Question about Microsoft Compaq Presario C501nr Notebook
Need to remove my keyboard on Compaq Presario C501nr.
The "N" key broke off of my keyboard. I recently purchased a replacement keyboard but I do not know how to remove the old keyboard.
Remove battery.  Notice 5 phillips head screws labeled M2.5X4.  Of the 5, 2 have arrows pointing to them.  These 2 screws hold down the cover plate above the top of the keyboard, the one that has the 5 buttons for (left to right) WiFi, Power, Vol down, Vol up, and Mute.  Carefully pry up the cover after the 2 previously mentioned screws are removed.  You will see 4 screws at the top of the keyboard.  Remove these screws and gently lift up and slide up the keyboard.  Once the tabs at the bottom of the keyboard are clear, look to where the ribbon cable from the keyboard attaches to the socket on the motherboard.  Gently slide the very small tabs on the socket outward.  They only move about 1/16".  The ribbon cable should be free and you should be able to remove the keyboard assembly completely.
Install new keyboard in reverse order
Posted on May 08, 2009
Overheating on Compaq Presario Notebook Model C501NR
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
May 18, 2012 | Microsoft Compaq Presario C501nr Notebook
I dont know why is my key board is didn't work can you show me how to unlock my key board
restart your computer. on boot it will say press del for bios. do that. in case it enters the bios menu then keyboard is fine. probably some virus in windows. if not then your keyboard is damaged.
Mar 03, 2011 | Compaq Presario CQ60-220US PC Laptop
How do I adjust the brightness on my laptop? Its a Compaq Presario V2140US
1. Press down the Fn key at the lower left end of your Compaq Presario keyboard. Keep the button held down and tap the F7 key to decrease the screen brightness by one step.
2. Tap the F7 key again with the Fn key still depressed to further decrease the brightness by one step. Continue hitting the F7 key until you reach the minimum LCD screen brightness.
3. Hold down the Fn key and tap the F8 key to increase the Presario's LCD screen brightness by one step. Keep pressing the F8 key until you reach the maximum brightness for your screen
Mar 01, 2011 | Microsoft Compaq Presario C501nr Notebook
On my laptop (presario C501nr), network drivers for xp
XP has its own stuff built in ... check your hardware on the Windows XP compatability list to see if XP will operate on your newer computer. Find the list here: http://support.microsoft.com/kb/314062
There is also a test there you can run.
Jul 06, 2010 | Microsoft Compaq Presario C501nr Notebook
Compaq presario c501nr can't detect wireless network connection
Here, download the driver from here. Just install it and restart your computer....that should do it for you.
Mar 07, 2010 | Microsoft Compaq Presario C501nr Notebook
Compaq presario cq60 keyboard
If the problem is intermittent then the problem could just be foreign objects like crumbs and hair that's trapped under the keys.
Turn the laptop off and stand it on it's side with the lid open. Get a soft, dry paintbrush and brush the keys, gently tap the keyboard in various places with the back of the paintbrush to help dislodge anything that's trapped.
Once your satisfied all the keys are clear turn the laptop on and see if it has made any difference.
If it has not then you may need to replace the keyboard.
Good luck.
Sep 14, 2009 | Compaq Presario CQ60-220US PC Laptop
I ' ve got compaq presario C501NR Notebook PC computer.My computer is falled.When he start the operating system is now off.Sometimes he turn on,and sometimes he turn off.My laptop compaq presario C501NR...
you may have damaged the computer if it fell as you say. As for installing windows Xp that should not be a problem did you download driver first and burn a CD. If not get on another computer and donwload driver for your laptop burn them on a CD then install your drivers for XP that way you have the right drivers and it should work if not damaged inthe fall.
Good Luck.
Mar 15, 2009 | Microsoft Compaq Presario C501nr Notebook
How to take apart the case of a Compaq Presario C501NR Notebook PC so i can see the motherboard?
According to HP, the C500 guide isn't readily available but you can use the C300 manual listed here http://h10032.www1.hp.com/ctg/Manual/c00753552.pdf
You will need to start with the Removal and Replacement Procedure section.
Thanks
Aug 25, 2008 | Compaq Computers & Internet
Microsoft Compaq Presario C501nr Notebook Logo
369 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
