Question about Kenmore Elite 45986 Front Load Washer
No lights, clothes are in the machine and the door is locked. I unplugged it, but still no lights!
  • 116 Answers
DO YOU GET AN ERROR CODE F DL F-11 ERROR CODE IF SO REPL MAIN CONTROL BAORD
Posted on Nov 30, 2008
Front loader leaking out the front door as is clothing stuck in it, How can we release the door lock. We've stopped the cycle.
Restart the machine...
On a NEW CYCLE... The first thing the machine
should attempt to do... is to drain itself.
If it does not...
UNPLUG IT... Restart it on a spin cycle ... or regular
wash cycle...
Carnac the Magnificent YZQ7YL
Jan 21, 2017 | Washing Machines
No lights on control board, door locked, MAH9700
Unfortunately the control board is dead and will need to be replaced. Here is the board to order if you decide to order it.
The E2 error code was for a stuck button and it would require the control board to be replaced also.
Dec 08, 2012 | Maytag MAH9700AWM Neptune Front Load...
When i started the machine, it went to start, then clicked and gave me a f dl error message. the door is now locked and will not even allow me to get clothes out. i have unplugged the machine several...
Unplug the unit, remove the lower access panel (front of the machine) reach up and find the small lock release tab and pull downward to release the lock manually. remove your clothing. This is usually do to a door switch failure. Replace the door switch. It may also be a wire coming loose or making intermittent contact. Hope this helps
Oct 22, 2010 | Whirlpool Washing Machines
My washer is locked. I unplugged and plugged bach
holding the end of cycle button is the control lock,not the door lock. Check to be sure that the control lock light is off--if not, hold end of cycle button again till control lock light goes off.
I've given up on the door lock after a few years fighting it, and researching. There is a solution on fix-it that may work--if it is computer(mother board I think they call it)--and not door lock mechanism. I've read many posts from duet owners that replaced door lock mechanism just to have it be a soldering problem with the "mother-board" that makes the machine "think" there is a door lock failure.
Here is link to a fix-it post I used today to get my machine open and retrive clothes it has held hostage for several days:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
Oct 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Maytag Neptune - door locked, clothes inside, lights are on, no reaction to unplugging and replugging. Help! My work clothes are in there! Thanks a lot.
The manual says that you should push the on/off button to turn off the machin. Wait for 2 minutes for the door to unlock. Then open the washer door.
Audioguy4
Sep 29, 2008 | Maytag Neptune MAH5500B Front Load Washer
Door locked & nothing happens Whirlpool duet wfw8300sw01
hi there,
sounds like the machine has no power at all.
there was no need to break the lock.
unplug the machine
take off the console
check connections from the touchpad to the CCU board
make sure nothing is corroded, burned, bent or pinched
unplug and replug the wiring harness
plug the machine back in and try it again.
let me know if this works.
Sep 26, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Door stuck Locked Control Locked light on
Try unplugging the washer for at 30 minutes to reset the computer, first. If this proves unsuccessful, you can retrieve you clothes by using the manual release. The following link explains how:
Once you retrieve your clothes, try running diagnostics on it. You can envoke the diagnostic sequence by selecting DRAIN/SPIN, NO/SPIN and then pressing any button under OPTIONS 4 times (must be the same button). The display should go to "C00" as the washer begins a sequence of tests that checks the fill functions, door lock, dispenser functions, motor speed, spin and drain. Allow the washer to run through the entire sequence and shut off. If anything is wrong an error code should be generated. Hopefully, all you had was a minor glitch. Let me know how things turn out. I hope this helps you.
Aug 25, 2008 | Kenmore Elite 45986 Front Load Washer
GE Energy Star WBVH5200 Front Load Washer
My GE Energy Star Front Load Washer is reading 5.9 instead of 59 minutes and not washing clothes. We cleaned the filter and still no luck. Please help.
Jul 30, 2008 | GE Energy Star WCVH6260F Front Load Washer
44072 Kenmore Washer - Front Door Won't Lock
There is a black peg on the round housing of the washer that gets pushed in when the door is closed and the machine locks the door. If the peg gets broken (as mine did) the machine won't lock. I now use a small screw...or you can buy a replacement part for the whole mechanism.
Feb 13, 2008 | Kenmore 44072 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
61 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
