Question about Jenn-Air JCD2389G Side by Side Refrigerator
Freezer is working but fridge side is worm. There is a little cold air comming to the fridge side but not enough to make it cold. Freezer is fine.
  • 121 Answers
Sounds like the freezer may not be defrosting the frost will stop or slow down the air flow
Posted on Nov 29, 2008
My ge refrigerator side by side gsh22jfta ww freezer is cold enough but the fridge is not there is a vent between freezer and fridge, but I don't feel any cold air comming from it. Plz help me
The "damper" that open and closes is not working. It is controlled electronically with a thermostat. Here is the part to order.
All parts come with a 365 day, any part, any reason return policy
Apr 06, 2013 | Refrigerators
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
I have a kitchenaid superba ksrs25ilwh side by side fridge. The freezer is working fine but the fridge wont get cold enough even at the lowest temp
check the damper vent door for proper opening and closing as if this door is frozen shut or broken and jammed it cant open to let cold air in from freezer it will be behind a plastic grille between the freezer and fridge compartments and you should hear a fan in there running to move cold air too
Jul 02, 2011 | Refrigerators
I have a side by side double door fridge. My freezer is cold and working fine but my fridge side is not getting cold.
check yor damper door, it's the little door at the top and or bottom of the fridge insid near the top and or at the bottom behind the crisper drawer when working right they open to let cold air in from the freezer and warm air out. top one cold in, bottom one warm air out.they work on a sensor/relay when the freezer fan goes on they open when cold air is needed.
Mar 12, 2011 | Jenn-Air JCD2389G Side by Side...
Top mount freezer won't cool, fridge works fine.
check for compresor operation. a relay on compresor could be out
Feb 10, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
LG Refrigerator has no cold air for fridge but freezer works fine
Sounds like the freezer fan(FF)is wearing out, This problem is very hard to diagnose because the fan spins but not fast enough to circulate the chilled air thru the freezer and refrigerator. This repair costs parts and labor around $300.00
Jul 31, 2009 | LG Refrigerators
Side by side: freezer temperature fine, fridge too warm
sounds like your auto defrost isn't working. my maytag does same thing. the cooling core in the freezer is probably iced up. when it becomes solid ice no air(or very little) can pass by, leading to too little cold air reaching the fridge. you can try to cycle the temp levers(usually doesn't work) you can manually defrost the freezer. pull the cover off the back(inside freezer) and use a blow dryer. not sure how much parts are for whirlpool. hopefully this is just a one time thing. there are tests you can find to check some of the the heat element for the defroster, just search for the tests.
Jul 30, 2009 | Whirlpool Refrigerators
Refridgerator side not cold freezer side fine
Difficult to properly diagnois with such a brief description, but try the following as a good first step at correcting the problem. Reset the freezer and fridge thermostat settings at the factory default. Also, check the freezer section to make sure nothing is blocking the cold air supply vent into the fridge, do the same on the fridge side too.
Normally is the freezer is working fine, and the fridge is warm, it can be due to either a blockage of the cold air cross vent by items in either the freezer, fridge, or both, preventing proper cold air flow from the freezer into the fridge. Also, check to see if the cold air vent is not frozen or obstructed, with a fashlight (you;ll need to remove stuff from fridge and freezer to make this possible to check.
If the vent is not obstructed and you can clearly feel cold air passing from the freezer into the fridge, it is possible that the cold air vent control has ceased operating properly and needs to be replaced. Usually though this type of problem is caused by people over stuffing things into the freezer section and blocking the cold air cross over vent. Hope this helps.
Jul 13, 2009 | Maytag MSD2756G Side by Side Refrigerator
Admiral side by side
All the cold air from your freezer gets pushed into the fridge with a fan in your freezer section. So your problem is from the fact that this cold air isn't get to your fridge.
- the door that allows this cold air into the fridge, normally in the top left corner of the fridge, is stuck shut and needs replacement.
-the freezer isn't defrosting and restricting the air flow
-the temp controller for the fridge is damaged and thinks that the fridge is cold enough.
Nov 15, 2007 | Admiral 26 cu. ft. Side-By-Side...
Jenn-Air JCD2389G Side by Side Refrigerator Logo
158 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
