Question about Pioneer Audio Players & Recorders
Pioneer PD-6030 cd player does load up cd cosistently. When it does, cd plays fine
5 Suggested Answers
SOURCE: pioneer pd-m406 cd changer magazine style
The Pioneer component 6 CD magazine changers only play normal store bought CDs, not CDs you make yourself.
sorry.
Posted on Feb 20, 2008
robotek
  • 1512 Answers
SOURCE: Pioneer PD-206 wont power up
Hi tfulton
Try disconnecting from the power and powering it up again to reset the unit.
If it still wont cooperate, the unit will have popped a IC protector in the power supply. Not an uncommon fault. The burnt disc you used may have pushed the tracking servos a little hard and a circuit protector has kicked it. Pop the lid off and look for a black 2 wire device about 4mm across that viewed from above has a D shape. Measure it with an ohm meter....It should read low ohms, if it does not... it has failed. It may be marked as ICPxx(from memory)
A fast fix we used for this is to grab the device and give it a 200 deg twist to short the legs together. Soemtimes(often) the body of the device will break off, just solder the legs left behind.
They have a habit of failingl with no reason, and shorting across them will not affect the operation of the unit, nor put it anything in jeopardy.
OR pull the board out... and replace the device, although I can tell you through experience, they may fail again.
Good luck, if you have any questions, just get back to
me here. :)
regards
Graeme
Posted on Mar 08, 2008
  • 46 Answers
SOURCE: Pioneer 6 disc PD-M455
Hello...if you can try to clean the laser lens whit a smooth cotton pin it may be dusty,,i have had the same problem...don't use any solvent just the pin very carefully,,,maybe you can use a mild solution made of hand dish solvent... and dry clean after...alternative use a cd.cleaning disc...Good luck Ron
Posted on Mar 11, 2008
  • 105 Answers
SOURCE: Pioneer PD F506 changer jammed
It is quite possible that one of the drive belts has come off its pulley.
Posted on Mar 16, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: PD-6030 MP3 player flash error message
MyMusix's PD-6030:
If you have a Windows-based computer,
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If that fails,
Check the battery polarity. (+ and - must be in correct psoition)
Set the hold button to the unlock position.
Check if the file system is NTFS. If yes ,format it to FAT or FAT32. - Connect player to computer, click my computer, right click on icon of mp3 player and select format
If that fails,
go to www.mymusix.com to see if the latest software update will correct the problem
-Tha Mp3 Doctor
Posted on May 24, 2008
Will a pioneer pd-f605 play mp3s
Yes is will. You need to attach the MP3 to one of the inputs and select that input to play it. A burned CD should work just fine.
May 12, 2016 | Pioneer PD-F605 CD Player
I Have a Pioneer PD M602 6 disc changer, and I just bought it used. And I cant get it playing. Sometimes say "no disk" ( but the tray is full discs applyed as it schould. It loads one disk after...
To my surprise, CD cleaner disc did it for me. It's a very old Philips one with a bit of furry stuff on the track side. I was amazed it even played, but it did and after letting it run for 20 secs, tried proper discs and it works fine. And this Pioneer PD-M603 is at least 15 years old!Looks like it would be hard to clean the lens manually because it's a long way inside.
Jul 27, 2011 | Pioneer PD-M603 6-Disc CD Changer
My Pioneer PD-M403 will not play computer made CDs. Why won't they play?
incompatibility is the cause of the problem. There is nothing wrong with both your player and the computer made CD's, they are not just clicking with each other.
The Pioneer PD-M403 player is also an old model, this could cause the problem.
There is not settings whatsoever that you can use ti solve this problem.
Take care.
Sep 25, 2010 | Pioneer PD-M403 6-Disc CD Changer
Can't remove cd cartridge because won't power up.
With the top off the unit, you can turn the tray gears manually for slow eject function. Unplug unit before touching anything inside, check internal fuses.
Sometimes the little ball bearings that keep the cart trays separated come out causing tray jams and shorts.
Make sure your tray retracts all the way into the player flush with the face plate when loading, gently push it in while retracting for those occasional no-read situations. (Also for Denon that takes these same carts). Also note that the CDs go in the Upside Down position.
Applicable to:
Lexus Models: CDX-M9071zt CDX-M8036, CDX-M9071, CDX-M9741, CDX-M9751
also:
Philips CDC-875 Pioneer CDX-FM35 Pioneer CDX-FM45 Pioneer CDX-M30 Pioneer CDX-M40 Pioneer PD-DM802
* Pioneer PD-DM902 Pioneer PD-M403 Pioneer PD-M423 Pioneer PD-M426 Pioneer PD-M450 PD-M453 PD-M455
* Pioneer PD-M501 Pioneer PD-M502 PD-M503 Pioneer PD-M510 Pioneer PD-M530 Pioneer PD-M550 Pioneer PD-M552 Pioneer
* PD-M600 PD-M601 PD-M603 Pioneer PD-M610 Pioneer PD-M630 Pioneer PD-M650
* Pioneer PD-M701 Pioneer PD-M702 Pioneer PD-M703 Pioneer PD-M710 Pioneer PD-M730
* Pioneer PD-M801 Pioneer PD-TM1 Pioneer PD-TM2 Pioneer PD-TM3 Pioneer CCS-430
* DCM-444 and DCM 777
Many Magnavox, Denon, JVC,
BMW 740 OEM and others.
Dec 04, 2009 | Pioneer PD-M426 6-Disc CD Changer
Pioneer PD-F805 can`t read discs.
Few things either cd,s are not compatible
laser has died or laser ribbon cable is broken
Jan 07, 2009 | Pioneer PD-F805 CD Player
Pioneer elite pd-f27 300+1 cd changer
I've owned two of these players, one currently, and both exhibit this behavior. Although frustrating, it seems to be inherent in the vertical loading mechanism. Every finicky CD I pull out of the PD-F27 plays perfectly in my single-loading tray player, including CD-Rs. One would expect more of an "Elite" product, but there you are.
Mar 17, 2008 | Audio Players & Recorders
Pioneer pd-m406 cd changer magazine style
sorry.
Nov 03, 2007 | Pioneer PD-M406 6-Disc CD Changer
IT is Pioneer PD-M430 6-Disk CD changer
turn the cd, the silver side must be look down
Sep 16, 2007 | Pioneer PD-M406 6-Disc CD Changer
374 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Dennis McCollum
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
