Question about E-Machines T5082 PC Desktop
I have a emachines T5082 and i want to know how can i disable the intergrated graphics in the bios?
  • Glenn Rogers
    Glenn Rogers May 11, 2010
    A couple of questions first? OK?
    The display adapter you have added in, does it have VGA out (blue) DVI out (white) or just DVI? Your monitor, is it flat screen? And does it have VGA in or DVI in or both? If both, you would have unpacked a VGA to DVI adapter, indicating it can take either. Same with the Display Adapter, if it unpacked with a DVI to VGA adapter included it means the DVI can be extended to a VGA adapter with no problems. This point I'm driving at can cause a problem where everything is connected correctly and the BIOS setup correctly but no signal still remains onscreen.
    Let me know, what it is or what you recall. I can take you through the sequence of switching over without trouble, the logic is clumsy on first use, to move off the onboard to an add in.
    I presonally think the motherboard should be smart enough to sense the load and make the switch automatically.
    And, if you weren't aware, displays are hot swappable. However, it is always advisable to power down the board when moving displays off one adapter to another. The MB can remain energized its just prudent to power down and extend the life of your equipment.
    Regards,
    Worldvet
DO IT HAVE WIFI?
Posted on Sep 21, 2010
I have a emachine t5082. I am trying to install new graphics card. How do i set the primary display to pci
Go into the BIOS, it will be in there...I don't remember where off hand, it won't be hard to find though.
Shut down your computer and wait for it to power down. Press the power button and look for a message that says "Press X to enter Setup." In most eMachines, this will be either the "F1" or "F2" key.
Dec 22, 2010 | E-Machines T5082 PC Desktop
I HAVE A T5082 WITH VISTA HOME BASIC I PURCHASED
problem will be with low watt supply, check the manula of graphic card, and use the power supply of the recomanded Watts
Feb 10, 2010 | E-Machines eMachines Desktop PC
I have an emachines t5082 and tried installing 2GB (2x1GB) they are a 2-pack, DDR2 6400's The board sees 1GB but when I put both in it won't even give me a boot screen or anything, just a black screen. Is...
eMachines recommends DDR2 at 533MHz.
(PC2-4200)
A lot of ram memory manufacturers, state you can use DDR2 at 667MHz. (PC2-5300)
This is a logical statement due to the fact that a lot of motherboard chipsets, (Northbridge chip specifically),
will allow ONE step up in ram memory frequency rate.
You are going Two steps up.
Who told you this would work?
This is erroneous.
(Mean that in a nice sort of way)
PC 6400 is DDR2 at 800MHz.
Your eMachines T5082 motherboard uses an ATI Radeon Xpress 200 motherboard chipset.
This chipset will only support DDR2 at 667MHz at best.
http://en.wikipedia.org/wiki/Xpress_200
Suggest you send that ram back, and get PC2-5300.
Jan 07, 2010 | E-Machines T5082 PC Desktop
How to install a xlr8 9800 gt graphics card on a hp p6140f with a intergrated card i try to put it on then start my computer but it will not turn on
if you have turned on the onboard video disable it in the BIOS and install the xlr8 9800 gt graphics card
Nov 23, 2009 | Computers & Internet
Need to flash the bios on E-Machine Model T5082. It has an Intel motherboard. Can you direct me to the tool download page?
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T%20Series&model=T5082
or
Paste into browser address bar
Oct 27, 2009 | Computers & Internet
I going to buy a emachine et116107 today and i
That particular model has PCI-Express slot for optional upgrades. So if you decide to upgrade the graphics look for anything with a PCI-E label or PCI-Ex16. If you do get a new card make sure to disable the onboard graphics in the system BIOS prior to installing new card. Instructions can be found via google search
Oct 05, 2009 | eMachines ET1161-07 Desktop PC
Dual Channel on an Emachines T5082
Look closely at the BOLD print
Memory Upgrade for eMachines eMachines T5082 Computer, the eMachines eMachines T5082 Computer takes the PC2-4200 DDR2 SDRAM DIMMs. Supports Dual Channel DDR2. Memory Type, and comes installed with 512 MB (removable) of Memory. You can upgrade your eMachines eMachines T5082 Computer to up to a maximum of 2.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB (removable) standard Memory installed. For best Computer performance use the maximum amount of allowed Memory per slot for your Computer.
Choose the following Memory Upgrade for eMachines eMachines T5082 Computer.
Apr 17, 2009 | E-Machines T5082 PC Desktop
Graphic Card
jumper settings for old graphic needs to be disabled or in the bios settings the on board vga settings need to be disabled this will allow the other new card to be ran as the dominent only video card
jumper settings are tricky
but bios settings are easy just find vga and disable on board video thats it save and boot
Jun 04, 2008 | E-Machines EMA IMPERIAL GV (845GV) TG3...
Intergrated Graphics card
The intergrated graphics card "should" disable itself automatically when a video card is installed. You may also be able to manually disable it in the bios.
Jan 09, 2008 | Computers & Internet
E-Machines T5082 PC Desktop Logo
260 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
