Question about Gateway GT5228 PC Desktop
Gateway gt5228- progressively worsening boot problem
Will not boot. started as an occasional problem. tried the obvious tricks,holding power switch for 30 secs. etc,worked a few times now it doesn't want to boot.
  • 5 more comments
  • h_william_b Nov 30, 2008
    no beeps come forth.works great when it does boot.Have had avast antiv on the system,never any problems detected. Won't shut off by power swtch unless held in for 10-15 secs. Some times need to pull plug, is on without switch being used upon replug.Fans roar but never slow down to normal levels.F8 does nothing.Mother board?If so any ideas on a different boarn that will not repro same prob?Thanks.Hank
  • bd0009 Dec 29, 2008
    My gateway is having the same exact problem. I have read a lot of threads with various solutions and have had no luck. I replaced the power supply to no avail. One post on another site indicated that the motherboard and/or hard drive may be toast as a result. I am having my IT guy take a look at it. I will let you know once I get a solution.
  • human1801 Jan 10, 2009
    I have exact same problem. It has occurred 3 times over the past year or so I have owned the machine. Each time prior, it magically fixed itself when I took the cover off and poked around looking a cable connections- however at this point I am still dead in the water.
  • Anonymous Feb 04, 2009
    I have two gateways in my shop with the exact same problem. One I found a little black fluid seaping from the capaciter near the memory this one I actully can get to boot occasionaly with a new power supply, but still inconsistent. The second machine I can not get to boot and it throws FF on a techaid diagnostic card. I believe both mother boards are begining to fail and if it is similar to many emachines I have seen and talked with a former tech at CompUSA the Power Supplies after about 2 years begin to fail and will sometimes damage the motherboard. It seems to happen with older Bestec power supplies. This has been my observation and it is not a scientific study.
  • computerscot Mar 09, 2009
    I have the same problem. I swapped out the power supply with a 350W power supply and I got the computer to boot. Putting the old PSU in I got no boot, so I ssumed it was the PSU. Re-installed the 350W PSU and computer booted enough for me to run anti-malware product. Only found 1 item. Next morning it would not boot with new PSU in it. I will try the holding power button in thing with no plug in PSU when I get home. I am going to try to get customer's data off if it boots again and suggest everyone else do the same if they can get it to boot one more time. No popped or leaking caps on mobo. I get no beeps from POST either. Both times I got it to boot I got a BIOS error requiring pressing F1 to continue, so I think mobo is going...
  • h_william_b Mar 17, 2009
    I too believe its a defective mboard. any inexpensive fixes, the board is proprietary and expensive. can buy a used dell from dell for less money. gateway will take no responsibility. this is my only and last gateway. can any of the parts work on another motherboard. and if I would buy a new board fro gway- whats to say it won't develop the same problem which they won't admit they have-so why would they fix something they say ain't broke?sucks!
  • Gav Shaw May 11, 2010
    Sounds like you have some sort of Hardware Power Failiure, which could explain why your problem seems to be getting worse each time you try to boot up. Either that, or some malware's probably been munching away on your Windows System Files, and is gradually deteriorating the longer the it's not been on your system.
    Do you get any Beeping Sounds from your System when you try booting up? If tyour not sure, next time u try to boot up, have a listen out for beeping sounds, and let me know if there was any, and if so, how many beeps you heard, and an estimate of the pause between beeps if more then one is sounded.
    Cheers
    Novelist:
  • 166 Answers
I went back last night and tried the holding power button in with no plug in and it did not work. I even tried the trick of freezing the computer. It would not perform the same way more than twice. Once I got beeps and start up but no video. Another time it started up and gave me video. Ran great when it did decide to start (twice in 4 hours). I got the customers data off, took about 30 minutes. However on trying to restart it through windows it would not do it. I am giving it the diagnosis of failing motherboard as the symptoms are random and with varying problems each boot. No rhyme or reason to when it would start. I could leave it sit for an hour or I could keep trying to turn it off and then on again. I have eliminated the power supply as I installed another (larger) PSU in and it worked the first time, but with limited success after that. I eliminated the memory as I removed it and it made no difference, the PC didn't even tell me (through beeps) that it had no memory. I eliminated the processor as it does not behave like an overheating or bad processor as when it did start it ran flawlessly. I eliminated the BIOS as I cleared the CMOS through jumpers and BIOS did not indicate problems- like I said when it booted it ran great - as if there were no problems. I elimnated the hard drive as I was able to get the data off no prob. So this all points in the direction of motherboard. I think we are both in the same boat.
