Question about Canon Digital Rebel XT / EOS 350D Body only Digital Camera
My 350D cannot take a picture
its just happen recently on my canon 350D, where suddenly the shutter button become difficult to take a picture.
For halfpress (autofocus) it stil working fine, but when you try to press it harder it seems not trigger the shutter to take picture.
anyone can help me to fix this?
personally I would like to fix it by myself, since I think maybe just some loosen connection or something, and also because my local canon service center put high cost to fix camera which not purchased locally :(
Thanks a bunch!
Regards,
Sucipto
  • Canon Master
  • 13,433 Answers
Hey, it sounds like the button might be faulty,
you can get a free repair estimate from www.advancecamera.com/repair
Posted on Nov 29, 2008
My daughters 350d will only take pictures in manual focus mode, in auto focus it all seems good but it won't actually take the picture? Any ideas?
Shutter Assy, Mirror Assy or Shutter Button taken a coffee breaks.
You did try using a new battery?
Or your battery is not over 3 years old?
If I can help, just send me an email.
atdlee@netzero.com
Dec 30, 2012 | Canon Rebel XT / EOS 350D Digital Camera
I am not able to shoot with my canon 350d using the shutter release or the clicking button. All that is happening is that when I switch on, it just keeps shooting and when I try to use the shutter release...
Remove the battery and memory card, press and hold power for 60 seconds to remove residual voltage and reset the processor, if there is no change a camera repair shop is the next stage for assessment.
Jul 08, 2012 | Canon Rebel XT / EOS 350D Digital Camera
My Canon Rebel XTi seems to randomly take shots and more often not. Any idea what could be causing this?
If the camera appears to be working properly in some pictures and not others I'm going to suggest you look at your Shooting Modes. It's very possible that the mode dial has been turned to the TV mode which is Shutter Priority. With the Rebel having a shutter speed of 30 seconds to 1/4000 you may click the shutter to take a pictures and the camera appear not to take the picture. A few seconds later the shutter closes and the mirror drops. This also can happen if you are in the Night Portrait mode. The length of time my be longer if the lens cap is immediately placed on the lens.
Change your mode to "P" program until you become more familiar with the camera functions and settings
Dec 10, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Auto focus my canon d1000
Press the shutter button half-way and listen for the beep...then push the rest of the way to take the picture.
Mar 15, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Err 99 in canon 350D
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Apr 06, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rbl XT out of focus in viewfndr when shutter half way down
It's possible that the reason the "pictures turn out fairly good" is that your f-stop is set high enough that even though the image isn't properly focused, you have enough depth-of-field to bring your subject into "near focus". Does your lens try to focus back and forth when you half-press the shutter? If not, double check that the lens is in autofocus and not manual focus. You can also try cleaning the contacts between the lens and camera. Take the lens off, and then one-at-a-time clean the contacts on both the lens and the camera, using a clean pencil eraser. Gently rub the contacts. Be sure to hold the item upside down so that the eraser debris falls on to the table, not into the camera body or lens!
If none of this helps the autofocus may have become damaged and you need to have the lens and camera looked at by Canon Repair.
Jan 10, 2009 | Canon Digital Rebel XT / EOS 350D Digital...
Digital rebel / SLR photos are nearly all black
If the camera still "operates normally" with recorded pictures while they are all black, you try to select CMOS Cleaning to see if the shutter really opens or not. If not, a plastic lever operates the first set of curtains had broken. This could be common for all plastic shutter except EOS 1 series which use metal.
Sep 28, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Shutter button not working
This happens to me on occasion. I pop the battery out and it works fine after I put it back in.
May 10, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Shutter release lag
I suspect a chip in the circuit is heating up and slowing the processing down. It may be a problem that Canon can solve for you. They might even have a modification for it already. Either way you should take it directly to Canon and have them look at it.
Apr 29, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Open Questions:
See all Canon Digital Rebel XT / EOS 350D Body only Questions
Canon Digital Rebel XT / EOS 350D Body only Digital Camera Logo
32 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
