Question about Nikon D200 Digital Camera with 18-200mm Lens
Nikon D 200 will not focus
Did you ever get a fix to the issue of the Nikon D200 will not auto focus?
I am having the same issue. Worked great the first 2 years
Andy andrew@tklcorp.com
  • 2 more comments
  • dandgtrs Jan 02, 2009
    I have a Nikon D-200 that will not auto focus unless I start by setting the focus ring to the infinity setting. The camera will then auto focus for one picture but as soon as I try to take another picture at a different distance the camera will not autofocus unless I reset focus ring to ths infinity setting again. Any ideas or suggestions would be appreciated. Thanks
  • Anonymous Jan 03, 2009
    My camera will not auto focus at all.  Tried other lenses, but no luck.
  • Anonymous Jan 30, 2009
    My D200 just stopped focusing. I thought it was a temporary problem with the cold air, but it won't focus inside anymore, either.
  • dippolds Apr 18, 2009
    Similar problem. D200 was working fine. All of a sudden, the LCD screen stopped working as did autofocus. As described elsewhere, if I manually focus to infinity, autofocus will work for 1 shot. Camera otherwise shoots fine. No error show except r25 show where it used to show the number of remaining shots.
  • 27 Answers
Andy, have you tried other lens??
Posted on Dec 02, 2008
Using 200-500 Tamron on Nikon d300. When I shoot, camera freezes. Clock and exposure readout next to it, on top panel, blink. Camera will not turn off, I have to take the battery out. Lens works...
Maybe there is something wrong with your batteries? Replace them. I had the same experience with my D200 and a Nikon 18-200 lens, later with my Nikon 10.5, Sigmaa 135-400. After replacing the battery everything worked as ever.
Mar 26, 2011 | Tamron 200-500 F5-6.3 DI AF Lens Nikon
D200 SHUTTER WILL NOT FIRE AUTUFOCUS DOES NOT Work
The manual says what f ee means, do you have the manual? Il get the manual now and check.
Jul 22, 2008 | Nikon D200 Body Only Digital Camera
Nikon 18-200 mm vr lens not auto focusing on my nikon d200
lets start with the basics, try hard reseting it and try again, if that doesnt work then
try upgrading your firmware (if possible on your camera) and if that doesnt work then it may be the lens, but dont forget to spend a few hours trying to find a option for it in the meny
Jun 13, 2009 | Nikon D200 Digital Camera with 18-200mm...
Trouble shooting in auto focus
Maje sure you lens it not set to manual focus and that the lens is mounted correctly. Also - FWIW - shoot with a fast shutter speed (1/250 or better) to avoid blur.
Apr 24, 2009 | Nikon D200 Digital Camera With 18-135MM
Nikon D200 refuses to auto focus with any lens it just doesn't do anything.
Does the camera body has a M/AFswitch? it would be located in front on the left side if that accidently gets changed to M your lens will not AF any more until you change it?? I know it sounds so simple but who knows!! Barry Brown
www.coralreefphotos.com
Oct 27, 2008 | Nikon D200 Digital Camera with 18-200mm...
Nikon D200 Auto Focus
It seems to be a problem with the internal working of the camera its self. I have requested a replacement fro my seller. Thank You Samuel
Apr 06, 2008 | Nikon Cameras
Nikon D40X stopped auto-focusing yesterday
I had the same problem. My issue was with all my lenses. I solved it by going to the menu and selecting the custom setting menu (pencil icon). Then from the right menu select the AE-L/AF-L and press OK. Then make sure it is set on AE/AF Lock. Presto...all my lenses worked on auto-focus.
Feb 24, 2008 | Nikon D40x Digital Camera
Trouble auto focusing
If it's any consolation, I have the same setup and the same problem. I'm now at the point where I'm probably going to have to return the lens as faulty, but there are a few things it could be on yours which you might want to check.
Have you got the D200 set to auto-focus? The selector (on the front of the camera, on the lower left) should be in the S position (as opposed to C or M).
Have you got the lens set to auto-focus? It should be in the M/A position, rather than M.
Have you tried cleaning the contacts? Pop the lens off and give the contacts a clean with the appropriate equipment. Dust on the contacts could be causing a problem.
Failing that, have you tried turning the camera on and off a few times?
I've obviously tried all the above on mine, and now suspect I've got a faulty lens that needs fixing ... which really sucks! Good luck with it, let me know if you get it working.
Dan
Jan 20, 2008 | Nikon D200 Digital Camera with 18-200mm...
Nikon D200 problem with SIGMA 28-200 lens - works on one D200 and not my other
Sigma lenses sometimes need re-chipping for full compatability with certain Nikon camera. They are usually quite good about doing this gratis.
Try the Sigma on another body at the camera shop or at home (preferably and older AF film camera). If it works then its likely just a chip compatibility issue.
Jan 07, 2008 | Nikon D200 Digital Camera with 18-200mm...
Nikon D200
My first question would be what lens are you using - some lenses have auto stability features - please post lens make, type, model number and when you purchased it.
Dec 22, 2007 | Nikon D200 Digital Camera with 18-200mm...
Nikon D200 Digital Camera with 18-200mm Lens Logo
432 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
