Question about Apple iBook G3 Mac Notebook
Negative screen image
When I turn on my iBook the display looks normal for the first few seconds, then the whole picture turns "negative": everything that is supposed to be black or dark is white and everything that is supposed to be white or light colored is black. Everything is working fine otherwise - but I can't find anything in the preferences to change this troublesome orientation.
  • janet_whitak Nov 29, 2008
    Thank you SO much! I have no idea how this option got selected - but your tip helped me change it back in a half a second.
    Problem Solver:
  • 5 Answers
Look in System Preferences for Universal Access, there is a Display option which says Black on White(the normal setting) and White on Black (the setting that has been enabled).
There is a keyboard short cut to change the setting, it involves pressing four keys - Apple, Option, ^ and 8.
Posted on Nov 29, 2008
  • Neil Capel Nov 29, 2008
    No problem, I found the options in there after our youngest child managed to enable the Zoom function (by pressing a few buttons altogether I expect) in the same place.
    I thought the monitor was broken as it went all fuzzy! (try it on an LCD screen and it goes really blurry)
Pictures all switched to negative lastnight
If the whole screen is looking like a negative mode: go into setting/general/accessibility and turn off Invert Colors
May 05, 2013 | Apple iPhone 4S
How to change setting picture just opposite
If opposite means that you want to rotate the image or picture for projector mount in the ceiling.
KEYS location: (keys are located back side of the projector there is 2 keys 1 for menu and second is a joystick witch have 4 arrow keys and center press is a enter key)
Press MENU button to display the menu screen.
then use joystick UP and DOWN to select the OPTION menu. Press joystick for ENTER to display the option screen. Then press joystick UP and DOWN to select INSTALLATION.
Then press joystick RIGHT and LEFT to select your required image rotation there is four type of rotations.
1. FRONT DESK
2.FRONT CEILING
3.REAR DESK (A translucent screen is required for rear projection)
4.REAR CEILING (A translucent screen is required for rear projection)
If opposite means negative to positive so there is no any setting in your projector witch is chang your picture or image positive to negative.
Jan 21, 2011 | Panasonic PT-LB60NTE LCD Projector
Magnavox 32MF337B/27 power supply works and like another writer when power is turned on the audio works the channels change and you can tell that all remote and on set keys work, but no picture except an...
hi i have a 50" magnavox that has a problem, i was looking at several websites and i find out the dirfferent posibilities.
in your case i have 2 posibble answers.
1) negative image
tv turns on and shots down in 2sec
flashing pixels on screen
dark image
has sound but no video
screen goes black and then return to normal picture
vertical color lines on screen no video
vertical color lines with video
vertical bars on screen
horizontal lines on the image
picture goes red after while
IT COLUD BE (X or Y or Z SUSTAIN BOARDS )
2) just left part of screen working
just right part of the screen is working
vertical and horizontal lines on screen
part of screen not working
some functions not working
no video but has sound
functions not working at all
IT COULD BE (LOGIC CONTROL BOARD)
TErry HerreRA
Oct 04, 2009 | Philips Magnavox 42MF521D/37 Television
Picture looks like a color negative
I would return it and get a brand name. It either has a bad lcd panel or digital board. If it breaks with no warranty you will be SOL.
Feb 26, 2009 | Protron PLTV-37 37 in. LCD Television
DSC-P200 displays ony negatives picture
Most likely a microprocessor problem. Replace the camera system board.
Nov 12, 2008 | Sony Cyber-Shot DSC-P200 Digital Camera
Syntax Olevia 50in Rear Projection Negative?
Sounds like you have projection bulb problems. Not an easy fix as the are 3 color tubes and a complete alignment when replacing even one of the 3 tubes. Takes a lot of work.
Aug 31, 2017 | Syntax Olevia 50" Rear Projection...
I have an LCD TV. All of a sudden the picture colour has gone wierd. The best way to describe it is that it is similar to either a colour negative or one of those scientific 'false colour' images. This...
TFTs can produce a wide array of colors, but it takes an enormous number of transistors to make up a display, and a problem with any one of them creates a defective pixel on the screen. Typically this shows up as a bright spot on a dark background, caused by a damaged TFT failing to turn off a pixel. Most active matrix displays contain a few bad pixels, but a few bad pixels are not going to have much of an impact on the overall picture.
The properties of liquid crystal material can create problems with viewing angle effects, causing the image to darken, disappear, or reverse the dark and light tones when the viewer is not directly in front of the display (kind of like looking at the negative of a photo). The light bulbs make LCDs heavier than the plasma TVs (though they are still lightweights compared to CRT televisions.
Benefits of LCD TVs include a picture that can't burn in and doesn't deteriorate over time. Because of their flat-panel nature, placement options are plentiful, optimizing the cool factor over standard TVs
Apr 30, 2008 | Televison & Video
Display
try to remove ur display driver and reinstall it
Dec 03, 2007 | HP Compaq Presario V2000 Notebook
Lcd screen
That is an effect that can be had by internal software in the camera, like my Sony. Just get in there and turn off "negative" Youll probably see Sepia, solarize, B/W and negative as other choices.
Sep 18, 2006 | Olympus SP-500 UZ Digital Camera
Apple iBook G3 Mac Notebook Logo
304 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