Posted on Mar 10, 2009
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 162 Answers
Ok, I've just found the Troubleshooting page for Gateway Desktop PC's (this is based on the Windows XP System, so if you have Vista installed you'll need to get back to the main support menu). but I don't really think it really matters what OS is installed on the PC for the problems your having  Hopefully something in this long list of things to check will help you out :-)
http://support.gateway.com/s/Checklists/BPC/ck2007022634.shtml
Posted on Nov 30, 2008
    Novelist:
    Champion:
  • 233 Answers
Sounds like your power supply may be going bad.
Posted on Dec 16, 2008
Gateway Desktop GT5228 comes up with "Disk failure - insert boot disk". I cant locate boot disk due to moving. Will I lose data on hard drive???
Go to ur BiOS and check if ur motherboard can read the HD and set the boot up to HD first!
Tell me afterwards!
Nov 30, 2010 | Gateway GT5228 (7156) PC Desktop
Gateway 5228 wont boot no lights on keyboard
does it load the bios screen? Does it get to the windows load screens if it does go to the bios screen? Does the computer power on at all?
Sometimes what happens is the bios chip can be faulty or die and this will have to be replaced to fix the issue. If the computer is not powering on then it is more than likely a power supply issue.
(just in case, you might want to make sure that all of the adapters that come from the power supply are connected to the motherboard as well)
Sep 30, 2009 | Gateway Computers & Internet
Power Supply
If you are not getting even the Motherboard boot singal, then, its a power card issue. Please check the power cable to the monitor.
Regards,
HP
Aug 28, 2009 | Gateway GT5228 PC Desktop
Fan runs but will not boot.
Remove all external devices first like printers etc and then try again.
If it doesn't work then you will have to open the computer case side panel so we can start troubleshooting some parts.
If the machine has warranty then you should rather take it back before opening it.
when the case is open first make sure the power is disconnected and the case must be laid flat on the ground.
look for the memory RAM ,if you have two of them then try booting with one and vice versa ,if you only have one stick then remove it and reinsert it into the next available slot.
If that doesn't help then disconnect the data and power cables going to the harddrive and CD ROM drive.
The last option is to change the power supply ,if it still doesn't start then its most likely a motherboard or CPU problem.
Good Luck
May 06, 2009 | Gateway GT5228 (7156) PC Desktop
My gateway gt 5228 has power boots up but I have no picture on monitor and the keyboard doesn't work. Both monitor and keyboard work on another computer. what is wrong with PC
First disconnect any external devices like printers etc that you might have plugged in.
If that doesn't work then it's a problem inside the box it can be the power supply ,motherboard ,memory ,CPU and others.
If the PC has warranty then you should take it back.
If you are comfortable in opening your computer then we could try more advanced troubleshooting ,let me know if you want to try it.
Mar 28, 2009 | Gateway GT5228 (7156) PC Desktop
Boot into safe mode and see if you can either roll back the driver restore the computer to the date right before you downloaded it.  the link is for directions on how to boot into safe mode.   Another option , if you have on board graphisc alos is to hook up the monitor to the onboard  turn it on in BIOS and change the driver for the card using the onther graphics.
http://www.pchell.com/support/safemode.shtml
Jan 28, 2009 | Gateway GT5228 PC Desktop
Computer won't start normaly
This is most likely do to a bad stick of RAM.
Try taking out all but one stick of ram and try booting. If it still doesn't boot try changing the stick out with another one you pulled (might be the stick you left in that is the problem)
In the case that it is bad RAM go to your local computer shop and get some new RAM for the computer or check if Gateway will replace the RAM.
If there is any display that comes on the monitor such as a 2 digit code try searching that or posting here with the code.
Jul 20, 2008 | Gateway GT5228 PC Desktop
Network card driver
try to go to this link and download and install all drivers that applies. install the chipset first then you may install the rest of your device drivers:
http://support.gateway.com/support/drivers/search.asp?st=pn&param=1014951R
Jun 22, 2008 | Gateway GT5228 PC Desktop
Gateway GT5228 PC Desktop Logo
798 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
