Inglis Washing machine not spinning
I replaced the transmission and water pump on an Inglis Wahing machine and now it doe not spin any more.
Can you help me?
  • leftywedge Dec 02, 2008
    JR JR,
    on the money! Forgot to remove the parts from the old transmission.
    Thanks.
    LW
  • 116 Answers
DID YOU REPLACE THE THRUST BEARING LOCATED UNDER NEATH TRANSMISSION, PLASTIC AND ROUND THAT BELT GOES ONTO ,, THAT SHOULD FIX UR PROBLEM
Posted on Nov 30, 2008
Frigidaire washing machine (FTW3011KW0) runs through all cycles, agitates, pumps out water, but doesn't spin, nor does the motor attempt to spin during the spin cycle
Your main switch needs replaced. The motor that drives the switch operates because it goes through the other cycles, so the switch must be bad.
murf427
Jul 31, 2012 | Frigidaire Washing Machines
Washer stop
My first thought Lid switch gone bad. This washer has a motor which reverses. The motor is a double shaft design. 1 end of that motor drives the transmission and the other end drives the pump. When moving in one direction the tranny agitates them clothes and the water cannot be repelled out of the washer. On spin cycle the motor goes opposite directione and tosses out that water while spinning the drum. Later models have a fancy spin pawl which allows them pump to empty that water and lessen the strain on the motor. If that safety lid switch don't act right then them washer will be dead in da water during dat rinsing cycle. Now here is a wondermous vido i found on dat new fangled world wide web from repair clinic the most wondermous site to buy them parts for this washer.
More good stuff HERE
Visit my forum and I might told you a story: Here
Jun 19, 2010 | Whirlpool Inglis IP4400 Washer
Tub does not spin. water pump works but no spin
  1. does the machine agitate? if no replace drive coupling between motor and transmission.If yes you have either a bad clutch or transmission.
  2. Remove cabinet and jump out lid switch to run with cabinet off.Put the machine in spin,look where the shaft goes up thru center of tub.Is the clutch drum turning?IF yes replace clutch.If not replace transmission.
  3. My guess bad coupling ,cost $20.
  4. Hope this helps .........Please rate my solution :)
Dec 14, 2009 | Kenmore Washing Machines
Washer will agitate but does nothing through it's spin cycles. The timer advances through the spin cycle but you can't hear the motor run or even try to start, Washer is aout eight years old.
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
as you mentioned timer advances,then check out cold water entering the machine or not. If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Jul 13, 2009 | Maytag Washing Machines
SAMSUNG WD-J2155R DOES NOT TUMBLE . It takes in water, heats the water up but the tumbling process does not activate.
May 06, 2009 | Samsung WF203ANW Front Load Washer
Kenmore Elite Washer not draining.
CHECK PUMP SOUNDS LIKE IT MAY HAVE A SOCK STUCK IN IT
May 03, 2009 | Washing Machines
Not sure if manifold is leaking
Leaks water...check the pump first. The fill valve and hoses may be the next step. See how to take apart info. With the use of plastic drain hoses on many machines today, this has become a common leak trouble maker. The drain hose can rub the wall or a pipe and this will rub a hole in the drain hose.
  1. Agitation problems and agitator dog repair aid info
  2. Automatic dispenser information
  3. Common problems with Inglis, Whirlpool, Kenmore direct drive style of washers
  4. Diagnostic Direct Drive washer chart from American appliance
  5. How a washer works, good to read this first
  6. Help for storing an appliance
  7. How does the agitator come off my washer ??
  8. How to prevent socks from getting into your pump
  9. Ohm test a common direct drive motor
  10. How to by-pass a lid switch for testing the washer
  11. Basic information: Inglis, Whirlpool, Kenmore Direct drive washers
  12. Inglis, Whirlpool, Kenmore Direct drive washers - How to take apart - Cabinet off, cabinet on, checking or replacing a lid switch, replace the pump, replace motor coupling or motor.
  13. Inglis, Whirlpool and Kenmore direct drive washer- useful parts breakdowns
  14. Important disclaimer
  15. My direct drive washer will fill ok, agitates ok but when it comes to the spin and drain cycle the washer comes to a screeching halt...no spin, no draining and the timer stops, what's up?
  16. My clothes have a whiting on them that looks like lint.
  17. My washer has a funky odor
  18. Noises
  19. Ohm meter testing a motor capacitor
  20. Slow water fills
  21. The wash tubs on my direct drive washer are leaning to the right...why?
  22. Timer stalls or missing cycles
  23. Timer will not advance
  24. Tips on changing a common washer fill valve
  25. To learn more about washing machines, click here
  26. Washer Basics: Filling with water
  27. Washer leaks water
  28. Washer moves around to much
  29. Washer will not spin
  30. Washer sample wiring diagrams
  31. Washer spins and agitates at the same time
  32. Washer belts: If your belt on any washer looks like these, replace the belt(s).
  33. Washer runs but wont agitate or spin
  34. Washer won't run, agitate or spin
  35. What is that black power powder or filings under my washer??
Apr 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
INGLIS WASHER SUPERB AGITATOR DOES NOT WORK
sorry not real solution as I am not familiar with that design but recommend replacing machine.
Jan 31, 2009 | Whirlpool Inglis IP4400 Washer
Washer does not spin when filled with water. Makes loud noise
It doesn't spin If your washer won't spin, check these:
Dec 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine does not drain
does the water pour out when you put the drain hose close to the ground if it does then make sure your pump isnt blocked if it isnt then youll need to replace the pump most pumps have 3 little fins in them if you can stop those fins with a screw driver when pump is going then it deffinatley needs replacing as you cannot fix them sorry for the bad news m8
Sep 12, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
310 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
