson brush bar stops when I move forward
Make sure that the brush does not have lots of hair etc jammed around it. If there is anything that will cause resistance to the brush bar turning, a sensor will immobilise the brush until it is clear. Be careful how far you strip it back to as there may be warranty issues if you do more than undo the bottom with a penny, so you can use scissors to cut away at the hair or carpet fibre entanglement. Good luck
Nov 24, 2013 | Dyson DC25 Animal Bagless Upright Vacuum
Mar 31, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson DC28 Animal Bagless Upright Vacuum Logo
218 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Manchester Vacs
Manchester Vacs
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
