Question about Intel Celeron Notebook
LAPTOP SCREEN NOT WORKING TRYING TO USE LAPTOP WITH
DESKTOP MONITORING
No screen display msi megabook s260
If you have a desktop monitor available try hooking your laptop up to that. if you get a display on your desktop monitor then that means your laptop screen needs replacing. If you get no display on your desktop monitor then that means the GPU chip in your laptop has gone bad.
Sep 12, 2012 | MSI MegaBook Computers & Internet
WHEN A SYSTEM IS ON BUT NOT BOTHING ON THE SCREEN
If it's a desktop try another monitor. If the other monitor works, then the original one you were using is bad. If the other monitor does not work then most likely your video card is bad.
if it's a laptop take a flashlight and shine it on the dark screen. If you look real hard you might barely see the icons on the desktop. If, so then your LCD Inverter is bad. If you don't see the desktop with a flashlight, try using a external monitor. If the external monitor displays your desktop, then the video card is good, but more than likely the screen will need to be replaced.
Mar 26, 2012 | IBM Computers & Internet
Wrong monitor HP F2105 goes black after two secs when connected to HP G72 Laptop?
If the monitor works fine when tested on another device like if you have a desktop or a friend will let you hook it up to theirs, etc. then I suspect the laptop does not have a compatible driver or just cannot drive the monitor with the onboard video card. That monitor may be too much work for the laptop. Also, have you looked into how much just the lcd would be then maybe see if you can get help installing it yourself?
Nov 20, 2011 | HP f2105 21" LCD Monitor
My compaq laptop powers up but the monitor stays black i tried to plug it in a monitor and nothing.
Unfortunately..your display may be shot...Is it a Compaq Presario? These laptops have a history of display problems...I have a Compaq Presario R3000 and the display is showing a reddish color in the left bottom corner of the screen and my brother had a similar problem with a Compaq laptop where the monitor stopped working....Unfortunately it would cost more to replace the monitor than to buy an Apple MacBook...
You can buy a cable and attach the laptop to a desktop monitor and it will work although you will lose the mobility of the laptop which is what makes a laptop so appealing.
If your laptop has a NVidia graphics card you can go to display in control panel and set it up to use Plug & Play Monitor but you may need to use safe mode or you wont be able to see anything because your screen doesn't work....You might get lucky and when you plug in the cable (just like you would to attach a PC tower to a monitor), it will work and you will be able to make the monitor the dominant screen.
Oct 29, 2010 | Computers & Internet
My monitor was going zigzaging in different lines with my color back ground going with the linesand then went each time it came on then had to restart it to make screen go back to normal then went all...
When you first power on the computer does the monitor work fine?
can you boot into safe mode? - Click Here for step by step to boot into safe mode.
If the Monitor works in Safe mode or works when you first power on the computer then it could most likely be an issue with your Video Card.
Try testing the Monitor on the laptop to see if it gives you the same issue. If it doesn't then you know for sure it the Desktop. I would most likely say its the video card.
If it turns out to be the Desktop, post the model of the PC and I can help see what other options you have.
Apr 15, 2010 | Computers & Internet
Monitor does not come on
  • try to toggle FN key and F5 key..
  • try to plug in to an external monitor screen, if it works on external monitor, there is a problem on the laptop LCD screen
  • call your manufacturer for warranty or local service technician for LCD screen replacement
Apr 28, 2009 | Computers & Internet
No Display on Monitor (Princeton VL1917)
Try leave it for some time and try it again to the PC, when you connected it to the laptop it must have auto configs it selfself too suit the laptops resolution.
Nov 24, 2008 | Princeton Digital VL1918 Monitor
Laptop doesn't see the monitor i attach to it
1st off there is a Fn key, I think Fn + F5? to turn the monitor on. It is a toggle button that toggles between only the monitor or monitor and Laptop screen both or just the laptop screen.
I hope that can help, if not, please tell me what you have tried. As in, does the monitor work on another PC/Laptop?
G'luck
Oct 24, 2008 | IBM ThinkVision L170 17" LCD Monitor
I am trying to connect my laptop to the Polaroid LCD TV, as i would like to use the TV monitor as a computer monitor (my laptop monitor is broken). So I connect the correct wire to correct places, however...
The simple patch that I found (same problem) was to start by using any old monitor that I could borrow to set up my Dell Laptop.
After getting the Laptop booted on a regular monitor I right clicked on the desktop and went to properties then to the settings tab.
Here I found the dual monitor settings (#2 will usually be dis-abled by default.)
Click on #2 monitor and set the resolution to the lowest number (800 x 600 works well)
Then I clicked on "make this monitor my primary monitor"
As soon as I clicked apply the PC Windows screen appeared on the Polaroid TV screen
Earlier I had set the secondary monitor as "extend this screen to this monitor"
This also worked but I had to "drag the current screen to the right all the way off the
"borrowed monitor" until it appeared on the TV screen. The mouse pointer will be there also.
At first it took a little getting used to but in a few minutes I was up and running.
Hope this helps your situation
David Flournoy
Waxahachie Texas
Mar 10, 2008 | Televison & Video
Intel Celeron Notebook Logo
133 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
