Question about Whirlpool Dryers
Whirlpool dryer is not drying
Whirlpool dryer turns on and turns; however, it is not heating.
  • mechatronic2 Nov 30, 2008
    thank you, i will look into it.
  • 121 Answers
The heater could be bad but you need a volt tester to check there are thermastats and thermal fuses that can stop the heat as well as the breaker the unit may run but not heat if one side of the breaker is triped or bad
Posted on Nov 29, 2008
  • 213 Answers
SOURCE: I have a Whirlpool Gas Dryer LGV6848AWO.
the ignitor bar that lights the gas might not be coming on, the coils that open the gas valve in the dryer might not be opening the valve, or the flame sensor might be bad which would not allow power to the ignitor. these are the most common problems with whirlpool gas dryers
Posted on Nov 28, 2007
SOURCE: Clothes dryer not heating
Hi I have a top vent Kenmore dryer. That seems to be heating up on and off. I can see the glow plus trying to ignite the gas I think what do you think is wrong..kj
Posted on Aug 28, 2008
docjohn174
  • 943 Answers
SOURCE: My Whirlpool Dry Model GGQ9858JQ1 turns off in heat mode after a few minutes
HI. thanks for the question. the motor seems to be at fault here. did you clean the venting from the dryer to the outside. , did you clean the lint inside the dryer. if not do that, thanks.
Posted on Oct 08, 2008
  • 163 Answers
SOURCE: whirlpool dryer model LEB6000PQ0 its not heating
check your breaker first.A dryer will run on 110 but wont heat.if not breaker it could be your thermal fuse or element.the thermal fuse is located on element cage,unplug machine and test for continuity to your thermal cut off fuse which will be the top one on cage and check continuity to element.
Posted on Mar 08, 2009
  • 14 Answers
SOURCE: whirlpool gas dryer #LGR4634JQ1 not drying or shutting off
MIGHT NNED A NEW IGNITER
OR GAS VALVE SWITCH
STEVE'S APPLIANCE
516-300-3249
Posted on Apr 06, 2009
Electric Whirlpool dryer m11036334, dryer will not always heat
Sounds like a limit switch has broken. Doesn't sound too expensive to fix.
Nov 14, 2016 | Whirlpool Dryers
The dryer wont heat-it over 5 hrs to dry a load. it would not turn off on automatic side & just keeps running. it turned off on the timed side
If it's not making heat the humidity sensor will never dry out, therefore it keeps running. It sounds like your heating element is bad.
Jan 20, 2014 | Whirlpool GGW9200L Gas Dryer
My Whirlpool clothes dryer model GEW9200LW0 stopped drying completely. The drum turns but no heat. It began slowing down the heating process approx. 2 years ago. Any suggestions?
Electric Dryer Does Not Heat
  • If your Whirlpool electric dryer is having trouble heating, you should check all of the thermostats, the thermal cut-off, all fuses and the electric heating element for continuity and proper connection.
Apr 18, 2011 | Whirlpool GEW9250 Electric Dryer
Dryer runs well but will not heat up and dry
You need to clean your dryer vent and make sure there are no obstructions.
Jan 02, 2010 | Whirlpool LGB6300 Gas Dryer
NO HEAT
its either the heating element or the limit switches both of which you can install yourself
Feb 05, 2009 | Whirlpool LER5636P Electric Dryer
Dryer has heat and tumbles but won't dry
your vent is stopped or the fan is not turning . most likely the vent under the house
Dec 14, 2008 | Whirlpool LER3622HQ Electric Portable...
Oct 07, 2008 | Dryers
Dryers Logo
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
