Question about Kenmore Dryers
Sears Kenmore Dryer. Model/stock no. 76691100 belt is broken, and a pulley attached to a spring steel L with a 90 deg bend is unattached from the machine. Joe
  • 116 Answers
RE ATTACH IDLER PULLEY TO GROUNG ONLY 1 WAY TO FIT RUN BELT THROUGHT PULLEY IDLER AND BEND BACK TOWARDS MOTOR TILL IT ATTACHES TO MOTOR THAT ITS
Posted on Nov 30, 2008
11076812693 drum won't turn.
Kenmore Dryer Model 110.76812693 (11076812693) Drum ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Drum-T...
Kenmore Dryer Model 110.76812693 (11076812693) Drum & Tub Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Kenmore Dryer Model 110.76812693 (11076812693) Motor ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Motor-...
Includes pulley for dryer drum drive belt. Other shaft has reverse threads for blower wheel. Common symptoms of a bad drive motor are: -Dryer stops turning ...
Kenmore, Whirlpool Dryer Repair - Heats properly, drum will ...
? 6:29
https://www.youtube.com/watch?v=bOShDc4kLfk
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Service a Kenmore Dryer with some of the following issues: Heats but ... Kenmore, Whirlpool Dryer Repair - Heats properly,drum will not turn - 11068202794 ..... Whirlpool Kenmore Maytag Amana Dryer Won't Start - Easy Fix ...
How To Fix Dryer That Won't Tumble ' Dryer Repair
www.partselect.com/Repair/Dryer/Will-Not-Tumble/
Feb 08, 2016 | Kenmore Dryers
Hi. I have a Whirlpool dryer Model le5800xsw3. The drum stopped turning so I opened the front panel, thinking that the belt was broken. Turns out the belt was fine but the idler and pulley assembly...
The ***. has an edge that fits into a slot on the bottom .The other side goes into another slot.check the internet for your dryer belt config.
Sep 24, 2010 | Whirlpool Dryers
Hey there i got a broken belt from old kenmore dryer model i dont see what model is it but i found a piece of paper with a part no. i dont know i u can gimme a good awnser also i find the paten number
You're really going to need the model number of the dryer to determine if the piece of paper has the part number for the belt that your dryer needs. If you find the model number info - you can go to Sears Parts Direct to check for a replacement (or go to the store).
You may get some help by bringing the belt to a Sears or Kmart store to compare to other belts that they have in stock. The length of the belt isn't super critical as the tension-er pulley can make up for small differences between your old belt and one that is "close".
I hope this helps!
Sep 14, 2010 | Dryers
The idler pulley on an older GE dryer does not tension the belt. The idler pulley is mounted on a spring rod, but the rod's neutral position does not tension the belt. The rod is attached to the bottom of...
Do not bend the rod you are not threading the belt right I had the same problem with one. Try searching the internet for how to thread the belt on a GE dryer. It has to go around the pullys a different way. Hope this helps.
Jun 04, 2009 | Kenmore 60172 Electric Commercial Dryer
My kenmore clothes dryer has stopped spinning and is just making
The pulley in question is likely a spring loaded idler pulley, used to keep tension on the belt. It likely hangs onto the dryer's frame, & is held in place by the belt. If you order a new belt from Sears, ask them for a belt path diagram, which should show the proper pulley position.
Apr 17, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Installing the belt around the dryer drum and pulleys. I have a broken belt and a loose pulley at the bottom of the dryer. How to I get the pulley on? Where does the pulley attach to create the proper...
you will have to take the drum out to see where the tentioner was inserted , it is in line with the motor pulley, should be a couple holes it fits into.
putting the belt on is easy , with the lined side of the belt down on the drum take the slack at the bottom with a finger holding the belt , move the belt toward the tentioner until it touches the tentioner pulley
then with your other hand help bend the tentioner pulley with the belt on it until you can touch the motor pulley with that finger , slide it off your finger onto the motor pulley and the belt is on.
let me know if you have any questions.
Phil
Apr 14, 2009 | Dryers
I have a kenmore 90 series dryer, the drum belt broke, bought a new one, but cant figure out how to get it on, too much slack in the belt, not sure where it goes on
REMEMBER BELT GOES AROUND IDLER PULLEY AND ATTACHES TO MOTOR SHAFT ,PULL BELT W/ HANDRUN BETWEEN ROLLER, AND PULL BACK AND ATTACH ON MOTOR PULLEY AND THAT ITS
Jan 02, 2009 | Kenmore 64952 Electric Dryer
Can't get replacement parts back on Kenmore 60 series dryer.
The belt has groves, right? Make sure the groves go over the motor pulley from the right. The idler pulley is spring loaded. Place the belt around the idling pulley with the smooth side of the belt on the pulley. This should work.
Dec 24, 2008 | Kenmore 62602 Electric Dryer
Kenmore dryer
The pully fits in some groves at the bottom of the motor shaft , the pic should help 9b7b31e.gif
Oct 13, 2007 | Kenmore 64952 Electric Dryer
Dryers Logo
48 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
