Question about Penn Gt Series Levelwind Reels 330GTi
Penn Spin Reel will not lock after casting
We have a 4500SS Penn Spin reel that will not lock after casting. The bale functions properly and clamps into the "locked" postion after casting but the reel continues to free spinv f you do not hold tension on the line. Where is the reel locking mechanism located and how do you adjust it?
  • 2,976 Answers
On the front of the spool there is a device to turn to set the drag. Torn it tighter and tighten it until slightly below the breaking point of your fishing line. It isn't a critical adjustment, it just keeps your line from breaking while trying to land a fish.
Posted on Feb 20, 2009
Penn 4400ss will not lock after casting
Posted on Oct 14, 2009
Why is my reel able to reel both directions instead of locking in place?
Sounds like the slider switch didn't get back into it's socket properly, take it back apart and look at that.
Jan 31, 2015 | Abu Garcia 7000i RED Baticasting Reel
Top 10 Best Spinning Reels for 2016 & 2017
Let's face it! It is not easy to find the best Spinning Reel from the market. here you find your best spinning reel.When you are looking for a Best Spinning reel, you'll see that numerous brands have a few reels with the same name that come in various sizes (for instance a 100, 200, 400). This is typically in light of the limit of the spool, which directs the general size of the reel.In this video you will see 10 unique models of awesome quality modest turning reels. After quite a while of research, survey and searching for reels data I made my own rundown of main 10 minimal effort turning reels in slideshow design. My rundown incorporates every one of these reels.
Enjoy Our top 10 best spinning reels to buy for the 2016 & 2017 Fishing Season. The Lowest Prices Online!
Visit our website:
1. PENN Spinfisher V Spinning Reel
2. Penn Battle II Spinning Reel
3. Daiwa Mini System Minispin Ultralight Spinning Reel
4. Shimano Stradic CI4+ Spinning Reel
5.Okuma Avenger ABF Graphite Bait Feeder Reel
6. Pflueger President Spinning Reel
7. Okuma Trio High Speed Spinning Reel, Black/Orange
8. Abu Garcia BMAX2 Black Max Baitcast Reel
9. Zebco Omega ZO3PRO Spincast Fishing Reel
10.Penn Clash Spinning Reel
on Nov 24, 2016 | Fishing
How to fix Defiance 25LW that will not cast (or free spool)
Those reels are very simple, nothing too complex about them at all, sounds to me that the clutch gear is stuck not and not releasing when you try to engage it. I've had similar bait caster lock up like that when trying to cast heavier baits, what happens is the spool spins so fast that the inertia and vibration causes the reel to actually engage mid cast slamming the gears together. not good for the gears by the way. more that like the reel needs to be opened up and looked at to resolve the issue. www, for all your reel service needs
Jul 09, 2014 | Penn Defiance 25LW 66" Combo
My penn 950SSm reel doesn't lock out the handle spins backwards and lets out line after casting it and bail is flipped back how do i fix this
Try flipping it forward.. if that doesn't work... there must be a small spring inside broken. Just take it completely apart on a table. once apart look at the bail assembly, u should be able to find the broken piece. Take both broken pieces down to your local hardware store and ask someone for assistance. Someone should be able to help you find a piece very similar.
Oct 30, 2010 | Penn Spinfisher 950SSm Saltwater Spinning...
How do you cast the reel so the spool dosent continue to unwind after the cast
On the side of the reel there is a knob that you adjust for the spooling.As a rule of thumb you adjust it so when you have a lure on,click the release button and let it spool out,it will only drop about 4 feet.Now! tighten it a fraction.Start casting and it will not go very far.Just before the lure hits the water,you put your thumb on the spool.Hard at first and then less as you get used to it.You can then adjust the spooling knob to go a bit further every time.You use your thumb on the spool to adjust the last 10 feet of line.Use a lure with no hooks on it to practise.It's called a plug.Hope this helps and you reel in the big one's
Sep 21, 2010 | Penn 320GT2 Graphite Levelwind...
Require a diagram to assemble 330GTI reel. Reel disassembled as drag not functioning properly
Here you go!
330 GTi Schematic
Make sure the drag plates and drag washers go in correctly or the drag will not work very well.
If you are using braided superline, make sure there is monofilament backing under the line otherwise the braided line will slip on the spool arbor, tricking you into thinking the drag is shot.
Best of luck!
Sep 26, 2009 | Penn Gt Levelwind Series Reels
Quantum Tour Edition 1170PT baitcasting fishing reel
Tighten the drag star to expose the black ratch ring. Press the ratchet ring down towards the star drag as you turn the handle backwards to unscrew it from the crank shaft.
Apr 15, 2009 | Penn Gt Series Levelwind Reels 330GTi
Penn Gt Series Levelwind Reels 330GTi Logo
1,418 people viewed this question
Top Penn Sport & Outdoor - Others Experts
Mike Marcotte
Mike Marcotte
Tom Chichester
Are you a Penn Sport and Outdoor - Other Expert? Answer questions, earn points and help others
