Question about JBL S120PII Subwoofer
Powered 12 inch JBL subwoofer cycles red and green
I have 2 JBL 12 in subwoofers hooked to my home theatre. Both have worked fine for the past 3-4 years. Given the understanding that the front LEDs are red when the system is off and green when the system is on and working, I now have one that starts off ok then cycles from red to green in an even timing pattern. Thoughts from anybody what in the amp section would cause this?
  • Jimmy Evans Jan 19, 2007
    I forgot to add they are both JBL PB12s
  • Jimmy Evans Oct 31, 2007
    Lenanci, since January, I took it to an authorized JBL service shop.  After a 50 dollar charge, I was told that the Amp was bad, specifically, the IC.  I was also told that JBL no longer had the parts available. I was instructed to call JBL about resolution.  Well, I have 2 JBL PB10's that led me down the same path that got me the PB12 at cost.  I opted to park it until I can find an after market amp or IC and now I have Klipsh which I love.  My JBLs have been a sad disappointment.  If anybody knows about the IC, I'm all ears
ice man
  • 68 Answers
SOURCE: jbl pb12 subwoofer
yes it can be repaired. but i need more details on this...
Posted on Apr 23, 2007
  • 3 Answers
SOURCE: jbl PB12 powered sub woofer problem
These subs have had many problems, all associated with the amplifier section. PB 12's with an "M" as part of the ser. no. were assembled in Mexico and these are the ones with the amp problems. JBL fixed mine and sent it back no charge, BUT it cost me nearly $100 to send it to them in the first place. I have another one that has had no problems at all. Try sending it back for repair. At best you'll get a rebuilt unit back, at worst a substantial discount from the company for a new sub.
Posted on Aug 09, 2007
CLUEPATEL
  • 138 Answers
SOURCE: subwoofer isn't working
If your wire connections are normal then the problem is due your woofer speaker. Its your subwoofer circuit error and must be repair thru replacing the damaged Component in the circuit
Posted on Dec 09, 2007
SOURCE: jbl subwoofer PB12
I had the same problem...replaced the C42 capacitor with one that I got from RS...fixed everything and all is well again. I only have moderate soldering skills, too, so if I can do it, so can you
Posted on Dec 01, 2008
SOURCE: when i plug in my subwoofer it has a constant hum
Check to see where you are plugging it in. Plug all equipment into the outlet strips powered by the same AC outlet. Or use a direct box. Check your cords also. And lastly, return the product if you are under warranty and get yourself a new one. If the problem is still occuring, it probably has to be on your part, not the product. So try one of those examples before you return it.
Posted on Oct 15, 2009
I have JBL GT5-S644 ,4chnnel,800 watts, bridgeable car amplifier.Is it possible to pair this amp with 2 pioneer 900 watts subwoofers working with 12 volt adapter at 80 amps in 240 volt in home ?
Hello
yes it is possible but you will find that the amp is going to be under powered to drive all three subs, will have to look at getting a stronger amp later. hope you enjoy rattling the house apart.
Enjoy
May 25, 2011 | Car Audio & Video
I have a JBL PB12 it works for a few minutes then it shuts off and on and the lights on the front flash red, green, red, green..... why is this? Is it something I can fix or get fixed? I don't realy have...
Here are the service manuals, you may what to read the service bulletin section. Most common failure in the PB10/12 is the blown ClassD amp module which you cannot get it anymore. This is how I fixed my: http://s807.photobucket.com/albums/yy352/budm/JBL%20PB-12%20mod/
Mar 08, 2010 | JBL PB12 Subwoofer
JBL Subwoofer - Intermittent operation
Sometimes bad caps show a lifting or rounding of the top of the cap, sometimes this top will split from heat and pressure and sometimes it will not show any sign of damage but will be dry inside and its capacitance value will drop to a very low value. Replace the big power supply caps and test again. Get the same size, value and voltage rating. You can go higher on voltage rating and a bit on value. Getting a similar size or something that will fit in the same space is important also.
Jul 20, 2009 | JBL PB10 Subwoofer
Noise when it turns on
have you checked your music source? Some systems like computers have a sort of output first before normalizing, which isn't your powered subs or powered amps problem. Try plugging in a regular solid state player like an ipod if the humming is still there when automatically turning on or off...
Dec 06, 2007 | JBL PB12 Subwoofer
Jbl PB12 powered sub woofer
if your serial number starts with ha then it's probably a bad capacitor C72 . 6.8uf 100v np electrolytic. replace it with a higher voltage capacitor of the same value.
Mar 10, 2007 | JBL PB12 Subwoofer
JBL S120PII Subwoofer Logo
168 people viewed this question
Top JBL Audio Players & Recorders Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
