Question about Refrigerators
Refrigerator, Frezer not running
My side-by-side Monogram stopped running three days ago, and started running by itself again today.
While it didn't work, the lights were on, but the compressor wasn't running.
Now that it works, and before it broke, everytime I open and close the freezer there's a noise coming from or near the compressor, similar to the sound of coffee brewing.
Thanks in advance.
  • 2228 Nov 29, 2008
    Thanks EmissionWiz.
    The Technical Data Sheet has Part Numbers for a Defrost Control and for a Defrost Thermostat. Which one would be the Defrost Timer?
    Thank you.
  • 2228 Nov 30, 2008
    EmissionWiz:
    The Technical Data Sheet has Part Numbers for a Defrost Control and for a Defrost Thermostat. Which one would be the Defrost Timer? Thank you.
    Lancer721:
    The refrigerator is working now. Will the compressor stop making that noise if I reboot the unit? I just want to be sure the unit won't stop running again; I'll reboot it if that's the solution. Thank you.
    Sergeant:
    Champion:
  • 291 Answers
The sound you were hearing is normal but if it shut off after it got cold enough and didnt come back on for the three days you have one of two problems ,,, the temp control is bad and it took awhile for the contacts to make or when it went into defrost the timer stuck ,,,, i would replace the timer 1st cause it would be the cheapest and easiest to fix and then if have to replace the temp control but that is the problem with your box / larry
Posted on Nov 30, 2008
  • 10,515 Answers
Refer this link :)
http://www.repairclinic.com/0088_4_1.asp
any issues regarding any appliances, noie or might be wana repair uself..........it has all the solutions with pics :)
Thnx.
    Sergeant:
  • 229 Answers
It sounds like the compressor is about to go out but you can try a hard boot on the fridge to see if it just needs a reboot on the board. Unplug for about an hour and then plug back in. This will sometimes reboot the relay that sends the message to the compressor to run. Also even if there is no visible ice sometimes the lines behind the wall can under-cool. This requires a complete defrost. Good Luck
Posted on Nov 29, 2008
    Top Expert:
  • Refrigerators Master
  • 81,400 Answers
Replace the automatic defrost timer, it is the most common cause of this problem by far, it is located at the base of the unit under the snap on cover/grille
  • Marvin
    Marvin Nov 29, 2008
    I would replace the control and the thermostat, as either one can cause the problem, most common is the thermostat.
Refrigerator running but not cooling
Is the fan running in the back compressor area?If not check voltage at the fan if there replace fan motor.[Condenser motor] Is the fan running in the frezer compartment if not check for voltage at that motor if voltage there replace motor[Evap motor]
Is their frost on the frezer back wall,in side the frezer compartment? if yes its a defrost problem.Use volt meter to check continuty on heater and term.thermostat [It must becold below 20 degrees to check term thermo.if those 2 ok its defrost timer
Nov 26, 2012 | Refrigerators
Problem with the GE Monogram ZISS420DMSS Side by Side Refrigerator. Defrost Drain tube clogged. Icicles form in the frezer compartment. How do I fix? Thanks.
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 17, 2011 | GE Monogram® ZISS420DMSS Side by Side...
I have a GE Monogram Free-Standing Side-by-Side Refrigerator Model #: ZFSB23DXSS was not used for 2 years. We decided to start it up again. It has been running for a month and is not getting cold on...
freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Sep 11, 2010 | GE Monogram Side by Side Refrigerator
We have a hotpoint refrigerator. The Frezer seems
There is a part called a defrost timer, it is usually the most likely culprit in these situations. Hope this helps
Oct 07, 2009 | Hotpoint HSS25GFT 25.0 Cu. Ft....
GE Monogram side by side not cooling
I had the same problem. GE Man said that since the unit had been allowed to warm so much, we needed to empty it, unplug it, and totally leave it alone for 24 hours for any excess water to drain out. Then, we needed to plug it in and let it run with NO ITEMS INSIDE AND NO OPENING OF THE DOORS AT ALL for 48 hours. After that, we started using it again and it was Perfect!! I thought it was a lost cause, so this worked and didn't cost me a dime!!
Jun 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Monogram will not accept freezer/fridge
Turns out the problem was because we didn't shut the freezer door tightly. The temperature re4set itself in about three hours. All OK and no expense :-)
Jun 05, 2009 | GE Monogram® ZISS420DMSS Side by Side...
GE Monogram side by side freezer and refrigerator
HI thanks for your question. the problem could have been, a defrost timer, stuck on defrost. or a failing thermostat. keep a close eye on it, if it stops again. get in touch and we fix the problem. thanks
Jul 17, 2008 | GE Monogram ZISx420DR 42-inch Side by Side...
Top Freezer and Fridge not working
WHEN ITS NOT WORKING DO YOU HEAR A CLICKING OR BUZZING SOUND (IF SO BAD COMPRESSOR OR OVERHEATING)SEE BELOW
ALSO CHECK THE CONDENSOR FAN IN BACK IS IT RUNNING WHEN THE COMPRESSOR IS RUNNING
Feb 18, 2008 | Frigidaire FRT8IB5EW 30" 18.2 Cu. Ft. Top...
Refrigerator will not get cold, but freezer works
Do you know if the compressor in the back is running? If you can check that out get back to me and we can go from there. Most times if the fan in the freezer is running the defrost timer is ok.
Jul 09, 2007 | Amana ARSE66MB Side by Side Refrigerator
Refrigerators Logo
15 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
