It sounds like something is wrong with the transmission but I couldn't tell by looking underneath the machine. I was able to drain the water and the spin cycle works but it was very loud.
  • 121 Answers
Sounds like something in the pump
Posted on Nov 29, 2008
My top loader didn't drain and it make an extremely loud almost grinding type of sound. i emptied the washer and lifted to see if something was caught underneath. when i lifted to washer i found a puddle...
Hi well if there is grease then this is a big problem heres another way of checking lift up the bottom of the machine and tilt it back do you see grease or oil on the inside walls of the machine this sounds like a transmission that is going bad the part itself can be from 96-180 dollars for a new transmission for a technician t come out and repair it your looking in the area of around 300 or higher If you have any further questions please message me back and please remember to rank how this opinion helped in your appliance situation Thanks again
Rick
Dec 05, 2010 | Washing Machines
My GWL 11 is stuck right before the rinse cycle. It will not drain. The two orange rinse lights and the red spin light is on, and there is a quiet electrical humming sound.No error beeps. I've already...
Hi just read your posting.Now bail some of the water out by hand with a pot or small bucket so you can lean the machine back far enough to look underneath the machine without it leaking everywhere.Now when are looking underneath the machine look to the front right and you should see a red or black fan,This is your pump.Turn the fan clockwise and anticlockwise a few times to loosen the pump if any thing is jammed.The fan should spin freely.Now put the machine back on its feet and select a spin cycle and hopefully the machine starts to drain.Please reply to tell me how you got on or if the machine is still not draining or you have the other type of pump.Good luck.
Jul 12, 2010 | Fisher and Paykel GWL11 Top Load Washer
Intuitive eco
this machine will not spin until it is empty of water. it sounds like your pump is jammed. first- empty water by hand then tip machine backwards so you can look underneath. only tip it back enough to look underneath. on the front right of the machine you will see a black or red fan, that is the pump. turn the fan clockwise then anti clockwise and hopefully that will loosen up what is jamming the pump. put the machine back on its feet and turn it on. advance cycle to spin then push start. it should start draining the rest of the water out and start spinning. please reply 4 more help
May 21, 2010 | Fisher and Paykel (IWL12)
Water does not drain from machine at end of cycle
it sounds like the out flow is blocked some where on the front of your machine normally down the bottom there is a door open it behind should be a tap/plug type of thing turn it but put something underneath to catch the water this takes time when done take the plug out all the way have a look at the fan behind it will probably be blocked
Aug 21, 2009 | Asko D1716 Built-in Dishwasher
Whirlpool washer not draining
most top loaders use belt drives, it sounds as one of the belts has snaped. can you see a belt laying around a pully or on the floor of the washer that has come away , or a pully with out anything to turn it.
May 14, 2009 | Admiral AW22 Top Load Washer
Hotpoint wm75 drain pump removal
soz didnt realise it was a wm75 .unplug machine and remove lower back panel.remove water and take off hoses.pump is secured by 2 phillips screws underneath.remove wiring block and after removing pump there is three t15 tox screws on pump housing. sounds like u have something obstructing pump impeller
Mar 17, 2009 | Hotpoint Ultima WF860 Front Load Washer
Oil and water leak
Chances are they are not related if the water is clean.These units can run quite a while dripping small amounts of oil. The drain hose is a possibility but there are other places it can leak from. Call a local tech he can run the machine with the cabinet removed and should be able to find the source of the water leak. good luck
Dec 18, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore 80 series won't spin
If it is draining then the motor is turning the pump so it is ok.
This washer has no belt so that is not the problem.
Remove the cabinet and bypass the lid switch wires and put into a spin. Watch the clutch to see if it is turning. If the clutch housing is not turning and you know for sure the coupler is not broken then you need a new transmission. If the clutch housing is turning but the basket is not spinning you have something binding the basket or you need a new basket drive and clutch.
If you have only looked at the coupler from underneath you may not be able to tell if it is broken in the center. If it is broken again your transmission is not staying in neutral drain until the water is drained. That means it is going into spin with full load of clothes and water. This puts a lot of pressure on the coupler and causes them to fail prematurely. If this is the case you will need a new transmission.
Post back if you have any questions.
Nov 05, 2007 | GE WSM2700D Top Load Stacked Washer /...
Loud noise and smell
It would help to know the brand and model number of the washer. If it has a belt that also runs the pump, something may have gotten into the pump during drain and locked the pump causing the belt to slip.
Oct 07, 2007 | Washing Machines
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
