Question about Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television
Flashing red light
You said in an earlier email that it could be the jungle ic chip? What is that?
    Master:
  • 623 Answers
The jungle chip is the main IC processor. It is very complicated and has hundreds of circuits surrounding its complexity.
Six blinks is a diagnostic code for loss of horizontal sweep. Thus there is no raster and no high voltage.
Cure requires a look at the jungle chip and the horizontal synch signal to see where it got lost. Cost of repair is not so much unless the jungle chip must be replaced which is rare, but very expensive.
A good repair place can fix it quickly and under $100 so beware of who works on it.
Posted on Dec 03, 2008
Red light flashes six times
6 blink's means H stop or Horizontal Drive failure. Check the Jungle and its soldering connection terminals for possible bad soldering or loose connection. In some cases jungle ic found defective.also check your horizontal drive transformer windings and connection that is connected at the base of horizontal output transistor. Open winding or loose connection would result to absence of horizontal drive at the base of horizontal output transistor..
Feb 13, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
PICTURE FLIPPING HORIZONTAL - OLDER TVS HAD A HORIZONTAL OR VERTICAL HOLD BUTTON - WHAT HAPPENED TO THOSE BUTTONS?!?
U talking about way back in the 40 and 50.From the 60 on tv all use intergrated circuit board.Mostly ICS chips now,no more tubes and analog parts.The problems ur tv have is the Horizontal IC chip is dead.
Sep 09, 2010 | Philips Magnavox 27MS343S 27" TV
Sony trinitron 6 red lights
Every part has its unique reference number on schematics and PCB of TV installed.
C515 means Capacitor # 515 and IC206 means Integrated Circuit # 206 mounted on PCB and shown in related schematics.
Jungle IC is technical term used in Sony and Panasonic refers to sync, oscillators, drive stages for horizontal and vertical deflection stages in a TV.
Need further info, let me know.
Jan 15, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Repost last comment on pt-47wx53g problem
Hi, I post here my last comment, follow the diagram at page 44, leave the checkup at page 16, for some of the test you need raster, and the TV is in protection mode now.
From protection mode follow troubleshooting diagrams, I think is page 44/45.
There are many faulty component that can give you blank screen with no raster, the strange things is that the TV stays on, has sound and is not on protect.
Test also the sygnal boards (the ones with the AV connectors) and see if it makes any difference switching the signal to a different input, this TV has several ICs that manage the video signal, testing blindly will give no help. Follow the diagrams on manual.
I think the following was my last comment:
You need to follow the troubleshooting charts at page 44 of user manual.
(download the service manual here)
Regarding the jungle chip, that is just a familiar name for the main computer CPU, service manuals rarely call it Jungle chip. Your jungle Chip is the main processor, IC4511, be careful handling the component arount the IC4511, some IC in there is sensible to static charges in your hands, better to keep fingers away.
In your case I would start testing following the diagram at page 44 of SM. I will also test the pico fuses at the base of convergence ICs, if the STKs had been replaced
That is what you do when the nature of the problem is not clear.
Since there is no protection mode on, the fault
can concern IC3001 and IC3002 that are vidio processors, and other parts involved.
If at any point you get the led on, and TV going in protect mode, with a flashing led, that is a step forward, means that the jungle IC (The IC4511) had detected the fault.
Start testing following the procedure at page 44, or same page on your version of service manual.
Dec 03, 2008 | Panasonic PT-47WX53 47" Rear Projection...
FLASHING RED LIGHT
Constant blinking usually infers there is trouble in the jungle ic chip. If that is so in your set the replacement of the jungle chip is quite expensive. More than $150. Probably not a wise investment for a 5 year old set.
The "call for service" is another sign the problem is more than minor.
So, without knowing more I think you are going to be better off by taking a trip to Walmart, Best Buy, Circuit City or Ultimate Electronics and start looking over the new stuff.
You know, I don't have any personal experience with Durabrand tvs, but I was in Walmart today and playing with the controls on one of their sets. After I got it optimized (in the store they always set them up with maximum color and brightness) it was the best looking picture in the store - even better than Sony. The one I was looking at was only a 20 inch for $89, but I was duly impressed with it. Walmart has a Durabrand 27 inch set for $168, which is a good price if the picture is as good as the 20 incher that I was playing with!! Just a thought.
Nov 27, 2008 | Panasonic PT-53WX53 53" Rear Projection...
TV Sony Wega Trinitron turns off automatically, blinks 10 times
if you know how to solder, solder the power supply then the jungle IC.if still not working. maybe flyback had a problem it need to replace.
Nov 16, 2008 | Televison & Video
Sony FD Trinitron colur television KV-29LS30E
When i set the TV on it's not open but the red led lights on-off 11 times.In service manual said than the error is in 8v in jungle I.C .That means the jungle IC is off?
The 8v comes out from jungle I.C or the power supply?
THANKS
Jan 15, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony KDF-55WF655 won't turn on, red light blinks 6 times
When a sony blinks 6 times that means a problem in the horizontal deflection circuitry. Check C515, C516 and the jungle IC !C206
Jan 08, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
SONY KP-57HW40 TUNS OFF AND STANDBY LIGHT BLINKS 6 TIMES
6 blinks is usually associated with failure of the horizontal deflection amplifier - which shuts down the high voltage system as well.
The repair requires testing to determine the exact parts that have failed. There are, for example, a few hundred parts and a section of the Jungle IC chip involved. So, repairs could require something as simple as replacing some inexpensive passive components OR as complicated as replacing the jungle chip (very expensive).
most of the time it's the horz. transformer and transistor.
Dec 20, 2007 | Sony KP-57HW40 57" Rear Projection...
Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television Logo
146 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
