Question about Infinity Overture 1--Single Speaker
Amplifier don't switch on
I have a infinity overture 1 active speaker system what don't switch on.
If i put the power on the red led is not complete on and the amp switch not on to green led. I also don't hear the relais come's on. The fuse is okee. I can't see anything wrong or burn inside. The woofer is okee.
I see its een commen problem.
Do you have any idea?
Sorry Englisch is not my native langue.
Thanks
Floor Mensonides
Amsterdam
Holland
SOURCE: bypassing the 150 watt blown amp with passive crossover
3/4 update: i bypassed the 300w amp on my first ovtr3 with a cs3006 crossover i purchased on ebay. the input wires at the base of the speaker were connected to the input of the crossover, the bass output of the new crossover was connected to the yellow/yellow-black lf+/lf- wires that used to leave the old 300w amp. the high freq output of the new crossover was directly connected to the leads coming from the speaker's tweeter (running the midfreq outputs from the new crossover to the input of the speaker's old crossover is no good, since the midfreq output of the new crossover would rolloff and provide little high freq to the tweeter). The mid-freq output from the crossover was connected to the input of the old crossover that came with the speaker (alternatively, i could have wired the mid freq output from the new crossover directly to the midrange speakers, but i figured the old crossover might have had some characteristics that would have been helpful. the result is better than i hoped for! true, the bass is not quite as floor shaking as before (and you need an amp that can boost +5-+10db below 350Hz and rolloff the boost above 350Hz), but the end result is more than satisfying and gives these speakers new life. I am using a Sony receiver that puts out around 200W for the front speakers.
Posted on Mar 04, 2008
SOURCE: infinity 3.5c , 2 powered Woofer 5.25" suddenly no sound.,
The woofers on my 3.5c stopped working, but with mine the light was off. I unplugged it and left it for about 24 hours and then plugged it back in and it worked. No idea why. It's happened twice and each time takes at least 12 hours or a day or so before it'll work again, just unplugging it for an hour won't do it.
It seems like both times the problem started when the speaker got unplugged without it being shutoff first, but I can't confirm.
But if your light is still on it's probably a different problem. With my 4.1t towers when the light was on but there was still no sound it equated to numerous fried amp components which cost about $150 for repair.
Posted on Apr 10, 2008
SOURCE: Infinity Entra Sub 150 no sound or power
I had the same problem. When I opened it up, the fuse was blown, and it was a pain to find the fuse it needs (3 Amp, 250 V slow-blow fuse, 5x20 mm). Also, the 2 large electrolytics (big purple things near the amp) and one small capacitor were all blown. For 4 fuses, bought seperately from, and the 2 electrolytics and 1 capacitor, it cost about $20, plus almost 20 more in shipping, which still isnt bad considering the original price of the sub. However, the tricky part is that you have to know how to use a soldering iron to take out the old components and put in the new ones.
Posted on Mar 23, 2009
  • 32 Answers
SOURCE: Infinity 2 overture speakers- 1 wasn't working so
Verify that the bass levels are set the same on each speaker. If they are and the problem occurs on all program material, you most likely have a bad driver or amplifier in the speaker. One other thing to verify is that the balance or output levels of the left and right main speaker outputs are set equally on the receiver.
Good Luck,
BB
Posted on May 16, 2009
Grubhead
  • 5349 Answers
SOURCE: My Infinity sub-woofer for my home surround sound
Open it up and see what is in there! You might find a fuse blown. It might have just blown, without a fault, if you are lucky. If not check out the part numbers on the amp board. All semiconductors numbers, then put the numbers into google. You will soon find out if they are obtainable!
Posted on Jan 20, 2010
How do you reset the infinity? where the power button?
Most car audio amplifiers don't have on off switches.
So to reset the amplifier, disconnect it from the power source, from the car battery side.
Disconnect the positive side (red) first. Then the negative side (black)
Or sometimes its easier to remove the fuse next to the battery for the amplifier.
After its disconnected leave it disconnected for approx 5-10 min.
I hope this helps
MobileJB
Jul 13, 2011 | Infinity Reference 5350a Car Audio...
Amp blown from power surge and need new amp for ovtr-1 powerd speaker were can i get one cheap
  • If it were me i would go with this. http://www.apexjr.com/inf.html $60usd not a bad deal and it looks like they throw a crossover in with it. It is actually the amp meant for your speakers.
Regards, Tony
May 01, 2011 | Infinity Overture 1--Single Speaker
My WHARFEDALE DIAMOND SW150 SUBWOOFER does not work. the light (red) comes on when connected. but no sound. I've tried direct from speaker and from receiver connection. doesn't work. Any advice
After finally finding the circuit diagram for the Wharfedale SW-150 sub woofer, I've managed to identify and fix a fault which has the same symptoms as yours.
The problem was with the largest of the two relays (Relay 1 in the attached photo).
The circuit has two power rectifiers, the first rectifier provides the small current for the system to operate in standby. Relay 1 is normally closed and this turns on the secondary power rectifier that powers the amplification circuit.
Relay 2 (smaller and black) is used to prevent the speaker from popping every time the auto-power switches on/off, it uses a delay to allow the amplifier to stabilize before activating the relay which connects the amplifier to the speaker.
On my system the power LED was lit, but the little click that happened about 2 seconds after power-on, was no longer heard. The little click that was missing is the sound of the smaller relay connecting the speaker. This relay was not activating because the amplification circuit had not been powered.
The larger relay does not need to activate to turn on the amplifier, as it is normally closed, meaning the the default connection state is to provide power to the amplifier. The relay is only used to disconnect the amplifier when the auto-off feature kicks in (or the system over heats). I could test this relay was clicking by connecting pins 1 and 3 on the temperature switch connector.
So the relay was not connecting properly in the closed state. This is what the relay looked like on the inside.
Mar 16, 2011 | Wharfedale SW150 Subwoofer
Why does the red light click to green without the speakers on?
That system responds to signal input, ie an electrical signal present on the input, in order to turn on the internal amplifier. If it is turning green without any input from the source, it could require service. It may be responding to static electricity...
The speaker should go to sleep after ten minutes or so, turning from green to red again.
Jan 13, 2011 | Infinity Overture 2 Speaker
Infinity 2 overture speakers- 1 wasn't working so I replaced the fuse. Now it works but doesn't have the same sound output as the other. Any suggestions?
Good Luck,
BB
May 16, 2009 | Infinity Overture 2 Speaker
Sound loss
bad system cofiguration too much load on rea amp
May 11, 2009 | Infinity 475A Car Audio Amplifier
New Dual XIA3145 2/1 LED glows red, guide claims speaker problem
look at these and only these... power or ground...either your power wire has grounded out somewhere (ud be surprised) or youdont have a good enough ground....i would check the ground first....hopefully this helps
Jan 27, 2009 | Dual (DBXPA6100) Car Audio Amplifier
Rt 202 led light red and no sound
With the system turned off, disconnect the speaker wires from the amplifier. Turn on the system. If the light stays red, then the amplifier has an internal problem. If the light turns green, then your problem is a blown speaker, or a speaker wiring issue.
Jun 03, 2007 | MTX RT202 Car Audio Amplifier
88 people viewed this question
Top Infinity Audio Players & Recorders Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you an Infinity Audio Player and Recorder Expert? Answer questions, earn points and help others
