Question about Microsoft Internet Explorer 7
My computer doesn't connect to internet.
I have an hp desktop computer i have a wireless card but it says my computer cant find any networks. I have 3 other computers using the internet but mine just doesent work.     Please help me!
  • 1 more comment
  • Anonymous Dec 21, 2008
    i have 5 computers 2 laptops and 3 pc. 2 laptops connect 1 pc connects and 1 wireless pc connects 1 wireless pc does not connect. i have verison router and netgearwireless router.they both connect to computers but not tom internet.
  • steve2442 May 11, 2010
    trav,
    what is the wireless card manufacturer and model number.  what type of computer are you useing again if you could proovide the manufacturer and model number.  After we get a little clarification we can then find out what direction we need to go in, in order to install this wireless card corectly.
    regards,
    Steve
  • eecom May 11, 2010
    Hi trav998,
    Perhaps try re-posting this in the 'routers' section, under your router name and model number. Also, please let us know your operating system, and if you have tried anything to fix the problem so far.
    Hope this helps you to get an answer.
    Problem Solver:
If you turned on security on your router you should check the follow:
1. did you hide your SSID? if so, you can either turn it back on, or manually add it to your favorite networks.
2. did you use WPA encryption? if so- does your wireless card support it?
3. does your router broadcast with G while your card can only work with B or A?
Posted on May 31, 2009
My computer is connected to FIOS router and now cannot connect to internet.
Posted on May 21, 2009
    Sergeant:
  • 366 Answers
Be sure your Wireless card is activated on your PC.
Check manufacturer instruction on How Physical activate it: HP Compaq 6710 has a touch switch on top of the keyboard. Lenovo T62 has a slide switch on front side
Some other Think pad use FN + F5
If you do not see any network be sure WLAN is on than check your WLAN card for wireless characteristics (Control Panel/Network characteristics/Wlan interface properties in General tab identify your device (connect using) May be you have to configure according to your environment
Posted on Dec 26, 2008
Does my hp pavilion p6733w desktop have wireless internet adaptor?
The HP Pavilion P6733w did not come with a wireless network adapter originally. It does have a wired 10/100 network LAN port. You could add a wireless network card to one of the PCIe slots. (There are 3 PCIe x1 slots and one PCIe x16 slot. Depending on the upgrades, you may have other cards in the system box.) See https://support.hp.com/us-en/document/c02628426 for the original specifications.
I hope this helps.
Dec 10, 2017 | HP Computers & Internet
I have a hp pavilion a1140n and i cant set up wireless internet in my house what do i do
To have wireless internet you would need a (cable or DSL modem depending upon your ISP. A wireless router (doesn't matter which brand) Also for a desktop computer you will need to buy and install a wireless NIC (network interface card) as desktops almost never come with one, only a hardwired NIC (cabled)
Dec 16, 2011 | HP Pavilion a1140n (PX774AA) PC Desktop
Scaleo 600 how can i connect to internet from modem?
Plug your modem up to your phone line & plug in the power cord. If you are using an ethernet cable its should plug into the modem and into your computer. If you are connecting wirelessly, make sure you card has a wireless network card or that you have a wireless adapter. If it still doesn't work you may have to call you internet provider to make sure the modem settings correct.
Sep 10, 2011 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
I have 3 laptops connected to a bell 2wire router. They are all able to connect wirelessly to the router and access the internet fine. But I am trying to connect my hp2605dn printer to the router with a...
To install a HP printer (with built-in Jetdirect print server) as a network printer you need to do the following -
1. Open the printer’s menu and enable the Network Card – then configure the IP address of the network card so it matches the IP range of your network. Eg. If your IP's are 192.168.0.xxx then set the network card to a high number say 100 then set the Subnet Mask IP address to 255.255.255.0
If you have a wireless router then check the IP addresses that the router issues to the computers on your network and configure the IP address in the printer accordingly.
2. Install the HP printer driver on your computer/s using the LPT printer port.
3. Connect the printer with a LAN cable to the network hub/router.
4. Click on Printers and Faxes - right click on the HP printer and click on Properties.
5. Click on Ports and click on Add Port.
6. In available ports - click on Standard TCP/IP Port and then Configure port.
7. Tick the IP box and type in the IP address of the HP's printer IP address.
8. Click OK and tick Enable bi-directional support and then OK
Install the HP printer driver on every computer on your network and configure the printer’s TCP/IP port as previously detailed.
Do a test print page to check the printer.
You can now print from any computer on your network.
Dec 03, 2009 | 2wire Computers & Internet
WHAT PCI CARD TO GET WIRELESS INTERNET ACCESS ON
You can get this adapter from Linksys its WMP54G so you can make the computer wireless, but you can also check some adapter from Ntegear , Belkin and Dlink...
Aug 16, 2009 | HP Pavilion 734n PC Desktop
Setting up Network Bridge Connection using Laptop
the simpilist way to do that is to buy a wireless usb stick 15.00 then you can connect directly to update.and if u dont want kids using it for net pull the usb out .
Jun 16, 2009 | Computers & Internet
Cant connect to wireles network . will not find network. not sure if equipprd with wireless adaptor
I don't think it has a wireless adapter as standard, you can check by doing this:
Right click on My Computer and chose Properties.
Click on Hardware and then Device Manager. This lists all the Hardware in your PC.
Next double click on Network Adapters.
If there is a wireless card listed here then you will be be able to connect to a wireless network. If not then you'll have to purchase one from a PC shop.
May 17, 2009 | HP Pavillion s7420n PC Desktop
Computer cannot access the internet
Try to disable wireless card on your desktop. With both the wireless and cat-5 socket enabled, "WITHOUT" the proper bridge settings, they will conflict and not be able to read.
Apr 07, 2008 | Computers & Internet
One computer on network can't open internet pages
Try resetting the modem. It may be the Modem has to re-assign an appropriate ip address to your desktop.
Apr 01, 2008 | Computers & Internet
Microsoft Internet Explorer 7 Logo
779 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
