Question about HP StorageWorks Media Vault Pro mv2040 (GJ422AA#ABA) 500 GB Network Storage Server
HP Media Vault - Power on / fan on / front panel indicators off
When I power on my Media Vault 500GB it does not boot. The fan is running "audible", the on button LED is ON, the network indicator LED on rear of unit is ON, non of the top front panel indicator LED light or flash. This unit was operational, shut down, then fail at the power on.
  • bentsteel Nov 30, 2008
    By the way, this is an MV2020 ... not one of the new generation "cubes" . I checked the power supply and it is producing 3.3 / 5 / 12 volts. I looked for an obvious SMD fuse on the mom board but did not see one.
    I have not been able to find a "low level" diagnostic procedure (if one exists) or a HP service manual. Since it is hard to tell what the post process is, I can not tell where this is failing in the boot process or if it is even making it to a POST.
    Any guidance here would be appreciated. Of course, the NAS is 14 months old and out of warranty. It was great while it was working but now, I can see that HP missed the Serviceablity merit badge training. I guess I expected an HP product to be full RAS. Any way, enough griping out of me. If there is a way to diagnose this I will be greatful.
  • Anonymous Dec 12, 2008
    About the same thing happened to me. MV2020 was running, came back from out of town a couple days later and only the network light was on. Unit would not power off from the front blue button. I followed the steps above - unplugged the power cord, held the reset button in while I plugged the unit back in, continued to hold for a few more seconds. After nothing happened for a few seconds, I held in the blue power button for ten seconds or so to try and do a hard re-boot. Eventually the disc drive indicator came on for a minute or so, then the OK button flashed a few times and the unit shut down. I booted it back up and all lights came back on. Despite a highly active hard drive indicator, the unit seems to be working fine. Thanks for the tip!
I read a bunch of material found on the web. Primarily this led me to believe that the Lynix flash OS has some issues (to say the least). After carefully testing out the mom board voltages I decided that there was probably a software boot issue.
I read this at
"The MV1 has a hard reset which severs the tie to the script that calls any of the installed software." The material on this site also indicated that the stored files would not be affected by a hard reset. So what the heck... nothing to lose. I unplugged the power, pressed the reset button and then applied power. Held the reset button for > 5 seconds. Held my breath for 30 seconds and the disk light started to flash on the front indicator panel. After a minute or two of that, the OK light came on. I pressed the power button on the front panel and the it responded. Another miracle? Hmmm. The MV shut down. I connected to the LAN and powered back on. Every thing worked fine.
I guess... there was a space issue / startup parameter corruption / enemy electron in the mix that was passed over with the hard reset at start up. Since there is on access to the OS boot process, (or source code) this is pure speculation. Although, it is reasonable speculation. Chao!
Posted on Dec 01, 2008
Blue power light off and fan running hard
The led may have become disconnected or failed. The power led can be replaced as it goes to a couple leads on your main board.
Sep 02, 2014 | HP Pavilion a6547c Refurbished AMD Desktop...
Hp pavilin a6547c power light is off but computer wor fine and fan is running ahigh speed all thtime
You have a bad motherboard. fans are hi all the time and power lights are not functioning correctly indicates a bad circuit on the board. Fortunately, a motherboard is not a terrible expense and it would fix all your issues. Here is one on ebay for 60.00 with shipping.
When i push the power on the fans start running and immediately turn off. power is on
1) normally the pc has software diagnostic installed by the company.
RUN the software diagnostic.
2) otherwise you must open the computer and test a) voltage a the FAN coming from power supply b)if there voltage at the FAN is faulty, if NOT the problem will be in the power supply section.
God bless you
Oct 02, 2012 | Fujitsu Siemens SCENIC E600 PC Desktop
Compaq Presario SR2150NX doesn't turn on. Front panel green light turns on but nothing else happens (no fans, no boot, no noise, nothing) Please advice
On the back of the Power Supply there should be a Green LED, When you power it on if it is flashing, this means that the Power Supply is dead and you need to replace it.
