Question about Kenmore 24032\24036 Top Load Washer
My Kenmore Elite top loader washing machine is not spinning well
There is a burning rubber smell. If this is a belt, how do I replace it? Is there a picture on-line to show how?
  • 116 Answers
USUALLY ITS A BROKEN COUPLER TOP 15 YRS AND NEWER DO NOT HAVE BELTS
Posted on Nov 30, 2008
My Beko washing machine has a smell of melted rubber and I found black bits on the drum. None of the clothes have been damaged but they do smell a bit. Is it overheating or something?
hi Alyson.
this is what i found on the internet.
WHAT'S CAUSING A BURNING SMELL IN YOUR WASHING MACHINE? If you notice a burning smell in your washing machine, the cause could be any number of things. Regardless, this is one smell you shouldn't ignore. It's important to quickly diagnose the problem and find the solution.
The Burning Belt Smell Many top loaders are direct drive. This means they do not use a belt. The motor is directly connected to the transmission.
In Whirlpool and Kenmore models there is a rubber coupler between the motor and transmission that takes much abuse. It's very common for the fingers or the rubber itself on the coupler to break. A clicking noise with no spin or agitation along with a slight rubber smell are symptoms of this problem.?DIY repair is possible. Older models may also have belts that can be tighted or replaced
The new Whirlpool or Maytag washer can often be fixed without calling for repair.
To work on a top load HE washer pull the empty unit away from the wall. Drape a small rug or towel over the control to minimize damage to the wall and the panel. Lean the unit against the wall and the bottom will be clearly visible. Lie on the floor and note if there are rubber pieces or shavings under the washer. The belt may be rubbing against a plastic guard attached to the motor. The solution is actually quite simple: If the belt is shredded or worn you need to replace it. You can call a repair person or, if your washer is under warranty, the manufacturer. Or, if you or someone you know is handy, you can do it yourself!
Electrical Problems If your washer smells. The first thing to do if you notice an electrical smell in your washing machine and not a rubber burning smell, is to unplug the machine and call the manufacturer or a repair person.
An electrical burning smell may also be caused by a water leak coming into contact with electrical wiring. Both are major concerns and should be addressed immediately. A water leak can cause structural damage in your home and can short out the electrical wiring in your washer and cause additional damage to the machine.
Other Causes
Another more likely cause of a burning smell in your washer is overloading. Adding too many clothes to your washing machine can stress the motor or transmission, causing them to overheat or malfunction and emit a burning smell. For top load washers, overloading can cause the agitator to freeze or malfunction, stressing the drive belt and causing friction, which could emit a burning rubber smell.
To prevent overloading, know the size of your washer. They are measured in cubic feet. In addition, know how many towels, pants, shirts, and other items you can safely load. When it doubt, do smaller loads. Not only will this prevent overstressing the machine, it will also ensure clothes are thoroughly cleaned and rinsed.
or go to this link might help you to find out more.
washing machine has smell of melted rubber and found black bits on the...
Nov 29, 2017 | Beko Washing Machines
Washer doesnt spin anymore smell rubber burning
your belt is bad they are rubber and thats what your smelling
Nov 06, 2012 | Kenmore 24032\24036 Top Load Washer
I was washing wool that has a lot of lint and the washing machine stopped spinning and smelled like hot rubber. Is there a filter to clean in the washer?
The burning rubber smell is probably the belt. It is probably broken into. Remove the front of the washer on a top loader to access the belt at the bottom where the motor is.
Dec 29, 2010 | Whirlpool Washing Machines
My washing machine will not spin...
As you don't give the model, I can just give a generic reply.
Most front loaders are belt driven, and some top loaders are.
I think the main thing to look at first is the connection of the drive motor to the tub. If this is a belt - replace it and check the tensioner.
If it is a top loader using a gearbox, then the motor is likely to need either brushes or a new capacitor. Both items should be checked - so -
Belt ok? - Y= go to next question / N = Replace belt
Brushes ok Y= go to next question / N =Replace
Replace Motor Run Capacitor.
Feb 10, 2010 | Washing Machines
Washing machine spins slowly and smells of burning rubber
The belt could be worn and will be slipping on the pullys, as it spins up the rubber , rubs against the pullys and that is what creats the burning rubber smell, the belt needs replacing.
regards jonno
Apr 21, 2009 | GE WBSR3140DW Top Load Washer
Whirlpool top loader won't spin
If you are lucky you need a set of clutches about $45. If you are unlucky you would need a transmission.
Since it spins after you help it, I am guessing clutches.
Jan 31, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Not spinning as well
From what information I could find without having a model #, This unit does NOT have a belt. Instead there is a coupling that contains some rubber that connects the motor to the gearbox. Requires a service technician to replace.
Nov 29, 2008 | Kenmore 24032\24036 Top Load Washer
Dryer drum wont turn- burning rubber smell
could be a stuck gear box. burning rubber smell is coming from the belt sliding .
or the belt is just loose and can not turn the drum to spin it.
tnx 4 using fixya,
drcool
Oct 11, 2008 | Kenmore 98702 Stacked Washer/Dryer
Very loud final spin cycle with burning rubber smell
Hi Mcbride2
It could be one of 2 things. 1 the belt. or 2 the main seal and bearing. i recomnd to get a tech just to make suer.
brent
Sep 06, 2008 | Maytag Neptune MAH5500B Front Load Washer
Kenmore 24032\24036 Top Load Washer Logo
115 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
