Question about IBM ThinkPad R40 2722 Notebook
When i turn on my laptop, the screen is blank
I have an ibm thinkpad r40 laptop. when i turn it on, sometimes it beeps 3 times(one long, two short) and the screen remains blank. Other times, when i turn it on, the ibm screen comes on, but it starts to flicker and then lines start to apperar on the screen and it goes blank. What is wrong with my laptop? Is it something that i can fix or will i have to get it repaired?
  • lolo029 Mar 14, 2009
    I have an ibm thinkpad r40 laptop. when i turn it on, sometimes it beeps 3 times(one long, two short) and the screen remains blank. Other times, when i turn it on, the ibm screen comes on, but it starts to flicker and then lines start to apperar on the screen and it goes blank. What is wrong with my laptop? Is it something that i can fix or will i have to get it repaired? I have placed new memory.
  • zainulabi295 Apr 06, 2009
    President:
  • 2,110 Answers
It seems to be u have problem with ur RAM ..Try to change it
Posted on Nov 29, 2008
How can i fix my IBM ThinkPad T22 2647. it produce 3 simultaniuos beep sounds lcd is black out.
This is a list of ThinkPad Beep codes.
It appears you have a memory or motherboard problem, most likely a RAM problem. Try reseating the RAM modules, if this doesn't work, then remove the RAM and take them to your friendly computer repair shop to get them to test the RAM modules for you. If the RAM is faulty them replace.
Beep symptoms
Symptom or error
Service part or action, in sequence
One beep and a blank, unreadable, or flashing LCD.
  1. Reseat the LCD connector
  2. LCD assembly
  3. External CRT
  4. System board
One long and two short beeps, and a blank or unreadable LCD.
  1. System board
  2. LCD assembly
  3. DIMM
Two short beeps with error codes.
POST error. See Numeric error codes for more help.
Two short beeps and a blank screen.
  1. System board
  2. DIMM
Three short beeps, pause, three more short beeps, and one short beep.
  1. DIMM
  2. System board
One short beep, pause, three short beeps, pause, three more short beeps, and one short beep.
  1. DIMM
  2. System board
Aug 06, 2010 | IBM ThinkPad T22 2647 Notebook
My IBM ThinkPad T41 screen won't turn on. it only beeps 3 times. thats all it does
One long two short beep? Sounds like the common Video issue. You can try the reflow method. Look it up on yourtube or you can get the reflow guide from www.msbin.com
Jun 14, 2010 | IBM ThinkPad T41 Notebook
Problem with ibm thinkpad r40
The IBM beep code error 1 long 2 short beeps means there is a video card fault. Reseat your RAM because the video card uses some of the RAM. If it doesn't work then the video chip on the motherboard is faulty, the only way to fix is to replace the motherboard - this may not be a cost effective solution.
Connecting an external monitor to the laptop won't work because the video card also sends data to the video port.
Apr 06, 2009 | IBM ThinkPad R40 2722 Notebook
Blank screen ibm r40e
This is generally a memory problem. Remove the memory, and try them one chip at a time in each slot. If the memory isn't the issue, then try removing the battery and starting with the supply only. Both battery and memory can cause this, but the beep code is generally for the memory, no beeps with the battery. If both check good, then test the power supply with an ohm meter for the proper output. If these three check good, then the problem will lie within the motherboard, and you will need to take it in for a professional diagnosis in order to track down the exact problem area. You might also look on IBM's support site for the beep/sound error codes and any troubleshooting for the exact code you have.
Aug 12, 2008 | IBM ThinkPad R40 2722 Notebook
IBM ThinkPAd feezing & screen not working
I have about 50 IMB Lenovo ThinkPad R40 at work, this "defect" comes if in use every day, from 1½ year to 2 years.
I have tried to fix it, but have to admit that I have found my superier.
Buy yourself a new one here for xmas.
Dec 27, 2007 | IBM ThinkPad R40 2722 Notebook
IBM T41 Thinkpad, not working properly
Do a system restore to a week or two before this all happend otherwise it may be the Hard drive starting to go bad if doing a system restore don't help and also you should run your antivirus and spyware Hope that helps you out
Dec 24, 2007 | IBM ThinkPad R40 2722 Notebook
Blank Screen
ccfl ( cold cathode flouroscent lamp ) is the backlit feature of the lcd panel. If you see a blank screen but do see the output on the external monitor then you sure have to take it to the hardware tech to get the inbuilt LCD panel checked. it seems to be a electronic failure. Thanks Ashish.
Sep 21, 2007 | IBM 11P836402 for ThinkPad R40 Monitor
IBM ThinkPad R40 2722 Notebook Logo
1,007 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
