Question about Hansgrohe 17224 Axor Carlton Vertical Bidet Faucet With Cross Handles....
Cross handle hansgrohe faucet I can't remove top piece
My faucet is leaking near the cross handle. Insturction with cartridge describes that the piece just below the cross handle has to be removed. I've tried a strap wrench, but I can't keep strap from slipping toward top of housing and thus can't torque suffeciently to remove housing. Any tips?
  • Anonymous Mar 22, 2014
    Need to remove housing
  • Anonymous Mar 29, 2014
    The faucet is leaking. I remove the top of the handle but I can't determine how to remove valve stem to fix the leak
  • 68 Answers
Use a rubber glove between the strap wrench and the fixture. It is a little monkey business but keeps the strap from slipping.
Posted on Dec 17, 2008
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ...
    • 11 MIN
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    How to repair cartridge-type faucets
  • Cartridge faucets have only one moving part. The stem slides up and down to open and close the faucet and rotates to regulate the flow of hot and cold water. Any leaking requires replacement of the cartridge.
  • First, turn off the water. To remove the cartridge, you'll need to remove the handle. This project can be like working a puzzle. If you have the manufacturer's instruction sheet for the faucet, you're ahead of the game. Without it, look for a retainer clip at the rear of the faucet just below the handle. Or, you may have to remove a set screw or snap-in "hot-cold" button and a handle pin or screw. On some faucets the swing spout must come off first. The retainer clip may be hiding beneath the handle inside a lift-out tube. Some cartridge faucets use two retainer clips–one by the handle and another by the cartridge. Retainer clips can be pried out with a screwdriver.
  • Once the retainer clip is removed, the cartridge simply pulls out. Use pliers, as shown. Install the new cartridge by pushing it into place with the flat arrow, or other mark upward. If you use a lubricant on the cartridge, make sure it's silicone grease.
  • on Jan 16, 2010 | Plumbing
    How do I replace a cartridge for kohler bancroft sink faucet?
    kohler bancroft is the sink manufacturer, not the faucet mfgr. do you have a clue what faucet mfgr it might be?
    Jan 14, 2018 | Kohler K-10577-4-SN Bancroft Widespread...
    Dismantle the handle plug
    Most Hansgrohe faucets or handles have a plug in them. This does not come apart but in most cases you simply push the plug into the handle and once you have removed the hendle you can retrieve the plug from inside the handle or on top of the faucet. If you need further help fell free to contact Hansgrohe Tech at 1-800-334-0455 press 2 for Technical.
    Apr 05, 2013 | Hansgrohe Plumbing
    Leaking faucet
    Remove the handles. See if the chrome slip nuts holding the stems in are corroded. If they are, the cartridges may not be fully seated or the o -rings that seal around the cartridges may need to be replaced. If either of these is the case you can tell for sure by turning the stems to the on position with the handles removed and looking for water seeping around the cartridge. If none of the above is the cause then check to see if the aerator (screen on the spout) is loose or corroded sending a light spray back towards the faucet body that looks like a leak. If this is the case remove and clean the aerator, then reinstall it making sure not to cross thread it. If none of the above, replace the faucet. Be sure to call Delta first before replacing because they have a lifetime warranty and you just might get your faucet for free!
    Apr 05, 2013 | Delta Faucet Delta 2530-24 Innovations...
    Manual for hansgrohe 14010 faucet
    The 14010 faucet does not have any adjustment for handle tension. It uses a cartridge to control the on/off functions. If it is hard to turn on and off it may mean the cartridge has debris in it or has worn out over time. You may need to replace the cartridge. This should be part number 92730000. List is $48 and it is available through your local dealer or online dealer. If you need further help feel free to contact Hansgrohe Tech at 1-800-334-0455.
    Jan 28, 2013 | Hansgrohe Plumbing
    Leaking tap
    This is most likely a cartridge that has worn out and needs to be replaced. Most of the kitchen faucets use cartridge number 92730000. This is available through your local dealer or online dealer. If you need further help feel free to contact me at Hansgrohe 1-800-334-0455. Press 2 for tech and ask for David Scarborough.
    Oct 10, 2012 | Hansgrohe Plumbing
    Stiff cold water handle bathroom Hansgrohe
    If the handle is hard to turn it is most commonly caused by water deposits in the handle or in the cartridge below. I would try removing the handle to ensure it turns freely when not installed on the faucet. If not you can clean it with CLR to remove the water deposits that are making it difficult to turn. If the handle turns freely when not installed you will need to remove the cartridge and inspect it to ensure it is not broken or damaged in any way. There could be debris in the cartrige that has either made it hard to turn or broken the ceramic disks. Our handles are easily removed by turning the bell shaped ecutcheon below the lever or cross handle. There are not set screws that hold them on. If you need further information feel free to call me at 1-800-334-0455. Press 2 for tech and ask for David Scarborough.
    Aug 07, 2012 | Hansgrohe - Lavatory Faucet - Centerset -...
    How to replace hansgrohe M2 cartridge
    First you will need to tighten the set screw all the way back in. The use your 4mm hex wrench to turn the screw 4 complete turns counter clockwise. Then remove your hex wrench and the handle should come off. There will be a dome shaped cover with blue and red indicator marks. This will simply pull off the cartridge nut. It is held on by o-ring tension only. Once removed you will see the large hex head of the cartridge retainer nut. Loosen this nut and the nut and cartridge will come out of the faucet. Don't be alarmed if your new cartridge is smaller than your old one. There has been a design change in the cartridge so it will fit smaller bodied faucets but will still replace the older thicker cartidge. If you need any further information feel free to give me a call at Hansgrohe. 1-800-334-0455. Press 2 for tech and ask for David Scarborough. I'd be glad to help.
    Aug 04, 2012 | Hansgrohe Plumbing
    Hansgrohe 17224 Axor Carlton Vertical Bidet Faucet With Cross Handles.... Logo
    767 people viewed this question
    Top Hansgrohe Plumbing Experts
    Paul Carew
    Jim Goldsmith
    Jim Goldsmith
    Are you a Hansgrohe Plumbing Expert? Answer questions, earn points and help others
