Question about Toshiba Satellite A105 Notebook
Laptop won't turn on
My laptop won't turn on even though it is plugged into the adapter and the adapter plugged into the electrical otlet. Also there are no lights on my laptop lit showing that it is charging. Could i need a new battery?
    Problem Solver:
  • 17 Answers
Try removing the battery and the power cord. Press the power button for about ten seconds. Sometimes a residual charge somewhere in the power circuit causes this problem and by pressing the power button it drains away. reconnect battery and power cord and switch on. this works for about 50% of the power problems that I have come across.
Posted on Dec 02, 2008
    President:
  • 2,110 Answers
No I think U have problem with ur mother board..
Posted on Nov 29, 2008
My Asus LaptopModel X205Ta is fully dead and won't charge or turn on.
MF. Could be the new charger is faulty, return charger for exchange or refund. Battery could also be faulty, have it tested if you can by a computer tech. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
My laptop notebook will not turn on
my asus laptop wont even charge or turn on after it shut off mid windows...
Laptop Won Come On Even When Connected To Charger
Why Won My Laptop Turn On Even Though It Plugged In
Jul 09, 2016 | ASUS Computers & Internet
Dell inspiron not charging
Dear Mathew,
You should you Dell Utility and it has the function called Dell Battery Metter, it can enable or disable charging
Nov 12, 2012 | Computers & Internet
My laptop not charging
When you say it won't charge, does it charge at all?
1. It indicates that it is charging, but as soon as you unplug the charger the battery quickly or immediately indicates it is dead. If the laptop is off, the LED on the laptop shows it is charging but the battery is always dead,
Or: 2. It is as if you didn't have the charger plugged in. No light on the laptop at all when the charger is plugged in.
Possible solutions:
1. The battery has died and is no longer capable of taking a charge. An alternate explanation if you can't even get the laptop to turn on even though the laptop charge LED is on, is that the internal power supply that converts the incoming and battery voltage to all the voltages required has died.
Or: 2. The power connector inside the laptop is a common failure point. The solder joints break from various minor shocks over time. This is going to become more common with lead-free solder as it is more brittle. Less likely is that the charging circuit inside the laptop has failed.
http://www.chargerbuy.com/laptop-ac-adapter/universal-ac-adapters.html
Oct 28, 2012 | Computers & Internet
Dell inspiron 1520 won't turn on.
Remove the battery from its compartment on the side of your Dell Inspiron laptop computer.
Remove the power adapter from its plug on the side of the Dell Inspiron (if your laptop is currently plugged into a wall outlet).
Press down and hold the "Power" button on the laptop for one to two minutes. This will dispel the excess electrical current that is built up inside the laptop.
Put the battery back inside the compartment of your Dell Inspiron.
Plug your power adapter back into the side of the Dell Inspiron. Press "Power." Your laptop computer will now turn on.
hope this helps
Oct 08, 2012 | Dell Inspiron 1420 1501 1520 1521 1525...
My hp pavillion laptop will not charge my battery . It won't even work without the battery but plugged in with power supply even though i know battery and power supply are sound.
It won't ever be a 'software' issue....it will be either a :
Adapter/Charger issue (Have it tested by local PC repair shop.)
if it is good, then it is the other prob. If it is not good, then buy a new one.
OR
Laptop power connector issue. (expensive repair.)
Sep 06, 2012 | Toshiba Satelitte M300 St3401 Core 2 Duo...
Laptop won't come on even when plugged to wall outlet
you will likely need to remove the battery pack to run the unit. If this works, you will need a new battery to use the laptop portable.
Jun 09, 2012 | Acer Computers & Internet
My laptop won't turn on, and the charger doesn't seem to be doing anything. even when plugged in, it won't start. ideas?
You've to replace the ac adapter, if it's brick doesn't get warm or LED does not glow on Power Jack on the laptop. offcourse, check with the wall different sockets
power jack can also be loose. so jiggle the cable to find out.
if notebook is getting power, you can remove the battery, ac adapter, hold and keeep pressing poer button for a minute, then, turn it on.
finally, you can take out hdd and ram, put them back again and turn on the laptop. hope it will help
Sep 17, 2011 | Compaq Presario CQ60-220US PC Laptop
My Dell Latitude D160 won't respond at all. I have to constantly push the power on button to even get it to come on and when it does, the battery light is on red and I think it says low critical power...
I'm confused too... it sounds like the power adapter is not (electrically) connecting to the laptop or the adapter is not delivering proper voltage/amps to the laptop.
You shoud 1. make sure that the AC plug is properly in the AC socket, 2. that the AC cord is (mechanically) connected to the adapter, and 3. that the adapter is (mechanically) connected to the laptop.
I cannot tell you how many laptops I have seen where the (internal) power connector breaks as a result of (typically) mis-handling, dropping, etc. Try (gently) wiggling the adapter connector and look for the LED changing colors.
You could also test the voltage output of the adapter with a standard Volt meter...
Sep 13, 2011 | Dell Latitude D610 Notebook
Dell Inspiron 1521 battery not charging
Laptop batteries power a laptop when it is not connected to an electrical outlet. If the laptop battery fails to charge when the laptop is plugged into an electrical outlet, the battery is likely dead and needs to be replaced. Unfortunately there is no way to fix a dead battery. However, while a dead battery is the likely cause, it is not the only cause. The AC adapter may be broken, in which case the battery won't charge, or the battery contacts may be dirty and need cleaning. Prior to replacing the battery, perform simple tasks to ensure a dead battery is the cause of the problems.
1.Power down the laptop. Gently pull the AC adapter from the side of the laptop for removal.
2.Place the laptop in front of you, bottom side up. Locate the battery release mechanism. This can be a button that slides or needs to be pushed to unlock or release the laptop battery from the housing unit. Press or slide the mechanism. Slide or lift the battery from the battery bay for removal.
3.Insert the AC adapter into the side of the laptop. Power on the laptop. If the laptop does not power on, ensure the AC adapter is securely plugged into a working electrical outlet. If the electrical outlet is working and the laptop won't power on, the AC adapter is not properly working and needs to be replaced. Remove the AC adapter.
4.Dip a cotton swab in a small amount of rubbing alcohol. The cotton swab should be damp, not dripping wet. Lightly rub the dampened cotton swab onto the battery contacts and battery bay contacts to remove dust, buildup and grime. Allow the contacts to air dry.
5.Align the battery over the battery bay. Either press or slide into place. A clicking or snapping noise produced from the locking mechanism will confirm the laptop battery is securely locked into place.
6.Install the AC adapter. Allow the AC adapter to fully charge the battery for 8 hours.
7.Remove the AC adapter. Power on the laptop. If the laptop does not power on, the battery needs to be replaced.
Sep 01, 2011 | Dell Inspiron 1521 Laptop
My laptop won't charge. I have an acer aspire 5315 that won't charge, I had problems with the charging adapter before so I thought that was the problem and replaced it, the replacement worked for...
For a test -Remove the battery from the laptop. (leave it out) -Plug in the adapter and turn the laptop on. -Gently wiggle the adapter plugged in
If the computer powers off the solder and/or pins have broken loose from the DC jack. This is very common. Average repair bill is around $150, if your in the Denver Colorado Area I can do the repair for about $50
If it won't turn on while you wiggle the adapter and hit the power button then the adapter is bad again sadly
Jul 09, 2011 | Acer Aspire One Netbook 8.9" Notebook
Toshiba Satellite A105 Notebook Logo
112 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
