Question about Philips Magnavox 51MP392H Rear Projection Television
I have a Philips Magnovox 8P6044 C101 60" rear projection tv that appears dim and slightly blurry. Waht are the suggested fixes and what would be a range of repair costs?
  • Anonymous Dec 08, 2008
    picture looks like a foot ball.
    small on all fore side.
    would it be the picture Bulbs Going Bad.
    8P 4844 C101
    E-Mail Castro2plypaper@q.com
    509-488-5078
    cell 760-5570
    Sergeant:
  • 233 Answers
As far as the foggy / blurry appearance goes, you more than lkely have contaminated CRT coolant. This coolant (inside the lenses) should be crystal clear, and normally over time, with heat and time the crt's will grow a sort of bacteria in the coolant. I have drained crt's and the coolant has looked like applesauce before. Once you clean the crt's and replace the coolant with new coolant, the pic should be just as good as new!
Posted on Dec 19, 2008
Magnaovox rear projection tv has too much red in the picture and it is blurry
Sounds like a coolant issue with the CRTs. Look into the lens of the green and blue CRTs and you should see what looks like bacteria if the coolant nees replacement. Usually the green and blue get contaminated which dims them and makes the red become dominate and the picture will get dim and out of focus.
Jan 22, 2010 | Philips Magnavox 51MP392H Rear Projection...
Magnavox projection tv model 8P6044 C102 is very
The CRT fluid is cloudy and should be replaced. Goto www.TvRepairKits.com. They have a kit to do it yourself.
Ed
Jun 21, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Blurry screen
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to...look white, look dull, look red/orange, etc. You may even see halos around images.
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Feb 02, 2009 | Philips Magnavox 9P6034C 60" Rear...
55 inch Philips
I have 50" philips magnavox big screen. I recently started to have a problem with the edges of my tv. They became blurry. the center of the tv is clear and the edges are blurry. what should I do to fix this problem.
Sep 06, 2008 | Philips 9P5034C 50" Rear Projection...
62 inch philps magnovox faded
I would suggest that you check the HV output first this could be a sign of a decrease in HV and or a focus problem. Check the trippler, The IHVT, and the focus block (this is usually attached to the IHVT). Then I would check the actual CRTs (items to check: filament voltage, HV at the HV anodes, and screen grids of the CRTs). If you do not have a background in electronics, I would suggest that you have a qualified TV technician examine your TV set.
I hope this helps
Thank you,
Shuttle83
Aug 30, 2008 | Philips Magnavox 51MP392H Rear Projection...
Philips Rear Projection Issue with Color Alignment.
this seems to be convergence problem in your tv .............
Aug 23, 2008 | Televison & Video
Blurry screen
coolant fluid on picture tube may be contaminated replace it an setbe ok (this is a technician job)
Mar 19, 2008 | Philips Magnavox 9P6034C 60" Rear...
Dim picture
If decide to do yourself, ya only have to do the green and blue ones, the red light spectrum won't allow fungal growth. Pull whole CRT assembly out to prevent spilled/leaking glycol from onto lower main boards
Sep 04, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
232 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
