Question about Dryers
Need Help replacing dryer belt
TRYING TO REPLACE A DRYER BELT ON FRIGIDAIRE DRYER MODEL FDEB34RGS1
  • donald_danie Nov 30, 2008
    Thanks JR JR I fixed the problem.
  • Anonymous Mar 23, 2014
    Dryer belt 1956mm
  • 111 Answers
PUT BELT AROUND DRUM FIRST AND NOW YOU HAVE TO GET TO BACK OF DRYER ,SHOULD HAVE SMALL PANEL AND ISTALL FROM THAT SMALL REAR PANEL NOT EASY
Posted on Nov 30, 2008
Change dryer belt
Thank you for your post, Amanda II!
Based off the information you have provided you need assistance in taking off your belt on your Frigidaire dryer. I was unable to locate any instructions on how to remove the belt or replace it. This is not a simple DIY job. I would recommend having a professional technician come out and disassemble your dryer for proper installation of the belt. They will have the appropriate tools to taking apart your dryer. I hope this is helpful to some degree. -Matt
Jan 22, 2015 | Frigidaire Dryers
Hi. I need help for replacing my dryer belt on a frigidaire mex731cfs. Please provide me with a step by step process, preferably with diagrams & pictures. Thanks!
http://www.ehow.com/how_6103112_replace-belt-frigidaire-dryer.html
here is a belt configuration:
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
Mar 30, 2011 | Dryers
I need to replace the belt in my GLER341AS2 model Frigidaire dryer. How do i open up the dryer to do so?
Unplug the dryer and using a 1/2 inch pait scraper locate the spring loded clips holding the top down to the front of the cabnet. They are located about one to two inches from the front corners of the dryer.
Lift the top and rest it on the wall behind the dryer.
Looking inside the dryer locate the screws holding the front panel to the cabnet and remove the screws.
Mark the wires to the door switch and remove.
Remove the front panel.
Go behind the dryer and remove the small rear panel near the bottom of the dryer.Observe how the belt is attached to the pulleys.Release the tention on the belt by moving the belt tentioner and sliding the belt off the motor pulley.
Go to the front of the dryer and grab the belt on the top of the dryer drum. Holding the belt lift the drum straight out holding the drum with the belt.
Check to see if all the rollers are in good shape and rotate freeley. Oil if needed.
Check to see if the teflon gliders located on the front panel that hold the drum are in good shape. Replace if needed.
Vaccum the inside of the dryer.
Put the new belt over the drum and line the drum up and install back into the dryer.
Put the front panel back on and reinstall the two screws.
Replace the door switch wires.
Make sure the grooves on the belt are flat to the dryer drum
Put the top down and go behind the dryer'
Locate the belt.
Pinch the belt and insert it under the tention pulley and slide it over the motor pulley. Make sure the belt is positioned straight and located where the old belt was positioned on the drum.
Jan 03, 2010 | Frigidaire GLER341A Electric Dryer
Belt replacement on a frigidare stacked dryer
Check the below link :-
http://repair2000.com/wpoolbelt.htm
Paste and copy it in other browser and click enter.
Any further help, let me know.
Thanks for using "Fixya"
Do rate the solution as "Fixya" if 100% satisfied.
Jun 01, 2009 | Frigidaire Dryers
Frigidaire electric dryer; model # FDEB34RGS1- gets TOO hot!
I could not find the model number you listed. I also would be very concerned about over heating until we can find and locate the problem. Look inside the door and compare number with the on listed here at Fixya. Thanks, Sea Breeze
Mar 25, 2009 | Frigidaire FGR341AC Electric Dryer
Need to know how to replace the belt on my dryer
Take off front and put belt over drum. Reinstall front. Take small access panel off back to install belt on motor. Idler pulley pushes against belt to tension it. Thanks, please leave feedback or contact me again for more info if you need it.
Nov 29, 2008 | Frigidaire FDE336RE Dryer
Frigidare dryer belt replacment
if your dryer is the one as pictured it is quite a job! I dont feel like writing a bunch of steps that may not even be the right model. Is the pic correct? Ill try to help if it is.
Nov 27, 2008 | Frigidaire GLEQ2152ES Electric Dryer
I am trying to replace the belt but the drum is still attached to the back (I have taken every visible screw out). Should I try from the front? Is there a way of getting the drum unsecured from the...
Hello mcbeanga,
Please find a link to an exploded view f your dryer http://www.pcappliancerepair.com/model-display.php
In many cases ( and I am not all that familiar with your figidaire model) belt replacement can be handled by removing the front and top panel. The exploded view may help a bit. Once you have the front removed, pay particular attention or take a digital picture if you have a camera handy) of the path that the belt takes around the pulley system and tensioner. Hope this helps you,,,
Regards,
Rick
Nov 23, 2008 | Frigidaire GLEQ2152ES Electric Dryer
front drum seal needs replacing pop clips at front of dryer top ..lift top remove 1 secrew each side of front from the inside..remove wires lift panel off clips ckd front panel around door area for felt seal may also have embedded plastic drum glides a felt seal also goes around bottom half
May 05, 2008 | Frigidaire FGR341AC Electric Dryer
Dryer repair
No. the belt is replace from the front, UNPLUG UNIT..remove front panel belt is looped over drum that way. Much eaiser to remove acess panel behind unit to reattach belt to idler and motor shaft, spring problably popped off idler, or motr shaft reattach and pull idler all the way to right and loop belt around motor shaft and relese(pulley should add tensionto belt)
Feb 26, 2008 | Frigidaire GLER642A Electric Dryer
Dryers Logo
147 people viewed this question
Top Dryers Experts
Richard Roth
Richard Roth
