Question about E-Machines T2642 PC Desktop
I have an Emachine T2642.hears a pop and the power went out on pc
I was on my computer and heard a sound like a fuse pop. Then i got no power on my emachine. Purchased a power supply and hooked it up and still no power. Problem isnever backed up my folders. Now evrything important I had I can not get back.
  • 55 Answers
As long as your hard drive didnt go, you will still have all of your files. Chances are your Motherboard blew. Motherboards have capacitors so they can make popping noises if they blow
Posted on Nov 30, 2008
1999 Crown turned ignition switch to start - heard pop - no electrical power
If nothing works including the lights, something happened between the battery and the fuse box.
There are some fuseable links between the battery and the starter solenoid or between the solenoid and the fuse box.
I'd start with the battery cables and look for those fuseable link wires.
Jul 09, 2012 | 1999 Ford Crown Victoria
I have an emachine T2642 desktop and I need to replace the battery. Where is the location to replace the battery
A desktop machine does not have a battery, only a power supply. Unless you are talking about the motherboard battery which is located on the motherboard inside the desktop, but if that is the case I highly suggest having someone at a local shop swap out your battery. Making a mistake could ruin the motherboard.
Apr 10, 2011 | E-Machines T2642 PC Desktop
T2642 Emachine upgrade,can you recamend parts that are compatable 1GM memory. Hard drive 160 MG Viteo memory over 128 GB Thanks
Use this site to help you upgrade you T2642 e-Machine. The link shows what can be upgraded. Includes max memory the system can run;
http://www.cputopia.com/emachines-motherboard-case-cpu-replacement-t2642.html
Hope you find this helpfull.
Mike
Oct 21, 2009 | E-Machines T2642 PC Desktop
Tv plays sound but no picture or any signs of backlight
This sound is a capcitor pop and this could be in the power supply unit itself. The glass could be a fuse that took the brunt from the capcitor pop.
1. Unplug the unit and do not plug it in.
2. if its under warrenty take it in please!
3. if its not under warrenty and you know eletronics verify what cap popped and replace that and the fuse.
4. if you do not know about eletronics this work would cost you around $150 for the wrok done.
Good luck I hope this information helps you!!
Jul 17, 2009 | Vizio L32 32 in. LCD HDTV
EMachine T2642 motherboard
Here is some great PC solution by Some FIXYA EXPERT. Get any kinds of PC solution from bellow.
  1. Intel MotherBoard
  2. Mercury Motherboard
  3. Gigabyte Motherboard
  4. MSI Motherboard
  5. P5GC-MX/1333 Motherboard
  6. ASUS Motherboard
  7. IBM
  8. Packard Bell
  9. via
jashim12
Apr 10, 2009 | Computers & Internet
Need2 know wiring diagram 4 power supply 4 a emachine T2642
Hi there
The power supply should be ATX 20pin connection and also a 4pin connector, look at this picture below so you know you have the power connections in the right places>>ba37bd3.jpg
On the top left of the picture, the big cream 20pin socket is where the 20 pin connector goes.
In the middle to the left you will see another cream 4pin socket is where the 4pin connector goes.
If your power supply does not have the 4pin connector the pc won't boot up, you will have to go out and buy one.
If you have all the connections right and the on/off button is connected to the front panel properly, take out the system memory, clean it with a clean, dry, soft pain brush and also clean the slots too, re-seat the memory and reboot the machine to see if it boots up.
Good luck and thanks for using Fixya!!!
Feb 19, 2009 | E-Machines eMachines Desktop PC
Power up
if no power light indication then, probably the power supply got fault. please try to test your power supply .
melnavz
Dec 23, 2008 | E-Machines eMachines Desktop PC
Old emachine T2642 will not boot...disk monitor LED stays on and CPU fan does not rotate...no boot access to CD-ROM, or disk drives...changed power supply...think it might be BIOS backup battery...
It sounds like a dead motherboard. Try removing the CMOS(BIOS) battery and replacing it. Then try removing and replacing the CPU as well. If you get the same result then you might be looking at replacing the motherboard.
Regards
Dec 20, 2008 | E-Machines T2642 PC Desktop
EMACHINE T2642 W/ IMPERIAL GV20030812
Can you provide at bit more info?
You say it wont power up, are you getting any power through at all? DO the LEDs light up? Can you hear the noise of the fans etc powering on?
Mar 23, 2008 | Computers & Internet
No power
Probably blown fuse on the power board. If you hear a "pop" sound, you have blown couple of fuse along with some other components. When a small fuse blows you cannot hear any sound. Camera needs a new power board and repair cost may run from $175-275 depending on damaged parts.
Mar 16, 2007 | Sony Handycam DCR-TRV230 Digital Camcorder
E-Machines T2642 PC Desktop Logo
101 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