Apr 14, 2010 | HP Compaq Presario SR2150NX PC Desktop
Fan revs up intermittently and pc occasionally powers off unexpectedly. Would seem to indicate an overheating problem but not sure which fan and what exactly might be overheating. Is this a common problem...
actually it is a common problem with dells... pull off the side panel, and disconnect the fan, power it up and let it register that the fan isnt working, turn off the computer, plug the fan back in and boot it up again, if it doesnt work this time, it suggests a larger issue... such as motherboard failure... which is also quite common in dells...
Oct 11, 2009 | Dell Inspiron 531 Athlon 64 X2 4400+...
Optiplex gx280 won't boot and cpu fan goes faster
Sounds like a bad motherboard, I try resetting the bios , removing everything but the video , could be a bad power supply too (if you have one jump the wires in there as a test). you can buy those dell MBs cheap on fleabay.
Jul 30, 2009 | Dell Computers & Internet
Hp pavilion 513n power up problem
replace the cpu fan if its not spinning fast enough the computer will turn off so it doesent over heat and damage the cpu
Oct 27, 2008 | HP Pavilion 513n (P9850A#ABA) PC Desktop
Power Green Light Flashing HP Desk Top PC m7250n
During a power outage their is a surge when power come back on the grid (surge can be caused by lighting strikes akso). This surge trips the internal procters inside the power supply to protect the Mother Board, hard drive, processor and fans and any device that pulls wattage from the power supply. Since all these power using devices are trying to pull power at the same time to boot the computer back up one ends up with a loop of surge thrugh the power supply with a protective trip, reset, surge again and trip again. This will continue in this loop as the computer is trying to boot all the devices at one time (Mobo, Hd, processor, cooling fans and other devices). Simoly, more power wattage is being demanded than the protectors will allow at one time causing a protective shutdown followed by a restart followe by a protective shutdown in a continious loop.
The normall sequence for a boot is to boot the board, processor and fans followed by a boot of the hard drive, and other boot devices once the board is energised, NOT all devices at the same time, as this results in an overload and trips the protectors. This protective loop is indicated by the blinking light as the power is turned on and then shut down for protection as the wattage pull is over the demand that the protectors will allow.
Blinking light indictes you are in the protective loop.
SOLUTION: 1. Disconnect the Mother Board connector, with the computer unplugged, this will allow the power supply to reset at maximum wattage upon reboot.
2. Disconnect the Hard Drive power connector and ay boot device power supply cables, this will allow the Mother Board, processors and fans to boot without an overload of the protector inside the power supply.
3. Plug in the computer and the indicator light will be solid green indicating that it is reset and out of the loop.
4. With the computer pluged in and the Power Supply fully energised, plug in the Mother Board. The computer will now boot, and the processor fan will come on and the cooling fans.
5. After computer has rebooted, shut the computer back down and connect the Hard Drive power cable and any other power cablis that were unplugged.
6. Reboot with all cables connected and you are up and running again.
Hope this helps everone with power outages and lightining strikes. It is a rather common problem and can also occure when building a computer and one missmatches the power supply with the board wattage needs. If the board wattage needs are greater than the power supply output you will get stuck in a potective loop eventually. WHEN BUILDING A COMPUTER ALWAYS MAKE SURE THE POWER SUPPLY CAN PRODUCE MORE WATTAGE THAN YOU CAN CONSUME AT THE MAXAMUM LOAD.
Have a great computing experiense.
Jan 13, 2008 | HP Media Center m7250n (ED842AA) PC...
Flashing "F" on front of drive slot
The front panel display contains seven (7) lights which provide the following information: ? Power-On - Steady green glow indicates that power is being supplied to the Data Silo chassis. ? Temperature Warning - Flashing red indicates that internal operating temperature has reached 43? C (109° F). ? Blower 1 or 2 Failure - Flashing red indicates a blower has failed. ? Power Supply 2 Failure - Flashing red indicates second power supply has failed. ? Power Supply 1 Failure - Flashing red indicates first power supply has failed. ? Mute - When switch is depressed, a steady yellow glow indicates the audible warning sounds have been disabled. Depress switch again to enable sounds. ? Reset - Depress switch to reset chassis and clear any error conditions. The specs on the DS550 do not say anything about an F at all? Did you put the correct model number?
Aug 29, 2007 | StorCase 9 Bays Data Silo DS550 Storage...
HP StorageWorks Media Vault Pro mv2040 (GJ422AA#ABA) 500 GB Network Storage Server Logo
2,581 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
