FixYa.com
Tags:
Epson 1.44MB 3.5 Floppy Drive Floppy Drive
Epson smd349 floppy
posted by elia on Jan 19, 2007
i have an old hp computer with bad smd349 1.44mb floppy drive, i found a new smd349 floppy drive but i can read on it just 720kb disks!( on the floppy label there is a label 1.44mb ) do's anybody have the floppy data to set it to 1.44mb ?
thanks
Comment by elia, posted on Jan 20, 2007
Hi
the floppy is new,and i have more than one.
on the floppy there are some jumpers i tried all the combinations.
where i can find the epson smd349 floppy data sheet ?
thank's
Eli
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jan 19, 2007
Helpful (85)
tomj23
Rank:Guru Guru
Rating: 86%, 1470 votes
Hi Elia,
Could be a couple of things:
-Your drive may only be a 720K drive. They will format 1.44 MB disks but only with a 720K format. The test is inserting a HD disk and try formatting it as HD.
-The disk could be mislabeled, HD disks have two holes on end opposite the slide, one to write protect the disk and the other to signal to 720/1.44 capable drives this is a HD disk.
-The HD disk could be formatted as a 720K disk even though it is an HD disk, reformat as HD.
-The new, used drive could be damaged.
-The drive could be configured as a 720K by the computers BIOS. You?ll have to enter the BIOS setup find the config for the A drive and set to 1.44MB.
Let us know what happens and please don?t forget to rate the posting.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Floppy Drives problems?
Floppy Drives
applications of linear...
1. if a rectangle has a length... Answer This...
Floppy Drives
floppy drive
The floppy drive will not open... Answer This...
Floppy Drives
word problems regarding a...
If you earned an average of... Answer This...
Floppy Drives
maths linear equations
A positive number is 5 times... Answer This...
Floppy Drives
konica floppy photo disks
I have photos on the old konica... Answer This...
Repair Service
Find Floppy Drive Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
