Question about Samsung HL-R4266W 42" HDTV-Ready Projection Television
Samsung HL-R4266WX 42-Inch
Lamp light flashes even after unplugging. We have tried replacing lamp but it continues to not work. Any suggestions would be great. Thank you.
  • 98 Answers
You need to check the SMPS(80%) or Main Board(20%)
( possibility ratio)
Posted on Mar 03, 2009
I have a 50 inch DLP samsung and it wont power on after making a lot of noise (I replaced the lamp) worked fine for a few days now the red light and the right side green light is blinking. any sugge
The answers above are correct. It's either the lamp or the color wheel. Testing the lamp is pretty straight forward. Use an Ohm meter to see if the it's filament has continuity. It's unlikely that a good color wheel would fail immediately after changing the lamp. Look to see if some wiring is out of place and rubbing the wheel causing the noise you described. A jammed but otherwise good color wheel would cause the TV to shut down and display an error code.
Sep 12, 2014 | Samsung HL-S5087W DLP TV
Samsung DLP HL-S5087W 56" Confused...
Those lamps can be pretty touchy and susceptible to temperature changes and finger prints. Also some discount lamp dealers can accidently sell you the wrong lamp. Something simple and dull to try is to take that lamp out and put it back in, check that the connections are seated properly and the air pathway from the fans is clear.  If the fans were dirty and you put in a new bulb that worked for a while it may have burned out prematurely.
May 17, 2008 | Samsung DLP HL-P5663W 56" TV
Lamp light flashes then stops. no picture. samsung HLS4266WX/XAA
Was the trouble exactly the same before lamp and wheel were replaced?
If lamp comes on for 3 minutes what do you see on the screen?
the more you tell me the better I can assist you.
Mar 14, 2012 | Samsung HL-S4266W 42" HDTV
Have a 50 inch hlp506w model samsung projector tv. it had wavy lines through it, and then turned off. it is continuing to try and turn on with the standby/temp and lamp lights flashing. replaced lamp...
Change the tv Ballast board too.This board only job are to help it to ignite the tv projection lamp. This tv also have a colors wheel design into it too.If tv have colors pictures flashes or Black& White flashes within it pictures or tv have grinding noises or humming sounds,than the tv colors wheel it is warp and dead.This tv colors wheel must be replaced,because the colors dis wheel is warn out.
Jul 05, 2011 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung HL-S5679W won't start - LED light blinking
Replace Lamp,but CK to make sure Fans are running if OK then replace Lamp Mats Has them for 99.00
1-800-628-1118
May 11, 2010 | Samsung HL-S5679W 56" HDTV
My samsung 42 inch hdtv is making a buzzing noise
First. The whirring or buzzing sound you hear is the Color Wheel and it needs to be replaced. Second, since I do not know when and if the original lamp has been replaced it is a good idea to replaced the lamp. The bad Color Wheel is the one causing the set to shut down.
Apr 04, 2010 | Samsung HL-R4266W 42" HDTV-Ready...
Lamp goes off and tv shuts down after lamp replacement
CK FAN on LAMP,or you could have problem with Ballast.
Aug 11, 2009 | Samsung HL-R4266W 42" HDTV-Ready...
Dlp tv problem
Is the lamp light the only one thats flashing? Does the buzzing your hearing stop or is it constant? Also when you press power off does the buzzing stop instantly or continue? Respond to this post and I will try to assist you. Is HL-R677w the correct model number also?
Jun 21, 2008 | Samsung HL-R5677W 56" HDTV
Samsung 42 inch projection
HLP, HCN HL-S The Start-up Problem or/and
3 LEDs in the front blinking.
Unplug the set, pull out the lamp module (not all the way - leave it on the track) and push it back in.
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Feb 07, 2008 | Samsung HCN4226W 42" Rear Projection...
Open Questions:
Samsung HL-R4266W 42" HDTV-Ready Projection Television Logo
115 people viewed this question
Jerry Greenberg
Jerry Greenberg
