Question about HP LaserJet 4350DTNSL Printer
Setting Saving Problem
If I want to change the ip and then click for saving it. It shows the message that Setting Saved but after a minute then saved setting is clear and it goes back to its previous state. In Short, The printer is not able to save any changes.
  • 62 Answers
Try printing a configuration page on the printer to see if the IP address is the same, if it is, the it might be the network
Posted on Apr 22, 2007
How do set the time and date on machine
Press and hold CLOCK until the message window displays C, and the default day is announced.
To change the day setting, press MEMO/REPEAT or ANNC/SKIP until the correct day is announced.
Press CLOCK. The current hour setting is announced. The correct day setting is saved.
To change the hour setting, press MEMO/REPEAT or ANNC/SKIP until the correct hour is announced.
Press CLOCK. The current minute setting is announced. The correct hour setting is saved.
To change the minute setting, press MEMO/REPEAT or ANNC/SKIP until the correct minute is announced.
Press CLOCK. The current year setting is announced. The correct minute setting is saved.
To change the year setting, press MEMO/REPEAT or ANNC/SKIP until the correct year is announced.
Press CLOCK. The new day, time and year are saved. The correct year setting is saved.
To check the clock, press CLOCK.
The above is from page 5 of the manual at
http://att.vtp-media.com/ecp/documents/product_Product/223/UserManual/944/1739_manual.pt2_i6.pdf
Jun 21, 2011 | AT&T ATT1739 Digital Answering Machine
I have nokia n70 i can type or send messages when i m saving messages in phone memory but if i change setting to save messages to memory card then i m not able to type or even open the inbox.....plz help
possibly problem with your memory card..try formatting it but be sure to backup your data saved in your phone..if problem remains there try changing your memory card..
Apr 26, 2010 | Nokia N70 Smartphone
Gprs setting problem
if you are using Airtel then use the following: Name Mobile Office IP address 202.56.231.117 Proxy Enable Proxy port 8080 APN airtelgprs.com Others you can give any values. If some other service provider then ask their helpline and set them up manually.
Sep 07, 2009 | Nokia 6300 Cellular Phone
Text messages saving to sim rather than phone
go to msgs then settings.
msgs will be saved in your sim first and when the max of msgs in your sim was reached then it will be the time that msgs will be saved in you phone.ü
Apr 08, 2009 | Samsung SGH-E900 Cellular Phone
Model 1739 answering machine
Set the clock
You must set the clock so that the system announces the correct day and time with any incoming messages. After this, if you subscribe to the caller ID service, the system will update the clock eac h time new call information is received. Press PLAY/STOP to exit at anytime while setting the clock.
1. Press and hold CLOCK until the message window displays C and the default day is announced.
2. To change the day setting, press
3. Press CLOCK. The current hour setting is announced. The correct day setting is saved.
4. To change the hour setting, press
5. Press CLOCK. The current minute setting is announced. The correct hour setting is saved.
6. To change the minute setting, press
MEMO/REPEAT or ANNC/SKIP until the correct minute setting is announced.
7. Press CLOCK. The cu rrent year is announced. The correct minute setting is saved.
8. To change the year setting, press
MEMO/REPEAT or ANNC/SKIP until the corr ect year is announced.
9. Press and release CLOCK. The new day, time and year are announced. The correct year setting is saved.
Jan 08, 2009 | AT&T 1717 Digital Answering Machine
Xerox Documate 252, just quit working
The flashing green light has the following meaning:
• Blinking green: indicates the scanner is waking up from power
saving and preparing to scan.
• Steady green: indicates the scanner is ready to scan.
How to Adjust the Power Save Settings for the DocuMate 252
1. Right-click on the One Touch icon and choose Show
Hardware from the pop-up menu.
You can also click the scanner icon at the top of the One Touch
Button Panel.
If the Hardware View of the panel is open you can also right-
click on the DM252 icon.
The Hardware Properties dialog box opens and shows
information about your Xerox DocuMate 252 scanner.
2. Click the Properties button.
Your scanner has a built-in power saving feature that is set to
power down after 15 minutes of idle time. You can change the
time before the scanner powers down, from 1 minute to a
maximum of 3 hours.
3. Click the arrows for the Lamp timeout setting and choose a
time setting.
To return the scanner to its factory settings, click Reset Device.
4. Click OK to save the changes and close the dialog box.
Let me know if this solves the problem and thank you, Binary Bob
Dec 09, 2008 | Xerox DocuMate 252 Path-Through Scanner
HP LASERJET 3055 Manual IP Address not saving
Try flashing the firmware: one of the fixes is this - (Improved IP address management of DHCP to Manual changes).  See link below. Firmware
Gerben People tend to evaluate events in light of their paradigm rather than evaluate their paradigm in light of events.
Sep 27, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Switch off the printer and press * & enter key together &switch on wait till you see " permanent storage int"
then release button your printer comes back to original defaults
then re-configure printer as you require
Murali,
PALLAVI INFOTECH
BANGALORE
Jul 16, 2008 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055 unable to save IP setting
i can solved this problem please give me one chance
Jul 05, 2008 | HP LaserJet 3055 All-In-One Printer
Saving messages on the K88i
Go to message setting and set ur message memory to memory card.And ur done
Regards
Sandeep
Nov 12, 2007 | Sony Ericsson K800i Cellular Phone
HP LaserJet 4350DTNSL Printer Logo
99 people viewed this question
Clive
Clive
